07-05-2022, 02:08 PM | #46 |
Rep 3,368
07-06-2022, 07:58 AM | #48 |
Rep 3,368
Here you go...he's also on FB. Good dude. Not the cheapest solution, but takes all of the guesswork out of any bits and pieces needed for a full refresh.
https://www.strutmonkey.com/ |
07-23-2022, 12:57 PM | #49 | |
Rep 706
07-23-2022, 02:16 PM | #50 | |
Rep 5,392
What is interesting about the -05 and -06 Eibach spring kits is that the spring rates are identical according to Eibach. So they should ride exactly the same. The rear springs in both kits are identical. The only difference is the length of the front springs in the two kits. I got all of this from the Eibach European springs catalog and several discussions with Eibach tech support. Compared to each other, the front springs in the -05 kit are 15mm (0.6") shorter, so they will drop the front 15mm (0.6") more than the -06 kit. My experience has been that the Eibach drop estimates are pretty accurate. For my 2015 335ix Eibach estimates a Front 0.8" and Rear 0.6" drop with the -06 spring kit. And that's what I got after i installed it. So if I swap the -05 kit in and remove the existing-06 kit, that should provide a total drop from stock of Front 1.3"-1.4" and rear 0.6". It's very important to remember that drop estimates are based on a specific car with its stock suspension and axle weights. If these -05 and -06 spring kits were installed on different car models like 335i RWD. 435i models, or 328i 428i models, then the spring drops would be expected to differ. |
dmanb2b2124.50 |
07-23-2022, 04:48 PM | #51 | ||
Rep 3,368
07-23-2022, 08:19 PM | #52 | |
Rep 706
Do you think a drop of 1.3-1.4” a lot? Since i am seeing a supposedly drop of 35 mm (1.375”) has not even become a 20 mm drop (0.75”) based on dman2 car, i am considering to go for a sportline instead of eibach proline because for my F30, pro line drop is 1” while sportline is 1.5” (38 mm) based on paper.
09-20-2022, 10:45 AM | #53 |
Rep 481
I have 2017 BMW 330xi, want to lower it on Eibach Pro springs and wants to install Koi Special Active, does anyone have complete list of of all items I need including F80 bump stops you are talking about?
09-20-2022, 03:41 PM | #54 | |
Rep 55
x1 set of Eibach Lowering Springs: E10-20-031-05-22 (4x piece) x2 F80 M3 front bump stops (strut bumper): 31-33-6-859-768 x2 F80 M3 rear bump stops (shock protector): 31-33-7-847-662 I am not sure about the specific Part number for the Koni Special Actives though. I am thinking of doing the above change on my 2018 440i GC w/ xDrive and M-Adaptive Suspension. No plans to swap out the shocks at this point yet. Edit: per dmanb2b I had the incorrect part number above for the 330i. Should be the 04-22's Last edited by ravenorxs; 09-20-2022 at 04:11 PM.. |
09-20-2022, 03:58 PM | #55 |
Rep 86
Reading this thread, I'm in the same boat. I have the 06 on my 340xi and I want that gap closed to, not slammed but a good reliable drive. I like the eibachs, but the front is too high still. Hate that reverse rake. I've seen others do rwd eibachs and it works..
09-20-2022, 04:02 PM | #56 | |
Rep 55
In Europe, both -05-22 and -06-22 are for AWD (xDrive). North America catalog only has the -06-22. The true RWD part # is the -02-22. I am not convinced that using this on an xDrive will not damage the car. I think earlier discussion on using the RWD version on xDrive may have been incorrectly tagging the -05 as RWD. (Unless of course people actually are using the -02-22's on xDrive cars, in which case I am wrong) If you have the -06 and wanted a lower drop, I'd check out the -05's first before considering the -02's. |
sdbwisc66.00 |
09-20-2022, 04:04 PM | #57 | |
Rep 3,368
09-20-2022, 04:07 PM | #58 | |
Rep 3,368
sdbwisc66.00 |
09-20-2022, 04:09 PM | #59 |
Rep 55
09-20-2022, 04:10 PM | #60 | |
Rep 86
dmanb2b2124.50 |
09-20-2022, 04:19 PM | #61 | |
Rep 3,368
sdbwisc66.00 alohasurftoad3079.50 |
09-20-2022, 04:32 PM | #62 | |
Rep 86
Thanks! |
dmanb2b2124.50 alohasurftoad3079.50 |
09-21-2022, 07:09 AM | #65 |
Rep 5,392
See photo for part numbers
09-21-2022, 07:16 AM | #66 | ||
Rep 5,392
Tunershop is a retailer that has locations on both continents and often can supply in the US those parts that seem to be available in Europe only. Andreas Schade is also an excellent source. Andreas is a retailer in Germany who is very knowledgeable and ships all over the world. Great guy. FaRKle! originally recommended him to me. His email is: andreas.schade@gmx.de |
