02-26-2020, 05:59 PM | #1409 |
Rep 2
I noticed this hasn't seen a lot of activity lately, but I've just started having this issue on my '13 335i. When people are saying the fan was replaced, do you mean just the fan, or the whole fan assembly? I can find just the fan for about $80, but the whole assembly is 10x that amount.
05-02-2020, 09:34 AM | #1410 |
Rep 25
Bump
I know this is an old thread but now there are those like me that purchased a used 2013 or early 2014 335i msport that have this issue (no need to tell me I should have bought CPO, salt is already rubbed in) Bought mine (7/13 prod date) 2014 model year and it is limping after driving spirited. Pulled up codes with bimmerlink and found the infamous 1A2108 code I also found this static link to the tsb everyone is mentioning. Shame it’s only covered under warranty but at least there’s a fix https://static.nhtsa.gov/odi/tsbs/2014/MC-10149351-9999.pdf Has anyone had luck getting this done outside of warranty for free? It’s borderline a safety issue. For those that had this fixed outside of warranty, what are the costs? I’m reading about $700. Does it have to be done at a Bmw dealer bc of the software flash required? Besides this, car is running like a champ! |
07-27-2020, 10:57 AM | #1412 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
I recently got error code 1A2108 from my BM3 software. No CEL on dash and car drives fine.
I haven't noticed anything else but I am going to buy the fan and replace it myself. I notice that a lot of people go into limp mode but why I haven't yet. |
10-13-2020, 09:31 PM | #1413 |
Rep 75
Can anyone confirm if the OEM electric fan on an f30 335 msport is 800watts? And is there an upgrade available in the market?
F30 335i Mperformance |Pure turbo stage 2|Upgrade LPFP|BMS Intake|VRSF CP|CTS catless DP|CTS FMIC|KW v2|MHD PS2 tune| M titanium performance exhaust|Xhp stage 4|Xdelete
07-01-2021, 08:30 PM | #1414 |
Post Advisor
1653
Rep 1,710
Just experienced this today for the first time. After being on the highway for a while, car refused to accelerate after about 2200 RPM. After 30-60 seconds, the car accelerated like normal... until it didn't again! No CEL, no codes, no drivetrain malfunction, literally no warnings. Oil temperature was low as described by others. Seems that the problem may be similar to what others have described. Is there an extended warranty that BMW has issued for this problem? This is a major safety issue for sure.
12-16-2021, 08:10 PM | #1415 | |
Rep 3
03-15-2022, 10:12 PM | #1416 | |
Rep 51
07-30-2022, 09:26 AM | #1417 |
Rep 28
Purchased my '13 F30 N55 M-sport just before the pandemic. Went into limp mode (no CEL) on a few occasions usually after driving for an hour and trying to accelerate on the highway. This past week I have experienced the drivetrain malfunction warning with the following fault codes via BM3: 1A2108 & 120308. Going to have the fan replaced next week so hopefully the issues are resolved for FC 1A2108. As for FC 120308; between pressure converter, vacuum leak, boost solenoid, diverter valve or wastegate, hopefully my mechanic can pinpoint the exact cause.
2013 335i xdrive (pwg): BMW MPE, BMS Chargepipe, BMS Wheel Spacers 10/12, BM3 tune, M performance Calipers, Qi wireless charger, Bilstein B4 EDC suspension, Eibach Pro Springs + F80 bumpstops, Zimmermann Formula F rotors, Active Autowerke FMIC
08-07-2022, 11:47 PM | #1418 | |
Rep 4
12-09-2022, 02:52 PM | #1419 | |
Rep 1
Will replace with 850w fan and update you Car went into limp mode for first time on the highway on the way to work also a CEL appears noticed oil temps were at 250 mark highest it’s ever been |
12-09-2022, 07:16 PM | #1420 |
Rep 5
Drives: F30 335i, E46 328ci
This is definitely good to know, i haven't experienced any of this, (knock on wood).
07-18-2023, 04:01 PM | #1421 |
Rep 1
Fan stopped working/AC stopped working on 2017 340i
Hey All,
Just wanted to give a heads up to folks with later model BMWs, the fan issue is still a thing. My AC stopped working here in PHX and then got a Overheating warning during stop and go traffic. I was only a few miles from the house so just limped it along, car would cool down if I was driving over 30MPH. Anyway, turned out to be the fan, I found one for $250 off Ebay which I was able to pick up from the warehouse here in PHX, so no shipping. Was easy to replace, just took out the airbox and intake hose, disconnected the fan wire, took out the one screw and unclipped the driverside upper clip, and pulled it right out. At least it was an easy fix I suppose, wish they would use better fans though. |
