01-05-2017, 09:21 PM | #111 | |
Rep 2,995
01-06-2017, 12:58 PM | #113 |
Rep 32
Yeah....early F30's had a problem with the base of the Sportline seat (http://f30.bimmerpost.com/forums/sho...highlight=rust). Couldn't see the rust unless you looked underneath or at the hinge. I was lucky that my dealership accepted it as a warranty claim and replaced them.
01-08-2017, 11:28 AM | #114 | |
Rep 1,485
It doesn't take much searching to find the common design issues that WILL go wrong on the E90/N54 platform. By comparison, the F30 launch was significantly more reliable. That's how improvement works, when issues are found, they are fixed on the following generations. Injectors Coils HPFP Oil pan leak Valve cover leak Water pump Wastegate/turbo assembly OFHG leak Subframe/PS pulley contact Walnut blasting Mechatronic seal on steptronic |
01-31-2017, 11:46 AM | #116 |
Rep 212
2013 328i with 67k miles
I bought the car (2013 base model 328i) in January of 2016 with 44k on it. Currently has 67k on it.
Problems so far: - Driver's side mirror electrically dead -- replaced under warranty - Hood release cable replaced (by me) with redesigned part. This was the double cable in front. Absolutely nothing was wrong with the latches. I also had to buy a set of tires on vacation after picking up a nail in one of the the run-flats. I was 500 miles from home, and had a flat leaking severely on a rainy Sunday morning; had to be at work on Monday. Very few tire stores are open on Sunday mornings! NTW in KC would not patch a run-flat tire (company policy) and had no run-flats in stock, so I opted to buy a set of normal tires as mine were going to need replacement soon. Last edited by jsouth; 02-22-2017 at 09:17 AM.. |
02-21-2017, 09:37 PM | #117 |
Rep 17
I own F30 316i build November 2012 from zero
Today i touched 190,000 Km I have done the following :- 1- two VANOS solenoid valves replaced 2- DME replaced 6 months ago 3- front crankshaft oil seal replaced 4- Head cover gasket replaced 5- two ignition coils replaced 6- the regular maintenance (oil, filters, brake pads, rotors,....) 7- Never touched the transmission oil |
02-21-2017, 10:30 PM | #118 |
Rep 1,157
closing in on 46k miles:
- Replaced a parking sensor - Replaced the head unit - Replace driver door lock - Rear hatch brake light housing broke off and was replaced - Replaced a sensor for the diesel emissions (not sure what that was...) All small problems (except for the head unit), but I had way too many trips to the dealer for all these issues on top of maintenance. I'm on the fence about getting an other BMW because of this.
2020 M2C 24.04.2020 delivery - Sold 24.08.22
03-09-2017, 01:02 PM | #119 |
Rep 155
56600 KM 2013 328xi CEL went on, turns out the engine thermostat has failed and needs to be replaced under third party warranty. Other than that it's been smooth sailing for the 3+ months I've owned it.
03-09-2017, 02:13 PM | #120 |
Rep 943
Drives: 2012 328i Modern Line
BMW extended the thermostat warranty to 10 years/120k miles.
:wave:
03-09-2017, 07:48 PM | #121 |
Rep 155
03-10-2017, 07:16 PM | #122 | |
Rep 155
Thank god I bought the extended warranty. Anyone know how much the rod bushing replacements would have cost without? |
03-11-2017, 06:57 AM | #123 | |
Rep 69
Connecting rod bushing?? |
03-11-2017, 11:11 AM | #124 |
Rep 31
2014 328D with 105,000 MI. No maintenance other than scheduled oil changes at 10k intervals, rear brakes were just done, front are coming up soon. Brake Flush after the 2 yr. mark and a fuel filter in there at some point. Whatever the computer says is what i do. nothing more, nothing less. i replaced a running light that burned out and my horn doesn't work. Other than that it feels new.
I did have two warranty repairs for the transfer case. One at 50k mark for the transfer case essentially blowing and the same transfer case issue at 75k but got them to fix again for free. |
03-11-2017, 07:27 PM | #126 |
Rep 2
2013 328xi sport
70,000 km (about 45000miles) Heated steering wheel stopped working Spring in trunk broke No other issues other than regular maintenance (oil change, tire checks, regular wear and tear). |
03-14-2017, 09:31 AM | #127 |
Rep 962
My thermostat gave out last night, 30k miles on the clock.
Symptoms included engine never reaching operating temperature, engine cooling fan running full speed and CEL (duh). Dealer said it's very common on pre-2016 models. |
03-14-2017, 05:56 PM | #128 |
Rep 155
I just had mine swapped out this past weekend due to the same issue. Thankfully the fail position for the thermostat is open preventing any potential overheating issues. Would have been a $500 job if I did not have a third party warranty to cover it.
03-14-2017, 10:14 PM | #129 |
Rep 246
Nothing big so far @45k miles. Rear passenger door trim was loose @28k miles. Low coolant warning came few times @33k miles, replaced coolant reservoir and sensor. Front passenger door pin rattle repair @38k miles. Car is MY 2013, engine is N26.
03-14-2017, 11:43 PM | #130 |
Rep 597
2013 328i xDrive, 65k miles on clock, owned since 52k.
Rear passenger window motor, side cameras + wiring, both covered under CPO. Other than that, just oil every 5-7k and brake fluid/coolant flush at 60k. Will be doing transmission fluid and pan myself, same with diffs and xfer case. -tgm |
03-14-2017, 11:58 PM | #131 |
Rep 797
For those with front side cameras. Do yourself a favor and put dielectric grease on the connector. These things are prone to water intrusion like a mofo...
03-15-2017, 08:33 AM | #132 | |
Rep 797
