BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Bimmercode app iOS/Android
      08-16-2017, 11:04 PM   #67
AudiA4
AudiA4's Avatar
648
Drives: 2022 G01 X3 M40i (Black/Black)
Originally Posted by nineiron View Post
i just coded a bunch of things (1 at a time) and on several of them i got the 'chassis error' and the car shut down. the app said the coding was successful on every change. i tested after and all the things i coded worked fine.
did anyone else get the 'chassis error' and have the engine shut off after coding a change?
do i have to do anything about these errors?
The exact same thing happened to me. No issues moving forward.
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust
2006 E90 330i (Silver) 6MT, Sport
      08-16-2017, 11:09 PM   #68
nineiron
Drives: 335
do we need to clear these codes or is it ok for them to be in the logs?
i'm still under warranty.
      08-16-2017, 11:10 PM   #69
AudiA4
AudiA4's Avatar
648
Good question. I don't know. Can you clear codes with the Bimmercode app?
      08-16-2017, 11:17 PM   #70
nineiron
Drives: 335
no, there's another app called BimmerLink by the same developer.
but i've used a free app called 'torque' with my old car (infiniti) to clear errors. i'm not sure if it will work with the bmw though.
AudiA4647.50
      08-17-2017, 02:30 AM   #71
gurpzz
Drives: 2013 BMW 328i xdrive
Originally Posted by spuntyb View Post
Don't ask...
Okay, I clicked the Code button after making all the changes. I wasn't doing that at first...
I just ordered my OBD2 Wifi Foseal scanner from amazon. Cant wait to try bimmercode to code my bmw!!
      08-17-2017, 07:14 AM   #72
scostu
scostu's Avatar
Drives: 2016 F25
Same here....no problems though.
      08-17-2017, 11:45 AM   #73
LMK5
Drives: 2017 330i Imperial Bloo
Are you saying that the chassis errors disappeared and that the engine only shut down once without it happening again?
      08-17-2017, 11:51 AM   #74
scostu
scostu's Avatar
Drives: 2016 F25
I coded 1 item at a time.
Chassis error came on and car shut down. I restarted car and error was gone and what I had coded, worked.
      08-17-2017, 03:11 PM   #75
nineiron
Drives: 335
good to know the chassis error is common so nothing to worry about!
but the question is do we need to clear this from the error logs? will it affect the warranty?
      08-17-2017, 04:05 PM   #76
ishowerinjager
ishowerinjager's Avatar
Drives: 2017 340i M Performance Editio
I'm curious why you're coding with the engine running??
Code with the ignition on but engine not running. Just keep your coding sessions short so you don't drain the battery.
Could you be getting the chassis error because the ECUs restart after coding when the engine is running and it throws a code? If the ECUs restart and they can't all talk to each other I could easily see it throwing a code
2017 340i M Performance Edition: Fashion Grey, MPPSK, M performance front splitter, rear diffuser, side sills, black grille, CF spoiler, 405M 20s, 8AT, full Marino interior and dash, adaptive suspension
      08-17-2017, 06:05 PM   #77
scostu
scostu's Avatar
Drives: 2016 F25
It's August in Florida.......it's 102* in the shade.
      08-17-2017, 06:08 PM   #78
ishowerinjager
Understandable haha. Try an evening code session without the engine running and see if you ever get the errors again
scostu1623.00
      08-19-2017, 09:06 AM   #79
F30Beast335i
Drives: 2013 f30 n55 335i
yeah dont code with the car running , code with the ignition on like previously stated if its hot roll your windows down or go to a parking garage or something. not the smartest idea to code with car running.
      08-19-2017, 12:12 PM   #80
AudiA4
AudiA4's Avatar
648
Why would it matter if your car is running? What matters is that the ignition is on.
      08-19-2017, 12:24 PM   #81
F30Beast335i
i mean you can but if you do you will constantly get error codes thrown and have the headache of erasing them or getting them to clear. It is highly recommended to code with just the ignition on and in the run position as the ecu will automatically shut car off and reboot. you do what you want but its smarter to just have car off , i have always coded with ignition in run position and never gotten a fault error code of any kind using the bimmercode app.
      08-19-2017, 12:27 PM   #82
AudiA4
AudiA4's Avatar
648
You may be right, but there was zero guidance on this on the Bimmercode website OR in the app. I would think if that were a big issue, they'd make it a big issue.
      08-19-2017, 12:29 PM   #83
F30Beast335i
Google it .
      08-19-2017, 01:04 PM   #84
Eternal
Drives: 2015 435i xDrive
Received my OBD module yesterday, downloaded the App today. Everything went smoothly on coding, wish it had a better explanation for some of the choices. I am going to go through and make a list of the ones I am unsure of.
Did have an issue with a warning popping up and a Triangle on the dash now. I changed some of the lighting to active and a warning after coding popped up that I did not have time to take a picture of, but it was along the lines of a Lighting failure, contact your dealer. And now the Triangle on the instrument cluster is there. I did not do any of the expert mode stuff.
I there a way to read the erro codes?
Also, I changed the startup animation on the Center Console display to the "M" and on the cluster to the M Performance. It says "M550D". They didnt have anything 435i specific and I did not choose a 5 series one, so I need to go back and find a better one.
      08-19-2017, 01:20 PM   #85
F30Beast335i
http://www.bimmerfest.com/forums/sho...d.php?t=892286
      08-19-2017, 02:08 PM   #86
AudiA4
AudiA4's Avatar
648
I'm not arguing it either way. My point was that the app developer for the coding device itself doesn't mention it. I specifically went looking for this answer before I started. Regardless, there's not even consensus in this link (which is just another web forum full of hacks like us throwing out uneducated advise...generally).
      08-19-2017, 03:37 PM   #87
dr.roro
Drives: 2019 G01 X3
I think you can use the app called BimmerLink by the same developer to read and clear codes, although it appears to only display the codes in German. (I haven't personally used the app.) Or you could try another third-party app like DashCommand or OBD Fusion.
Were you coding with the engine on or off? Do you remember which specific coding changes triggered the lights?
      08-19-2017, 03:45 PM   #88
Eternal
Coded with Engine off. It rebooted just fine and everything worked. I do not remember the exact ones, but it all had to do with lighting. I know I changed the length of time for lights to stay on when leaving the car, brightness of DRLs, stuff like that.
