06-22-2018, 06:56 AM | #177 | |
Rep 646
| 2021 Tesla Model 3 |
06-26-2018, 03:44 AM | #179 |
Rep 157
07-06-2018, 03:51 PM | #180 |
Rep 12
I finally had installed this retrofit into my 2016 f30 at local bmw dealership only after 3 weeks they had my car. They installed it but the idrive is not working (it does not activate anything at all) they now claim their diagnostics computer is not showing any retrofit option anymore, after reading in the posts that this idrive problem (not activating) seems to be a wiring problem I will check out for wire connections. I opted for an AVIN 10.25 screen to upgrade from my 6.5" one, not sure that may be an issue too. Do you recommend I plug the old small 6,5 and try again? At this point bmw local dealership doesnt know how to make it work and I wasnt succesful on my first attempt to learn coding since my lap top didnt connect to my car but I assume the work done at the local dealership may have already coded my retrofit since their diagnistics computer did actually recognize the retrofit and this may be a smaller hardware installation issue. Guidance or tips are highly appreciated.
**local dealership didnt charge anything since I have complained they are not completing the work or providing a proper solution & now they are still looking into it but I think they are clueless since they have never done this before** I am pretty confident I will nail it down with all I have read here and even it may only activate US CAN maps (I am in Mexico) I wanted the feature along with the larger screen instead of buying a whole NBT from ebay at a much higher cost. Last edited by alexgarcia; 07-06-2018 at 04:05 PM.. |
08-22-2018, 08:06 PM | #182 |
Rep 159
I'm going to throw a guess that it's an issue with the integrated navigation's software. It was designed for the smaller RadioProf/Buisness 800x480 screen resolution, hence if you conntect the the nav-module to your pc and peek under its storage youll find in the subfolder "Navi", there you'll find another subfolder Skin800x480.
The bigger 8.8" screen, has a bigger resolution with a different aspect ration which I guess does the fuckery. Unless someone doesnt modify the Integrated Navigation's software to work with the bigger 1280x480 resolution of the 8.8" screen, this will not work. |
04-05-2019, 04:47 PM | #183 |
Rep 41
I have the same problem. I upgraded of my 6.5inc screen to 10.25 inc by an android 7.1 unit.
After the following coding: HU_ENTRYNAV> 3000 HMI > DISPLAY_SIZE_RESOLUTION = 10.25_1280x480 HU_ENTRYNAV> 3001 EXBOX > DISPLAY_VARIANTE = breites_display Everything worked fine except the integrated navigation. The integrated navigation is not supported since the resolution of the new screen is 1280x480, will the previous one was 800x480. I have also tried the split-screen option but still nothing. Does anyone know if this problem can be solved through coding? |
04-06-2019, 10:06 AM | #184 |
Rep 1,325
I had business nav on the small screen and Entrynav. Upgraded to the 10.25 screen coded as above it the nav works fine across the whole screen. The only thing I havent done yet is select the highest of the two 10.25 resolutions
04-09-2019, 01:30 AM | #186 | |
Rep 6
thank you |
04-15-2019, 08:38 AM | #188 |
Rep 646
Would love the same - sick of my small 6 inch screen with this old-school navi on it...
Just read a lot of bad things about the Android systems - have you had any luck? Basic Apple Carplay on a big display is all I ask
05-04-2019, 02:41 PM | #189 | |
Rep 159
05-20-2019, 04:57 AM | #190 |
Rep 30
Welcome everyone. Update is how to activate HBA for F10 LCI 2016 with the switch off switch(Without buttun HBA). Thanks for the NCD TokenMaster comparison tool
Who can help me? I Have Coding VO FRM, FLA3 after adding 5AC. Conclude. Only works very well after Coding times. It turns itself off when the engine turns on the next time, I also switch the A-Off - A light switch, it doesn't work again. Note: I choose FDL FRM, do not edit the code (FDL after having 5AC), and HBA works again, I decided to run the test to see if it worked. As a result, it works very well, turns itself on and off high beams according to traffic, but when it stops and starts again, it disappears. I have read somewhere on forums of HBA activation commands 1. / FRM >> FLA_VERBAUT = aktiv 2. / FRM >> FLA_AUTO_AKTIV = automatisch 3. / KAFAS2 >> 3050 >> FLA_ON_OFF = aktiv But I equipped the mirror in FLA3 so I couldn't find it KAFAS2 >> 3050 >> FLA_ON_OFF = aktiv, and I also rummaged in FLA3 nor did FLA_ON_OFF or it changed to another code? I also searched in FRM the following code a. / 3000 FRM_VERBAU_U_ALLGEMEIN, 20 LIN_PUBU_TLC nicht_aktiv (not active) = 00 Comment = BEFAS: Auswertung des Tasters TLC (Time To Line Crossing / Fahrspruverlassenswarnung) am Bedienteil Fahrerassistenzfunktionen b / / 3050 FRM_AUSSENLICHT_PARAMETER, 30 FLA_TASTER_LIN ueber_can = 00 Comment = 0 - FLA Taster Information wird über CAN-Bus eingelesen: SZL ---> FRM 1 - FLA Taster Information wird über LIN-Bus eingelesen: BEL -> FRM " OPTIONS ueber_can = 00 ueber_lin = 01 c. / FLA_BEL_POS stufe_A = 01 Comment = 0: FLA will be activated if BEL is in POSITION AUTO or MANUAL LOW BEAM; 1: FLA will be activated if BEL is in POSITION AUTO Blendfrei nur in A, da auch nur hier die AHL funktioniert OPTIONS stufe_A_und_II = 00 stufe_A = 01 But I'm not sure these commands can automatically HBA. Does anyone know please show me Thank you very much |
01-13-2020, 02:10 PM | #191 |
Rep 16
integrated, navigation |
