BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Chassis reinforcement plate (from CPM Japan)
Studio RSR
      10-01-2016, 04:59 PM   #67
wakdady
Drives: i3
I see a brace over a brace. does it really make a difference?
I would think if there was no prior brace, sure. but in this case...
      10-01-2016, 07:41 PM   #68
MSportTune2
Aland Islands
80
Drives: F30 MSport
I went from stock to CPM then to F32 braze.
The improvement for me is mainly how it handles and corners. From stock to CPM, there is improvement in handling.
However, you do feel it more when the roads are bad. When I went to F32 braze, the quantum improvement in handling is more compared to CPM but road imperfections is even more pronounce.
So in a nutshell, if your daily drive is through a lot of twisty and turns, you will like the mod a lot. If you drive daily through bad roads, you will kind of dread it a little though it is not extremely uncomfortable.
I recently changed my absorbers to B6s and most of what I dread about the stock MSport suspension is fix by it so IMHO save your $ and go Bilstein first then if you are still not satisfied and hv extra $, then try the F32 braze?
Others who have tried, pls feedback. I am just sharing my personal perspective.
Cheers!
      10-15-2016, 11:28 AM   #69
flwbyu
flwbyu's Avatar
Drives: 2014 BMW 335i M Sport 6MT
I am planning on doing this mod myself. I have found that lower strut braces in concert with upper rear and front braces makes a huge difference. It keeps the car more planted IMO. I also noticed that AutoTecknic has a lower strut brace –
http://www.autotecknic.com/product-p/bm-0404.htm
I'm not affiliated with them or any such thing. I was just looking for a strut tower braces and came across the lower brace while searching. Great thread.
      10-15-2016, 12:07 PM   #70
flwbyu
flwbyu's Avatar
Just wanted to say thanks to 'glennQNYC' for listing the part numbers for this mod –
Genuine BMW Tension Strut – 33316797444 (1 QTY)
https://www.turnermotorsport.com/p-1...uine-bmw-part/
Genuine BMW Push Rod Left – 33326793651 (1 QTY)
Genuine BMW Push Rod Right – 33326793652 (1 QTY)
Genuine BMW Torx Bolt – 33306861221 (2 QTY)
      10-17-2016, 09:27 AM   #71
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
That was me post # 38 on here - using M3/M4 alloy brace as spacer - to increase the rigidity mid chassis - and then attach the main rearward brace tie down the rear subframe to the chassis - cheap by comparison to CPM and autotechnik as oem F8x alloy plate is <$30 including longer bolts !!!
Current '22 X3M LCI..
      10-17-2016, 09:32 AM   #72
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
save yourself $150 and just buy oem F8X alloy cross plate - does the same job for <$30 !!!
Part no.s from realoem
1 off 33312284647 "CONNECTING SUPPORT"
6 off 07119907189 "Star-socket screw - BM8X25-8.8-ZNS3"
      10-19-2016, 09:43 AM   #73
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Direct bolt on???
SOLD: 2012 335i Mineral Gray
      10-20-2016, 03:13 AM   #74
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Originally Posted by shivaswrath View Post
Direct bolt on???
Yes
      10-20-2016, 08:19 AM   #75
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
You think both braces stacked on top of one another appreciably improve rigidity compared to just the F32 piece?
      10-20-2016, 08:58 AM   #76
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
For me - its 30 bucks well spent...as I was fitting the under floor brace any way.
      10-25-2016, 06:10 AM   #77
Lancelot
France
568
Drives: 2017 m550i
Hi
Did anyone try to use the f80 V-braces as well? Ref 33302284645 / 33302284646 - we ordered them together with the plate thinking it would fit, we haven't actually tried yet but would like your opinion - are we wasting our time and should I use the F30 plate + links as above?
      11-17-2016, 05:46 AM   #78
cesare87
Drives: 435i
Originally Posted by Lancelot View Post
Hi
Also curious to know if the f80 v braces would fit.
      11-17-2016, 06:07 AM   #79
Lancelot
France
568
Drives: 2017 m550i
We tried, they absolutely don't
Completely specific to the f80 subframe
      11-18-2016, 07:25 AM   #80
cesare87
Drives: 435i
Ah shame. Picking up my f80 reinforcement plate today
      11-20-2016, 04:14 PM   #81
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Just a quick question, which parts do F32 owners buy? Just the reinforcement plate off the M4 + longer or anything else?
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      11-21-2016, 12:14 PM   #82
Lancelot
France
568
Drives: 2017 m550i
Just the plate, you're supposed to have the V brace from factory
Apparently BMW think sedan drivers like their chassis soft
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i
      11-21-2016, 05:20 PM   #83
Smee
Smee's Avatar
505
Drives: BMW M4 F83
bought the m4 plate today plate was £15 the 6 longer screws £25 lol
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit
      11-27-2016, 07:44 PM   #84
kevinjt
kevinjt's Avatar
152
Drives: 335i M-Sport 14'
Bought the parts! Any special instructiona to install the f32 v brace + the m3 brace (as spacer) on a F30?
      11-28-2016, 04:06 AM   #85
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Yes - use ramps as opposed to jacking the car up so as you keep weight on the rear wheels when removing rear subframe bolts to install cross brace rear attachment points.
kevinjt151.50
      11-28-2016, 04:08 AM   #86
Smee
Smee's Avatar
505
Drives: BMW M4 F83
What torque do I tighten then up to?
The bolts I got from bmw are Alan key type not the star type on this picture is that normal
kevinjt151.50
      11-28-2016, 04:30 AM   #87
kevinjt
kevinjt's Avatar
152
Thanks for the info!, Can i just unbolt them without any problems? I mean, is there any part that might come out of place if i unbolt those ?
I have my ramps ready!
By the way getbmwparts.com is having a Free shipping offer until today.
Thanks again!
      11-28-2016, 05:08 AM   #88
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Thanks again!
Yes no problem to unbolt the forward rear subframe bolts provided weight is still on the wheels.
If car is jacked up and or on axle stands such that weight is off the wheels, you may get slight movement of subframe when taking bolts out that could make re-installing these bolts more of a challenge.
kevinjt151.50
