11-11-2018, 06:44 PM | #177 | |
Rep 385
11-11-2018, 08:21 PM | #178 | ||
Rep 227
Drives: 2000 BMW E39 M5
2017 BMW 330i Sport Wagon - M-sport, EBII, THP, DHP
Supersprint cat-back exhaust (resonated, dual outlet) - H&R rear sway bar - ER charge pipe Waiting for: Bootmod3 - xHP Flashtool - xDelete |
11-11-2018, 10:04 PM | #179 | |||
Rep 1,934
The adjustment knobs I mentioned on the Bilsteins are for dampening/rebound adjustment. Bilstein knobs change both simultaneously, Kw v2/3 is the same (rears require removal of the shock from the car), and both offerings of Clubsport give you separate adjustments for both rebound and dampening. Clubsports are for hard core racing and they're $$$$.
12-02-2018, 08:43 AM | #180 | |
Rep 535
They are also holding their appearance very well.
'17 C7 Vette GS (bye) / '15 F31 328 ix (sold) / '08 E92 335i (sold)/ '08 E92 M3 (RIP)/'01 M5 (sold, sniff)/'07 M5 (sold)/ '15 M5
12-09-2018, 02:18 PM | #182 |
Rep 8,499
I think he means adjusting the damper resistance 2-3 times a year, not the ride height.
02-04-2019, 10:50 AM | #183 |
Rep 385
what's a recommended lube or whatever for the threads to adjust height? asking because i want to prevent it from seizing and not able to adjust later down the road.
02-05-2019, 08:17 PM | #184 |
Rep 1,934
Boeshield T9. Get it on Amazon, or online. It's a sprayable parrafin that dries to a film. I've used it on several coilovers through several NE winters with salt.
Mkswoosh92.50 |
02-10-2019, 07:25 PM | #185 |
Rep 254
02-13-2019, 01:35 PM | #186 |
Modder of everything I own
147
Rep 491
Update on my CATuned coilovers. I've been driving on them since June 2018, I did soften them a bit, from 20/30 to 15/30 for the winter. Still really quiet. My son's 2014 EVO coilovers make a hell of a lot of noise even with everything tight so I'm really happy with my CATuned coilovers compared to his.
This is where I'm at with my summer wheels/tires, although I have my winter wheels/tires on now.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
02-13-2019, 01:37 PM | #187 |
147
Rep 491
I used this as well, I raised my car a bit for winter and had no issues. T9 works great!
04-10-2020, 11:42 PM | #189 |
Rep 14
04-11-2020, 03:21 AM | #190 | |
Rep 681
2016 328ix F31 - SOLD!
2006 997.1 C4S |
alohasurftoad3079.50 |
04-11-2020, 04:15 PM | #191 |
Rep 14
Just want performance right now don't care for looks at the moment. Also will these help with the pitch of the car? Speeding up and braking.
04-15-2020, 12:40 PM | #192 |
Rep 3,540
Dampers control the rate of weight shift, so you should notice a difference with brake dive and squat, and control that a bit since the damping is adjustable.
nadefade10.50 |
08-25-2020, 10:16 PM | #196 | |
Rep 40
11-06-2020, 02:55 PM | #198 |
Rep 216
The KW HLS coilovers are finally available for the f30 340i xdrive! Anyone run these in a different car? If so how were they and what coil level can they be compared to the V1, 2, or 3?
https://www.kwsuspensions.com/produc...-19299299.html |
