09-16-2014, 01:25 PM | #67 |
Rep 1,252
i just received mine and took in a shop, front needs alot of work also rear , will not take less than 7-8 hours for both :S
im getting charged for like 500$ but i talked to him and got it down to ~400$ cuz really its not an easy job.
Docrace 6266
09-17-2014, 05:44 AM | #69 |
Rep 1,252
my cousin has a good relation with automotive markets and he ordered it for me from US, not sure from which vendor, if you wish you can hit him in IG:Instaperformance
Docrace 6266
09-17-2014, 05:56 AM | #70 |
Rep 1,252
i have found this
http://www.vividracing.com/catalog/2...448-8--28.html
Docrace 6266
09-17-2014, 08:09 AM | #71 |
Rep 704
Drives: 2014 328d
I got mine from Turner Motorsport in Massachusetts.
2014 328d SportLine
09-17-2014, 02:40 PM | #72 |
Rep 1,436
Question guys, which one will be more beneficial.
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
09-17-2014, 09:06 PM | #73 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
You mean between front and rear sway bars? If I had to choose, I would absolutely go with RSBs...
09-17-2014, 09:10 PM | #74 |
Rep 704
Drives: 2014 328d
x2. Although I have fsb & rsb on my E30 and it rides really well. But it's an old(er) car.
2014 328d SportLine
09-18-2014, 09:54 AM | #75 |
Rep 1,436
Thanks
09-20-2014, 07:48 PM | #76 |
Rep 1,397
09-20-2014, 08:06 PM | #77 |
Rep 5,803
how noticeable would the difference be on a stock msport with passive suspension?
F30 330i Alpine white/Coral red Msport 6MT
09-20-2014, 09:54 PM | #78 |
Rep 704
Drives: 2014 328d
Yes, you need to call them. They don't have it in stock yet so it's not on their website. They can order it for you from H&R. I haven't seen the invoice yet because they have to receive it from H&R and then ship it to me, but I think the cost was ~$330 or so. I should see the invoice this week sometime.
2014 328d SportLine
09-20-2014, 09:57 PM | #79 |
Rep 704
Drives: 2014 328d
It would be approximately as noticeable as if you had DHP in Sport--which is to say, you most probably will feel like you got your money's worth.
2014 328d SportLine
09-21-2014, 03:30 AM | #80 |
Rep 1,397
This may sound like a total noob question but...
If i get the H&R sways will i still be able to install coils afterwards using these sways? or do coils require different sway bars? Reason i ask is cause i have never seen the need to switch sways before the the f30 is too "floaty" for my liking. that and my buddies BRZ required new sways when he install coils. |
09-22-2014, 09:14 PM | #81 |
Rep 8
I was just looking at these on Turner's site the other day. I had front and rear H&R's on my stage 2 MKVI GTI and the difference was incredible. Coming from that, my 335 basically feels fat and sloshy.
I've actually never owned an AWD before though, so I'm curious how the xDrive responds to a stiffer front and rear. Anyone have any insight? |
09-23-2014, 09:19 AM | #82 | |
Rep 764
What the bars are intended for is to reduce roll during cornering. Someone please do correct me if I am wrong. |
09-23-2014, 04:08 PM | #83 | |
Rep 1,397
car moves too much around turns. |
09-25-2014, 10:24 AM | #84 |
Rep 704
Drives: 2014 328d
FYI--I have just confirmed with Turner Motorsport that the 328i H&R rsb is now also on the 328d fitment list.
2014 328d SportLine
10-02-2014, 11:11 AM | #85 |
Rep 1,397
I received mine today
i also check ista and it does not seem like its a lot of work to swap these. i'll attempt to install them tonight and write up a diy |
10-05-2014, 07:17 PM | #86 |
BMW CCA #257
75
Rep 190
Has anyone tried H&R's bigger Sway Bars on a 328 xDrive sedan or wagon? I am particularly interested in the difference in handling with the stock xDrive suspension.
Thanks in advance ...... |
10-25-2014, 01:57 PM | #87 |
Rep 114
For those who got it installed,
how is the handling? Do you guys think that the upgrade would be worth it with Kw v2 coilovers and camber plates already installed? Thanks |
10-25-2014, 05:23 PM | #88 |
Rep 1,436
did you get bolts with rear sway bars or only bushings ?!
