      03-21-2013, 07:19 PM   #2993
the_jaguar
Drives: F30 328i
Folks,
I am new to BMW coding (but not to the world of coding/programming in general). I am looking to code a few options on my 2012 F30 328i Sports line with Premium, Tech, Xenon lights with BMW Assist and Advanced Bluetooth, etc.
I would really appreciate your help with a few questions I have:
1] Cable - are the places listed in the OP still the best sources for buying the cable?
2] Software - I use a Mac, so I am looking for a place where I can download the software and the relevant data files.
Couple of things that I am hoping to code eventually: get ipod out using the USB cable, video in motion, possibly enabling BMW live (do I need the BMW Convenience plan to enable Live?)
Thanks in advance
      03-21-2013, 07:38 PM   #2994
Frogman
Drives: 2012 F30 328i
Originally Posted by the_jaguar View Post
Folks,
Thanks in advance
Pre-made cable are available from April1. See http://www.f30post.com/forums/showpo...postcount=2967 or you can make your own with a J1962M cable (try Amazon). The cable connects via Ethernet, not USB.
Software is PC only, so you will need to run it under Parallels or something similar. Checkout the more technical bimmerpost coding forums for details and pitfalls.
I don't think you'll get iPod out without the cradle and I think enabling BMW live will disable BMW Assist. I'm sure others will correct me if I'm wrong.
At least DVD in motion is easy to do!
      03-21-2013, 07:41 PM   #2995
kromix
kromix's Avatar
Drives: '16 340i AW MSport
2016 340i (F30)  [0.00]
Frogman is this the right thing? http://www.amazon.com/OBDII-Splitter...eywords=J1962M or this better? http://www.amazon.com/OBDII-Cable-J1...eywords=J1962M
      03-21-2013, 07:58 PM   #2996
Frogman
Originally Posted by kromix View Post
No, those are pass-thru cables.
try this: http://www.amazon.com/Cable-J1962M-O...eywords=J1962M
or this:
I got the 10 footer and made my own cable with 1/2 of a grounded Cat-5 patch cable, a 510 ohm resistor and some soldering and shrink tubing.
      03-21-2013, 09:40 PM   #2997
shawnsheridan
shawnsheridan's Avatar
or this:
Or this:
http://enetcables.com/
      03-21-2013, 09:41 PM   #2998
shawnsheridan
Folks,
Thanks in advance
PM sent.
      03-21-2013, 09:51 PM   #2999
kon
Singapore
Drives: F30 310i > G20 310i
Is there any way to VO code without actually writing the FA to the vehicle?
I tried this morning removing certain VO from the vehicle, intentionally skipped the step to write FA to vehicle, proceeded to code Combox & CIC which worked ok, but the specific option code that i remove also got deleted from the FA
      03-21-2013, 09:54 PM   #3000
shawnsheridan
Yes. Just save FA, exit FA Editor, and from the Coding module, load the modified FA, activate it, and VO Code ECU(s).
      03-21-2013, 10:09 PM   #3001
shawnsheridan
Originally Posted by avgor123 View Post
I changed only 3 drop downs to activ from nicht_activ. The Werte values was changed automatically.
I would reset the ECU (VO Code) and try it again from scratch. It should work just with those 3 codes, and by changing only the drop-downs.
      03-21-2013, 10:12 PM   #3002
shawnsheridan
Originally Posted by Aritaurus View Post
Thanks Frogman. I checked the logs and this is the file that I need cafd_00000794-002_020_029; so if I have this file, I can just copy it over to my existing CAFDs and it will work?
Is there a way to find a list of all the orphaned files in case it asks me for more?
PM sent for cafd_00000794.caf.002_020_029.
      03-22-2013, 01:07 AM   #3003
kon
Singapore
Yes. Just save FA, exit FA Editor, and from the Coding module, load the modified FA, activate it, and VO Code ECU(s),.
How to "exit FA editor"? Close eSys?
Should I therefore => Read FA > edit & save FA > "how to exit FA?" > load FA > activate FA > code ECU.
      03-22-2013, 04:14 AM   #3004
cedchung
Mauritius
64
Drives: 2011 F25, 2014 F30
I tried changing 6NH to 6NK today and got this error when I coded HU_ENTRY
Transaktions-Report: Aktion: Codieren
HU_ENTRY [63]
cdDeploy ProcessedWithError
cafd_000000f9-007_003_024 ProcessedWithError
The head unit would not go past the BMW splash screen. I changed the VO back to 6NH, recoded and it was working again.
What am I doing wrong?
      03-22-2013, 08:15 AM   #3005
shawnsheridan
By Exit, I meant only to save the FA, then click on the Coding module. From there, make sure the modified FA is loaded and active, then VO Code the ECU.
      03-22-2013, 08:19 AM   #3006
shawnsheridan
HU_ENTRY [63]
What E-Sys and PSdZData versions are you using, and are you able to do any FDL Coding without getting an error?
Beyond that, I am not sure a Basic Head Unit can support 6NK. I think you need HU_CIC and CMB_MEDIA (Combox) to switch from 6NH to 6NK.
      03-22-2013, 08:30 AM   #3007
kon
Singapore
thanks, I'll try reloading the saved FA from my PC then.
I move from FA editor to Coding, and esys prompted to reload the FA, which I click yes, and I saw the file pre-loaded in the Coding screen, and seeing that the option i want to get rid off is no longer there, so i proceeded to code, which went well.
Just don't understand why the vehicle FA was updated as well since I didn't write the modified FA back to the car
      03-22-2013, 10:05 AM   #3008
cedchung
Mauritius
64
3.22.5 and 48.3
Yes I have coded everything without getting an error. I guess the only reason is HU_ENTRY not supporting 6NK
      03-22-2013, 11:12 AM   #3009
Puri1
Puri1's Avatar
Drives: F30 328i 2012
No luck. Default is DRL_S, I changed it to TRL_S and that didn't change anything. Haven't tried DRL_HI or DRL_LO yet but I think DRL_HI will make the angel eyes extra bright in daylight; I need to try and find out.
Please keep us updated... thanks bud
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
      03-22-2013, 12:05 PM   #3010
kitster
Drives: G31 M Sport
Hi, I'm just getting the software all setup up, I've just confused on the psdzdata files:
The psdzdata.7z.001, psdzdata.7z.002..... do I need to combine these 7z files or form a massive file or do I leave them in their current form? Or unpack them separately before moving them in the C:\ESysData\psdzdata\
Thanks.
      03-22-2013, 12:18 PM   #3011
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Thanks.
unzip the 20gb and move to the directory
M Sport Line Estoril Blue
      03-22-2013, 01:33 PM   #3012
kitster
Drives: G31 M Sport
All I got were lots of psdzdata.7z.001.....etc files. Should I just copy these over?
Also the next part says "Copy the contents of the "C:\ESysData\psdzdata\swe" folder into the "C:\ESysData\SWE" folder." I don't seem to have this folder C:\ESysData\psdzdata\swe.
      03-22-2013, 01:37 PM   #3013
shawnsheridan
No. You need to open Part 1 (psdzdata.7z.001) with 7-Zip, and then extract the psdzdata folder out of the archive.
You can ignore that second step. Nothing is needed in the C:\ESysData\SWE folder, and doing so will only waste 20 gb of HD space.
      03-22-2013, 03:20 PM   #3014
kitster
Drives: G31 M Sport
Thanks a million. Unzipped and ready to go
