BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F3x brake rotor/disc & pad replacement guide
      09-26-2021, 10:37 AM   #89
Nijenego
Croatia
Drives: BMW F30 2014 318d
Excellent guide! Thank you!
      04-15-2022, 04:47 PM   #90
mode.grau
mode.grau's Avatar
Drives: 17 340 M-Perf Ed. Fashion Grey
Retaining Pin Stuck!
Great write up and discussion here, thanks everyone.
I've run into a road block trying to do my brakes. My 2 fronts were absolutely no problem at all, everything went smooth. When it came to the first rear (rear right), the 2 pad retaining pins were absolutely impossible.
I did have a proper punch tool which worked just fine for the fronts, but on the rears I could not get them to budge. I tried everything I know/am capable of: hammering harder, WD40, hammering the pins directly, wiggling the pads so I know they're not binding to the pin, etc. I even removed the rotor by removing the caliper then bolted it back on for easier workability. I tried to clear up whatever gunk I could find on the pins. NO LUCK.
It got to a point where both my punch tool and the pins have now flattened out due to the amount of hammering I've done. The caliper's paint is completely f---ed as I stopped caring and decided I'll have to repaint it anyway. I had to abandon the project for this week as my body is aching and I've run out of the energy to figure it out.
I'm going to buy a replacement hardware kit and try to drill out these existing pins. If anyone has ANY feedback or tips to help out, it'd be much appreciated.
Aside: these are the original pads and the car has 67,000 kms on it. Still surprised that the fronts were no issue but the rears are causing me such a headache. Also, yes I had jack-stands as well.
2017 340i M-Performance Edition (ZE0) - Individual Fashion Grey // Extended Black Merino Leather - xDr 8AT - THP - MPPSK
Previous Cars:
2017 340i xDrive 8AT
2019 Golf R 6MT
      04-15-2022, 06:10 PM   #91
CanadianHorseMan
CanadianHorseMan's Avatar
Drives: 2019 440i Gran Coupé
Oh shiiite. lol. Not pretty. I however had the same issue as you. Fronts prolly took me a max of 20 minutes. My rears calipers, pads, rotors (I did the whole job) took about 2 hours. Getting the caliper retaining bolts out took forever; I thought they were gonna snap off they were so hard to get out (due to the scotch lock crap on them). Pad retaining pins took A LOT of small/ and brisk taps to get out. I have 2 marks (one on each side) and I was quite sad
But yours are clearly depressing. I have no tips except maybe spray some wd on there or pbblaster and walk away for a day/night and try to tap them out the next day.
They’re stainless but I believe the spring/expanding washer thing is not very resistant to rust and that’s what’s stopping it from coming out.
I would recommend before you go back out there to work on it to go get some new pins.
I don’t get why we don’t slather on the brake grease or anti-seize on these pins, especially on the washer/spring part of the pin but the manual says not to do I didn’t do it.
Anyhow, good luck. Maybe it’ll buff out?
      04-18-2022, 10:39 AM   #92
Itogliano
Itogliano's Avatar
Drives: 2015 F36 435i
I think most pads will come with new pins, my StopTechs did, at least.
I would also suggest trying to loosen/break free the retaining spring and try hitting the pins with some penetrating oil and letting it sit overnight. If they are seized due to rust (which it looks like is the case), I would also try consistent rapid taps on the punch/pins instead of single hard blows. The vibrations can help break the rust free
      04-18-2022, 10:52 AM   #93
BeFitty8_F32
Melbourne Red F32 B58
BeFitty8_F32's Avatar
Drives: 2017 440ixm
Good to know about StopTechs. EBC Reds did not come with the pins.
Real drivers use 3 pedals. Its about connection.
      04-18-2022, 10:53 AM   #94
Itogliano
Itogliano's Avatar
That is also good to know. Yeah the StopTechs (sports) came with both new pins and retaining springs
      05-14-2022, 06:11 PM   #95
GeordieRacer84
Drives: BMW F30
Originally Posted by fortythirtyfive View Post
My Zimmermann discs are currently suspect of some horrid noise. I feel the garage I used messed up during installation.
https://streamable.com/hr3ph
At first the brake shield was suspect but I've leveraged that away with full clearance, so now I'm thinking of refitting the disc. Last time I attempted (before getting the garage to do it for me) I couldn't shift the two bolts holding the caliper in.. what tool did you use? My breaker bar is around 2 1/2 ft long so it won't really clear the wheel arch
Hi There, what was the issue in the end? I think i have the same problem, First BMW, 2013 330d. Loving it but having some niggles!. Getting the rubbing noise as if the disc is not rotating true. gets worse when turning and goes away when apply bit of brake.
TIA
      05-15-2022, 02:08 PM   #96
fortythirtyfive
Drives: 435i MS
TIA
For me it was purely just the addition of slotted and dimpled rotors, the air gets trapped in them causing the sound. I believe fully drilled rotors aren't as bad but do have some what of a sound
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru)
      12-21-2022, 10:02 AM   #97
jrbeckie
Drives: BMW F32 (435i with xdrive)
THANK YOU Daggers!! Will be doing this in the upcoming month and your guide is most helpful, even with little tips along the way
