04-11-2017, 01:16 PM | #1432 |
Rep 40,765
I replied to your same PM.
FlorinQCK-2.50 |
04-11-2017, 02:31 PM | #1435 |
Rep 40,765
What is wrong with the Link in Post # 5:
http://f30.bimmerpost.com/forums/sho...02&postcount=5 I just checked it, and it works just fine.
FlorinQCK-2.50 |
04-11-2017, 04:48 PM | #1436 |
Rep 3
Managed to solve my issue, updating in case anyone else runs into this.
I was basically following instructions for a different program. I encoded my original .fsc into base64 using an online app, then saved it as one line in a new .fsc file. This is the wrong thing to do. Just use the stock .fsc file you get from ESYS and run it through the program, it takes care of the base64 for you (even on a 64-bit Windows 7). Finally got my 2017 maps now Last edited by new_bae; 04-11-2017 at 07:39 PM.. |
FlorinQCK-2.50 |
04-16-2017, 12:32 PM | #1438 |
Rep 40,765
0xA8 0x2B
04-17-2017, 03:08 AM | #1439 |
Rep 5
I gave up...I did everything step by step but i can't get my code. Various errors as "is not recognizet or can't read the file". If someone wants to help me i owe you.
I'll attach my FSC extracted file. MAPS NBT EUROPE NEXT 2017-1 Many thanks in advance! FOUND IT! Don't need it anymore Last edited by qikz; 04-17-2017 at 08:17 AM.. |
FlorinQCK-2.50 |
04-19-2017, 04:23 PM | #1440 |
Rep 3
I've read through some of the pages here, and I was able to successfully update my 2014 NBT maps, but I am now trying to do the same for our 2013 F30 which has the CIC navigation.
Am I able to use the same method to extract the FSC code from ESYS, or do I need to have the SWID_Reader & EDIABAS software for that? |
FlorinQCK-2.50 |
04-19-2017, 04:25 PM | #1441 | |
Rep 40,765
FlorinQCK-2.50 |
04-24-2017, 05:03 PM | #1443 |
Rep 32
Hy Guys,
I am new here and I have some question regarding to connection. I followed Kretzu tutorial step by step but for some reason I can not connect to my car. ZGW_SEARCH shows me blank white page with no error message. Refresh button do nothing in this case. I am using Win 7 Home Premium x64 with turned off Wifi, Kaspersky, Windows firewall, disabled wifi and other unused network adapter. Ediabas Installed, ECU content copied, ENET 6801/6811 config set, NET. framework 4 + java. Ignition on and my PC is connected. What am I doing wrong? Any input is appreciated! |
FlorinQCK-2.50 |
04-25-2017, 12:22 AM | #1444 |
Save the manuals!
6015
Rep 6,746
I'm having an issue on a Canadian 2012 CIC E92. I pulled the 1B file, trimmed the a.hex as per usual but when generating through the FSC generator for 0x2D and 0xFF, the FSC code doesn't work. 2D is for North America Premium maps, right?
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
FlorinQCK-2.50 |
04-28-2017, 06:52 AM | #1445 |
Rep 40,765
FlorinQCK-2.50 |
05-01-2017, 12:34 PM | #1446 | |
Rep 32
FlorinQCK-2.50 |
05-01-2017, 10:14 PM | #1447 | |
Rep 8,364
BMW Standard tools is not required. TCP/IPV4 should also not be configured. |
FlorinQCK-2.50 |
05-02-2017, 12:55 AM | #1448 | |
Rep 32
Should I start the engine or the ignition is enough? |
FlorinQCK-2.50 |
05-02-2017, 01:30 AM | #1449 | |
Rep 8,364
You would be using tool like E-sys to pull DE file. Then, command prompt or Generator Wrapper to create FSC for designated map. Neither of these programs require EDIABAS. Engine should be on for proper connection and power to all relevant ECU's. |
FlorinQCK-2.50 |
05-02-2017, 03:09 AM | #1450 | |
Rep 32
FlorinQCK-2.50 |
05-02-2017, 03:17 AM | #1451 | |
Rep 8,364
FlorinQCK-2.50 |
