02-19-2017, 08:36 AM | #551 | |
Enthusiast
468
Rep 1,791
Drives: F87 M2 / F31 330d
Garage List 2004 E46 BMW M3 [0.00]
2017 F87 BMW M2 [10.00] 2013 F31 330d Touring [9.50] 2009 E89 Z4 Sdrive 30i [9.00] 1989 E30 320is 2-door [10.00] 1986 E28 M535i [9.00] |
I've actually never unplugged the cables attached to the air vents/trim. To unplug the wires leading to the ac/radio controls, just pull on them. I've tried to unlock the plug using a small screw driver myself, never worked. Just pull like in the video and it will come out. In one piece!
2017 F87 ///M2, Long Beach Blue, 6MT
2013 F31 330d Touring, ///M-Sport, Alpine White, Alcantara/Cloth, 19" Style M403, 8AT 2009 E89 Z4 SDrive 30i, Titanium Silver, Coral Red Leather, 19" Style 296, 6MT 1989 E30 320is, ///M-Technik II, S14 Engine, Sterling Silver, Black Leather, 16" BBS RS 003, 5MT 1986 E28 ///M535i, Agate Green, Pine Green Velours, 16" ALPINA, 5MT |
02-20-2017, 02:13 PM | #552 |
Rep 785
Got it on. Did it without unplugging anything which was kinda a pain in the ass. Oh well, looks great!! I think I like classic mode better for the lights as it matches the rest of the lights on the dash, AC, etc.
02-21-2017, 03:20 PM | #553 |
Rep 3,022
Drives: 2019 M2 Competition
I got my parts today, and built out the splitter wire.. I need a proper crimping tool for these style of connections that is for sure. That was far more trouble than I should have had doing it!
Ironically enough, my car is (still) in the shop so cant do the full install until it is back. Grrrrrrr. |
02-24-2017, 03:47 AM | #555 |
Rep 2
Does anyone know how to remove the radio and climate buttons from the old Matte trim to be able to put them into the new glossy trim? I removed my radio and climate control face plate from the car but I couldn't find a way to actually release the two units that contain the buttons. I figured I'd ask you guys before breaking something 😝
02-24-2017, 03:50 AM | #556 |
Rep 2
Remove the climate and audio control buttons from the matte trim.
How did you remove the controls from the matte trim to get them into the new gloss trim?
Thanks in advance! Quote:
02-24-2017, 06:39 AM | #557 | |
Rep 785
I couldn't get the plug out so I did mine while it was still wired to the car, which was not ideal. BTW I got pissed, used a bunch of force and it came out. Figured no worries if I mess up the matte trim as I was replacing it anyway haha. |
02-24-2017, 06:53 AM | #558 |
Rep 2,152
if you look carefully you can see the tab i used a small flat head and popped the clip then apply pressure to push it out
like mentioned constant pressure required otehr wise it pops back. do one side first i.e left to right not top to bottom
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
02-25-2017, 01:09 AM | #560 |
Rep 5
Struggling with Y-cable
I'm having trouble fitting the two wires into the connector and have probably ruined my first set of parts.
Anyone willing to sell a Y-cable? It'd save me a lot of time and aggravation! |
02-25-2017, 03:54 PM | #561 |
Rep 1,369
Drives: F80 M3 6MT
@madmortar ^^^This. You need a small flathead and constant pressure. A flashlight is helpful too for the middle ones. If you are worried about scratching the HVAC panel, use a microfiber cloth. If I recall, getting the bottom portion out first and then the top made it easier. There are tabs in the middle between the two and the upper ones are so tight there leaves little room to release much pressure.
15 F80 M3 Mineral Grey/Black 6MT
02-25-2017, 06:24 PM | #562 | |
Rep 785
02-25-2017, 11:17 PM | #563 |
Rep 3,022
just finished the install.. really simple honestly even including building the cable. The change looks fantastic and the first of many I suspect for my 435!
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
02-27-2017, 05:12 AM | #564 |
Rep 2
I'm having problems finishing up the install. When I try to put the cover which houses the 'above cupholder led', it pops back out. When I install the old trim it snaps into place perfectly.
Does it have to do something with the extra wiring? Anyone else ran into this problem? |
02-28-2017, 07:20 AM | #567 |
Rep 2,152
Just make one for the cost of it and it's so simple. I made mine with pliers
02-28-2017, 07:27 AM | #568 |
Rep 2,152
those that are struggling with making a cable there is an easier way with a tool that most have at home... a crimper
instead of buying 2x Universal pin terminal uncoded 3 POL. #61136931929 1x Universal socket housing uncoded 3 POL. #61138377072 3x pin contact 0,2- 0,5MM˛ #61130005198 (comes with crimped on cable!) 3x bushing contact 0,2- 0,5MM˛ #61130005197 (comes with crimped on cable!) 3x pin contact 0,75 MM˛ #61131393723 (without cable) just buy these instead 2x Universal pin terminal uncoded 3 POL. #61136931929 1x Universal socket housing uncoded 3 POL. #61138377072 6x pin contact 0,2- 0,5MM˛ #61130005198 (comes with crimped on cable!) 3x bushing contact 0,2- 0,5MM˛ #61130005197 (comes with crimped on cable!) put all the pins to the the connectors and then collect all of the 1's and crimp together. or solder and heat wrap. the only reason to do it the way in the post is because it looks a lot neater and thats is why i did it that way but its hidden behind dash so who cares
03-04-2017, 02:16 AM | #569 |
Rep 25
Did this last night, it was kind of a PITA but got it done and it looks awesome! Thank you OP for this. Problems occurred when i could't get the wiring off of the ac control unit and had to handle the panel when still attached to car. But at the end, nothing broken but my fingers, and as said, looking good
Edit: Added pic, sorry about the steamy windows, but was too anxious to get this done, and weather was what it was, and, and, and... Last edited by Fasse; 03-14-2017 at 12:30 PM.. Reason: Added a pic |
Dante467.50 |
03-06-2017, 10:24 AM | #570 |
Rep 164
I have read through the post and I have a question concerning the lighting. I have a 2013
335xi with the M sport option. If I do this mod will the light on the trim panel be the amber/orange or would it light up white. Reading the posts I think it would be the white light because I have the sport package. I don't think you can change the lighting color with out during some type of coding. Thanks in advance to everyone that reply to my question. |
03-06-2017, 10:32 AM | #571 | |
Enthusiast
468
Rep 1,791
