10-21-2015, 03:27 PM | #111 | |
BMW Fanatic
331
Rep 1,076
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
10-21-2015, 03:38 PM | #112 |
Rep 33
Nick - Thanks I'll wait. That will be helpful to see comparison pictures between Option 1 and Option 2. Interested if it's worth 2-3x the cost ($80) more?
Option 1 = 2x H8 CREE LED 50W ($19) + 1x CanBus resistor cable pair ($8) = $45 Option 2 = 1x H8 CREE XHP50 LED Headlight Kit - 3000 Lumens = $125 |
10-21-2015, 03:46 PM | #113 | |
BMW Fanatic
331
Rep 1,076
10-21-2015, 05:34 PM | #114 | |
Rep 1,436
10-23-2015, 04:24 PM | #115 | |
BMW Fanatic
331
Rep 1,076
10-27-2015, 10:22 AM | #116 |
Rep 153
Hi all,
I have a F36 and want to convert rear turn signal to LED. From the thread I have clear that I should go for this: http://www.horizonleds.co.uk/cree-le...cree-led-bulbs but... which color? white or amber? I am from Spain and my rear turn signal lens are amber already. Thanks in advance. Regards! |
10-27-2015, 11:15 AM | #117 | |
BMW Fanatic
331
Rep 1,076
11-03-2015, 01:10 AM | #120 |
BMW Fanatic
331
Rep 1,076
11-07-2015, 02:11 PM | #121 |
Rep 33
Thanks Nick, I just ordered the H8 CREE XHP50 LED Headlight Kit. I'm slightly worried about the color being too blue from you pics, but I guess I'll try the (supposedly very difficult) color filters if it's too blue.
These don't need Canbus Controllers and don't need coding, right? Don't want to deal with either. Basically, I just want color matching LED fog lights! |
11-07-2015, 06:37 PM | #122 | |
BMW Fanatic
331
Rep 1,076
They won't be blue at all! They're just whiter than the Xenon bulbs without the filter. The only coding needed is the cold + warm bulb check coding. No CanBus connectors needed. If you need help, lemme know.
11-10-2015, 12:30 PM | #123 | |
Rep 307
I've sent them this, through here "Order number- 3855 I've emailed you direct, filled in your online form, now I'm here. The PHILIPS-HLKT-H7-GEN3 I ordered on 06-June-2015 have failed, the plastic bases that clip into the lamp unit have snapped, leaving the bulb hanging out, I am trying to get a warranty replacement sent out ASAP but nobody is responding to my messages???" It's pretty poor waiting this long for a response, Horizon LEDs are dearer than most, but you're paying a premium for quality, reliability, & service..... the later at which Horizon led's are failing miserably |
11-10-2015, 12:31 PM | #124 | ||
BMW Fanatic
331
Rep 1,076
11-10-2015, 12:50 PM | #125 | |
Rep 307
Thanks for that, not sure what SEMA is but i'm sure they would have access to messages for their business. I've also just left a message on their FB page, man that page is full of complaints |
11-10-2015, 01:34 PM | #126 | ||
BMW Fanatic
331
Rep 1,076
Hope this helps
11-24-2015, 09:37 AM | #127 |
Rep 33
Do NOT fit 2012 328i F30
Well, my LED lights from Horizon cam yesterday but they don't fit on 2012 328i F30.
H8 CREE XHP50 LED Headlight Kit: http://www.horizonleds.co.uk/cree-le...adlight-kit-g4 I installed the driver's side in less than 5 minutes and tested it – I was super impressed, it looked amazing! But then when I opened up the passenger side wheel well I immediately saw an issue – there is a radiator about 0.5" inches to the left of the "butt" end of the light and a plastic injection mold point about 0.5" directly above it too. I immediately knew the fatter "butt" end of the headlights (linked above) would barely fit and definitely touch. So I carefully cut off the excess plastic injection mold point, and pushed the radiator over and barely was able to install the LED light. About 1 inch of the LED headlights "butt" end radiator/fan is mashed against the radiator rubber. I let it run for 5 minutes to see how hot it would get on the radiator – it was too hot to touch after just 5 minutes. So I had to uninstall them both. There is no way I can leave that much heat directly mashed against the rubber of the radiator. It would definitely burn, or worse. Pics: https://www.dropbox.com/sh/o1vptpimz...OHhFAG1Ra?dl=0 Horizon better have a good return policy, $180 shipped to the US! I wanted to share so no one else makes the same mistake. Now I need new ones with a small butt end and located in the US. Any suggestions? I want the best available, that fit easily, cause no errors, and match my Xenon headlights. Option 1: https://bimmian.com/Accessories-for-...g-Light-Bulbs/ Last edited by rjjy; 11-24-2015 at 10:13 AM.. |
11-24-2015, 12:44 PM | #128 | |
Rep 1,436
11-24-2015, 12:57 PM | #129 | |
Rep 1,436
http://m.ebay.com/itm/5000LM-Fog-Lamp-Cree-XML2-H8-H11-Heat-Copper-Belt-No-Fan-LED-for-CHEVROLET-x2-/351571546016?nav=SEARCH |
11-24-2015, 02:47 PM | #130 |
Rep 33
Thanks man! I saw that style and had the same idea that it could work, but then I was thinking it will be equally as hot and again right up against the rubber of the radiator?
11-24-2015, 02:49 PM | #131 | |
BMW Fanatic
331
Rep 1,076
Edit: I'm talking about the XP50.
11-27-2015, 10:00 AM | #132 |
Rep 33
