06-29-2021, 01:07 PM | #221 |
Car Hypochondriac
335
Rep 901
Those with millway street plates, how are they so far? I find myself in need of more front camber but I don't want to compromise my ride comfort any more. Starting to toe the line on being too rough for a daily.
06-29-2021, 08:27 PM | #222 | |
Rep 1,370
My only question would be is there a way to somehow affix some sort of sound ablation material to the strut tower covers to help cut the added noise a bit??
07-02-2021, 07:27 AM | #223 |
Rep 216
Why not take a thin sheet of dense rubber, and cut it to size to fit where the camber plate touches the car. should provide a little sound protection and not cause any issues
07-02-2021, 09:11 AM | #224 | |
Rep 1,934
Some of us get M4 strut tower bolts to account for the ~5mm height of a strut tower bar. So those may be an option if you add this rubber gasket.
07-02-2021, 10:43 AM | #225 | |
Rep 1,370
Be great if there was a way to make a cast of the assembly and build a mold from that. Just thinking how many ways that idea could go awry.
07-02-2021, 10:51 AM | #226 |
Rep 1,370
After doing my Millways, I am curious if there would be an issue if the alignment tech torqued the bolts to the wrong amount of torque and in the wrong order. I haven't noticed a problem but I'm pretty sure he just torqued the bolts to a value just short of welding the bolts in place and in any order he chose.
07-08-2021, 08:27 PM | #227 |
Rep 1,370
Is anyone using their Millways camber plates with KW StreetComfort Coilovers? I've heard that the KWs only work with the OE top hats. Reached out to Millway a couple of days ago but no answer yet.
07-08-2021, 10:11 PM | #228 |
Rep 1,934
It can be used with oe type springs (of wish the KW are), or 60 mm ID springs (aka afrermarket springs/coilovers).
07-08-2021, 11:17 PM | #229 | |
Rep 1,370
If I end up going lowering springs with struts I promise not to throw off magnetic north. Really.
07-15-2021, 10:52 AM | #230 | |
Rep 891
I am really quite impressed. For those considering the Street option over the standard monoballs, do not hesitate. Edit: I checked Millway's site today and it looks like all of their camber plates are getting updated to a new version at the end of August... kinda wished I waited to see what exactly was changed.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 07-15-2021 at 04:17 PM.. |
07-17-2021, 07:27 PM | #231 |
Rep 67
Got mine on as well and really can't tell the difference between the OE top hats in regards to NVH. Very pleased overall, but fomo is definitely setting in now seeing that updated version haha
07-17-2021, 08:10 PM | #232 |
Rep 1,934
What did you pair them with for suspension?
07-17-2021, 08:15 PM | #233 | |
Rep 67
07-18-2021, 08:17 AM | #234 | |
Rep 3,947
07-19-2021, 06:36 AM | #235 |
Cheapskate
4450
Rep 4,993
Mine are still noise free
09-09-2021, 11:23 AM | #236 | |
Rep 79
Anyone have their original top mounts they'd be willing to part with or take some measurements from? I'm a little concerned about where the strut shaft gets located relative to stock- it appears to take some travel out of the shaft which would be exacerbated on a lowered car but I want to be sure and I don't have my car apart yet. If it does end up being a thing, I'd like to get the new top mount I designed machined so I can install that instead of the original millway part since it moves the shaft up about 20mm relative to the original.
The rubber will eventually fail to return to its original thickness when you relieve pressure and the tension you put into the bolts when you torqued them will no longer be there. You would need to use patch bolts or loctite to prevent the bolts backing out, and even then the compression set would begin to allow relative movement of the strut plate to the chassis as time goes on and would likely make more noise than just bolting it solid. |
09-09-2021, 01:26 PM | #237 | ||
Rep 15
Don’t worry guys. I just hate when I buy something and then realized I bought an outdated version. So we shipped out the updated version long time before we announced it. (Around 20 June). So chances is you already have the updated version. So what are the changes? 1. Studs and nuts instead of bolt. 2. Added more preload to the pu-discs from 1mm to 1.5mm. 3. Centre washer got some minor dimension change. So how to check if you have the updated version? 1. You got studs and nuts in the box. 2. Center part is marked 27.8 Let me know if you have any questions. Best Regards |
09-09-2021, 02:25 PM | #238 | |
Rep 3,540
09-09-2021, 06:54 PM | #239 | |
Rep 3,947
09-10-2021, 09:21 PM | #240 | |
Rep 3,189
11-02-2021, 05:38 PM | #241 | |
Car Hypochondriac
335
Rep 901
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
