01-01-2020, 11:57 AM | #178 |
Rep 36
Yes, short oil change intervals 5-6k max, get rid of the stupid ASS, if you're worried about your fuel economy, just from personal experience, I've always got better MPG figures on normal drives than what's on the window sticker and that's with ASS off.
Some might agree or disagree but using a can of Liqui Moly Motor Clean every 30k before an oil change shouldn't hurt. My trust in the German oil company is high. |
JoeyF3021.00 StradaRedlands5029.00 |
01-10-2020, 04:11 PM | #180 |
Rep 230
Well, over last years on this forum I saw pictures of engines with inside:
- thick layer of sludge and fully working TC - surgically clean surfaces and and ripped TC Go figure.... |
01-11-2020, 05:31 AM | #181 |
Rep 53
I’m stopping in from the F10 forum and am wondering what the intelligentsia thinks of my engine in the video below. Cam lobes resting allowing slack when cold? Lifters filled with oil after started thus tightening the chain? These items were discussed earlier in this thread. Thoughts are appreciated.
2016 528iXDrive
1988 Carrera Coupe |
01-14-2020, 12:58 AM | #182 |
Rep 170
So I remember reading this was normal however I have not observed it on my engine. Also that seems more loose than I would expect. Do you have a boroscope camera to look deeper?
Oddly sounds fine to my ear though so I don't know what to make of it. I'll see if I can get a video in the morning of my chain after sitting all night. If its lose I'll post for comparison. |
01-16-2020, 03:40 PM | #183 |
Rep 55
My F10 N20 is doing exactly the same when cold. Will try it after running the engine few minutes to see if it stretches. I am just 3k km away from the canadian limit...will try changing it before costing me half of the car.
01-17-2020, 10:05 AM | #185 |
Rep 212
01-17-2020, 10:38 AM | #186 |
Rep 19
01-23-2020, 07:13 PM | #187 |
Rep 212
01-26-2020, 03:35 AM | #189 |
Rep 1
New to forum, timing chain mileage question
I've been worried about the timing chain in my car and as of right now I sit at 108k miles. I have a 2015 328i and just did a oil change in the car today. Checked under the oil cap to see what color my guide is and it looked pretty dark orange in color. I've put a few mods in the car like a gfb dv+ valve, an mst inlet pipe, injen intake and mishimoto catch can. I haven't had any unusual whining or whirring sounds but I tend to drive the car pretty aggressively some days. I had a mechanic say that timing chains should be replaced at least every 100k. Is there any truth to that? Should I be looking at replacing my timing chain? Appreciate the help.
01-26-2020, 06:51 PM | #190 | |
Rep 326
Your car is likely not affected given its year, and probably has the updated parts. All plastic guides are originally white, and become the caramel colour due to oil saturation, heat etc. Check for slack and whine, otherwise I see no reason to change.
If you can imagine it, you can achieve it.
If you can dream it, you can become it. |
sspade2475.50 |
01-27-2020, 08:41 AM | #191 | |
Rep 5,460
Drives: F30
If your car was built after 02/2015 then you have the new components. Period end of story. Check your build date and move on. Also- any mechanic who tells you that you should change your timing CHAIN every 100k is a thief. |
01-29-2020, 07:54 AM | #192 | |
Rep 420
01-29-2020, 07:59 AM | #193 | ||
Rep 5,460
Drives: F30
He specifically states he has not seen a revised components vehicle fail. That being said, I wouldn't say it impossible just highly unlikely. I personally haven't see any reports of 2015+ vehicles on this forum but again, that doesn't mean it hasn't happened. |
CandyRedRC46242.00 |
01-29-2020, 12:17 PM | #194 |
Rep 71
About 2 years ago I brought the car in to the dealership because of a whine when cold. I was told the noise is normal, but my HPFP and wastegate was noisy so those parts were replaced. However, the whine did not go away so I just ignored it because the dealership said the noise was normal.
Fast forward to 2020. So I decided to finally check my timing chain for slack with a cold engine. The chain has a lot of slack and the guide rails move a lot too. I know the chain might have some slack because the tensioner has no oil pressure, but is it normal for the guide rails to have this movement also? Video below... 2012 F30 N20 w/56K miles |
meltbox43.00 StradaRedlands5029.00 |
01-29-2020, 02:34 PM | #195 |
Rep 5,460
Drives: F30
@m95roadster
That does move a bit much. Id be concerned. You should do a comparison video after a drive (with oil warm). Of course, let it cool for a few minutes to avoid burning your finger. Interested to see if it still moves that much when warm. |
01-30-2020, 05:18 AM | #197 |
Rep 1
Hi Guys,
so I was reading in alot of platforms regarding the N20 timing chain and oilpump chain issues, because I am also an owner of an 328i F30 with this motor. I already let the the oilpump chain renewed because of some hauling noice before 1 year. Interesting is that actualy I hear some sorring noise inside the car when accelerating - best between 2000-3000rpm. Did anybody else had some similar symptoms? There is no hauling, it is just like a sorring noise which bring me headache. Best to hear at 00:30 in the video. Any advice? https://youtu.be/HCeal1wyLR8 Last edited by SubSeven00; 01-30-2020 at 05:19 AM.. Reason: Added Video |
01-30-2020, 09:27 PM | #198 | |
Rep 170
EDIT: Actually there is a park that pivots not sure if that is the part. Last edited by meltbox; 01-30-2020 at 09:35 PM.. |
