11-19-2022, 06:55 PM | #89 | |
Rep 1,148
I'm about to order everything I need for this, I was wondering about that because I had the same worry of such little engagement I am almost at the point of swapping an f80 front subframe in, I just wish I knew if my steering rack would work/mount up to that subframe as they are different part numbers. Do we know if it's the subframe or hubs that cause the wheels to sit forward? I'm really getting curious as subframes are not very expensive and I've pulled them before… |
11-19-2022, 09:08 PM | #90 |
Rep 27
Yes, you can't buy them separate, they're sold together as 1 piece. I added links to the parts in my last post. I don't think it makes sense to run the LCAs without the appropriate tie rods.
Wy do all that work? Seems like the cost/benefit isn't worth it. Even if you're tracking the car, there are other ways to manipulate and dial-in the suspension. Afaik the hubs are different. I've read a few threads that discussed this briefly. |
Pussiwillow521.00 |
11-19-2022, 10:04 PM | #91 | |
Rep 1,148
11-20-2022, 04:01 AM | #92 | |
Rep 1,004
11-20-2022, 09:39 AM | #93 | ||
Rep 1,148
I want to keep the f30 hubs lol, but I would be doing f80 ts, control arms, and tie rods, really curious… I may call around this upcoming week or 2 |
11-20-2022, 10:09 AM | #94 |
Rep 5,457
Drives: F30
F80 arms on the F30 has proven to be a disastrous and foolish idea. That video should be deleted for promoting something harmful for the sole purpose of selling auto parts.
alohasurftoad3081.50 |
11-20-2022, 10:16 AM | #95 | |
Rep 5,392
For RWD F3x: https://www.kiesmotorsports.com/prod...8;_ss=r?aff=22 For XDRIVE F3x: https://www.kiesmotorsports.com/prod...8;_ss=r?aff=22 |
11-20-2022, 12:47 PM | #96 |
Rep 1,148
We'll I got a lead on a frame and asking if they can measure the mounting lay out so I can compare, if it matches I may go for science here and send it, would be amazing if it centers the wheel, I'm not going to replace hubs if it doesn't, it's not cost affective but 400$ for a frame I can handle that. I know they mount up to the chassis, but ya, I'll report back
11-21-2022, 10:32 PM | #97 |
Rep 27
Can you elaborate? I'm assuming you're only talking about this retrofit on xdrive cars and not rwd. There are a lot of cars running these in the F3x and F2x chassis including myself with no issues.
11-21-2022, 10:39 PM | #98 | |
Rep 27
There's a reason why the M cars handle better than the F30. Adding monoballs will definitely make the steering feel and turn in better but it won't add the negative camber that the LCAs will in order to increase handling performance. You can do adjustable control arms and camber plates but why would you when you can take the F8x components? |
mike082802114.00 E60F3030.00 |
11-24-2022, 06:41 AM | #99 | |
Rep 8
Sorry for the noob question, I'm installing camber plates in a few weeks. |
11-24-2022, 09:57 AM | #100 | ||
Rep 1,148
12-04-2022, 11:36 AM | #101 |
Rep 27
No, I wouldn't bother. Camber plates can give you up to -3 degrees which should be sufficient for track applications. I think it would be a waste of money to add the LCA's on top of that. Also, not sure if they would even provide additional camber.
12-05-2022, 07:33 PM | #102 | |
Rep 891
I personally have had a pretty good experience with mine, but I had far fewer options available at a reasonable price at the time. There are better options these days as others are saying. Many are cheaper.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
12-05-2022, 08:46 PM | #103 |
Rep 1,127
I have been using the F80 lower arms up front for a year now at the track. They require an alignment and a F30 bushing. I would not drive your car any more than on to the back of a trailer or tow truck until aligned.
https://www.bimmerworld.com/F8X-Fron...Assembled.html I think I could hit -4* of camber with that kit and GC camber plates, but I typically do -2.5 to -2.75. |
12-05-2022, 10:44 PM | #104 |
Rep 1,148
Those that have done the f80 arms with camber plates, how has the positive castor and geometry benefited the chassis?
I'm debating this upgrade, but can achieve my camber desired with plates like you guys could, but I like to hear the feedback on the other parts of the mod. |
12-09-2022, 08:45 AM | #105 | |
Rep 8,500
In terms of suspension the car runs Millway camber plates, F3X tension struts with SuperPro poly bushes, Ohlins R&T (lowered, in layman's terms, to 'one finger'), Eibach anti roll bars, OEM 403M rims with Michelin Pilot Sport 4S 235/4019 F and 265/35/19 R, and 12mm spacers all round. F80 wishbones pushed the wheel hub centre forwards in the wheel well causing significant rubbing under compression and especially with any steering angle applied. Even with the camber plates set to full positive the camber was -2.5. For road driving I find that around -1.75 is a good compromise between better turn-in and reasonably tyre life on the inner shoulders. The track control rods couldn't even be reconnected unless they were wound out a very long way. Although not enough to be dangerous, the shop did mention that it had to do a very unusual/large amount of adjustment to be able to reconnect the track rod ends. I had to remove the front spacers straight away, which left the wheels significantly 'tucked' - this is not a look that appeals to me. I had the shop install BMW OEM wishbones (rubber bushes) as a temporary solution until Millway F3X arms with sealed hyme bushes were delivered. The Millway units have been on the car for several months now, with no problems. My preferred geo was, of course, easy for the shop to re-establish. Although I (kind of) admire your bravery in terms of an F30/F80 subframe swap my main reactions are "why ?" and "don't !".
Polo088161610.00 |
12-09-2022, 11:43 AM | #106 | |
Rep 1,148
12-13-2022, 05:47 AM | #107 | |
Rep 25
I really appreciate your input, I'm searching for the tie rods right now. I want to be 100% sure on this, so the F80 rods are longer ONLY in the inner side? Like the one in this picture? Is the outer part longer too? Thx! Last edited by WallaceK; 12-15-2022 at 03:44 AM.. |
12-17-2022, 03:37 PM | #108 | ||
Rep 8
Maybe i should consider mount the F8x inner rods too Quote:
----------------------------------------------------------------------------------------------- Does anybody can confirm that is it the correct inner rod for F80 ? According to Lemforder (ZF), i can find a part number for F30/F31 with 253mm, and this part number (see picture) but the length is not mentioned. Last edited by yabx172; 12-17-2022 at 03:52 PM.. |
12-25-2022, 07:20 PM | #109 | ||
Rep 25
Apparently the F80 Inner Rod has a length of 291.4mm. I also found this link for the F30 to compare: https://cars245.com/en/item/swag-209...od-axle-joint/ This has the same length that you mentioned (252.5 mm), but is pretty weird that it also mentions the length of 269mm. Quote:
Maybe I'm overthinking it too much, but I will probably give a shot to the F80 inner rods. I really wanted to know if the outer part is also longer, since I could find the parts being sold separately. |
06-04-2023, 03:02 PM | #110 |
Rep 25
I almost forgot to comment about the process after I finished this mod. I won't focus so much into my opinion about the difference in the steering feeling since there is millions of posts and youtube videos about it. The only thing I want to say is that I absolute love it and it gives me a lot more confidence when going around corners with no NVH added.
Instead, I want to focus into some interesting information that I was able to confirm when going through this process: 1) I highly recommend doing the tie rods and personally, I wouldn't go LCA without them, since you be probably maxing out the thread with the F30 stock ones. This was a big issue for me since I like to run with zero'ed toes. Also, I was able to buy ONLY THE INNER RODS from the F80. 2) The length of the F30 inner tie rods are 269mm. The length of the F80 inner tie rods are 291.4mm. 3) You DO NOT NECESSARILY NEED the M3 headlight control rod to have the ball joint added to your stock rod. Personally, I saved some money by buying the part number 2203200389 from aliexpress, although this number wont match with anything on realoem, by the pictures I was pretty confident that it would fit, as it did. They also mention the numbers 37146776549 /221320248. The number 37146776549 matches with some X5/X6 bmws. I could have saved a little bit more by just buying the ball joint from some hardware/car part store. I found one from a mercedes that I was almost sure it would fit too, but since I was in a hurry I prefered to buy the aliexpress one since the other option would take a bit longer to arrive and wasn't so much guaranteed that it would fit. In case someone wants to grab a ball joint from another source, here are some pics with measures that I took, I hope this helps! Finally, a picture of the end result: |
FrankDK171.50 mike082802114.00 |
