07-17-2015, 10:28 AM | #45 |
Rep 66
I am on Dinan springs and B8's. I travel through a road construction area every day and of course it is a very rough ride. But you need to think about this - this combo is stiffer that the stock suspension. BMW provided a pressure value for the tires based on their suspension. To get rid of the roughness and to avoid further damages you need to dial down the tires' pressure to where you feel the ride is smooth again on rough roads. I did it and I can tell you that I cannot feel the pot holes and the bumps anymore, and also there is no body roll.
07-17-2015, 10:50 AM | #46 |
F30 -> F80 Conversion
69
Rep 217
Old thread, but the same part got busted when I hit a pothole with 20" wheels. I am on Bilstein's as well and drove home for around 3-4 miles. Made a funny 'clack clack' sound but couldn't damage it any further so I thought what the hell and just took the risk and drove it back home.
07-17-2015, 12:46 PM | #47 | |
Rep 3,947
Why would this be an issue with the H&R +Bilstein setup but not the M Performance Suspension? |
07-17-2015, 03:10 PM | #49 |
Rep 3,947
So basically, you're 4psi below the minimum recommended pressure.
Aren't you concerned that you could eventually have a blowout due to under-inflation? http://www.tirerack.com/tires/tirete...e.jsp?techid=1 |
07-17-2015, 04:47 PM | #50 | |
Rep 66
If I were to take a long drive I would still add at least 2 psi. But again, this is based on my experiencing. PS - Let's not forget that the sticker on E9X was showing a rage of pressures for both front and rear, if I am remembering this correctly my 325i was to be set up from 29 to 32 front and 35 to 39 rear. And the suspension on that car was stiffer that any F30 today. I am very close to that right now. Last edited by bbog2008; 07-17-2015 at 04:55 PM.. |
07-30-2015, 05:08 AM | #52 |
Rep 31
09-29-2015, 02:23 AM | #54 |
Rep 31
My service looked at my suspension again more carefully and the conclusion was that these springs do not match with bisltein B8. They are too short (fronts). When mounted they are not compressed at all. Adding to that fact that B8 is pretty stiff we have all body weight being carried by shock absorber, not by spring. I replaced HR springs by eibach pro-kit and the car is fantastic now. I have them for over 4 weeks and shock never compressed to its end hitting hard. And Im concentrating now back on driving, not on searching of holes in the road. I did also one track day and car behaves much better than on H&R. On that setup the car is not as low as used to be on HR but I find is actually as advantage for daily usage.
09-29-2015, 12:31 PM | #55 | |
Rep 66
09-29-2015, 06:39 PM | #56 | |
Rep 1,029
Drives: 2019 440xi Gran Coupe
I do know that the rears are the same for RWD and AWD but its the front that is different. |
09-29-2015, 07:13 PM | #57 | |
Rep 74
2014 435i xDrive MSport / Black Sapphire Metallic / Black Dakota Leather / MPPK / 6MT / 19" / M Sport Brakes / DINAN Springs / Bilstein B8 / Technology Package / Premium Package / Cold Weather Package / Driver Assist / HK Sound
10-01-2015, 01:34 AM | #59 |
Rep 74
Do you know of any good ones that work with stock suspension, or in my case, DINAN springs with Bilstein B8s (which I am told is same as stock when considering camber plates)?
10-09-2015, 08:50 AM | #60 |
Rep 31
In order: Eibach + bilstein B8 przod_resize.jpg (125.4 KB) Eibach + bilstein B8 tyl_resize.jpg (156.3 KB) HR + Bilstein B8 przod_resize.jpg (137.7 KB) HR + Bilstein B8 tyl_resize.jpg (136.7 KB) OEM przod_resize.jpg (134.4 KB) OEM tył_resize.jpg (108.7 KB) "Przod" means front, "Tyl" is rear. Last edited by Darekme; 10-09-2015 at 09:01 AM.. |
10-09-2015, 08:57 AM | #61 |
Rep 31
My car is xdrive. Ebiach has springs dedicated for xdirve. In my case (335ix) the part number is E10-20-031-06-22. In Europe they are half price of H&R. Eibach has different springs for 2 and 3 litre engines because their weight makes big difference.
11-19-2015, 11:42 AM | #62 |
Rep 3,947
11-23-2015, 08:24 AM | #65 | |
Rep 3,947
11-23-2015, 03:12 PM | #66 |
Rep 4,635
similar thing happened to me but mine happened from turning in too early and hitting the apex hard at the track. I ordered adjustable tc kline camber plates to fix the issue instead of replacing with oem
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
