04-28-2018, 08:30 AM | #89 | |
Rep 67
sspade2466.00 |
05-03-2018, 01:21 PM | #90 | |
Rep 1,597
08-13-2018, 10:51 PM | #91 |
Rep 340
i just install the front lower brace bar.. does anyone know the torque spec for those two bolt?
09-08-2018, 11:59 AM | #92 |
Rep 67
09-08-2018, 12:09 PM | #93 |
Rep 67
09-09-2018, 01:07 AM | #94 |
Rep 2,499
What is the point of an aftermarket strut brace when the stock strut brace seems to be made of heavy steel and is probably stronger than any aluminum bar you can get? It also has the advantage of bolting on to the firewall. I'm asking honestly, because I don't exclude the possibility that an additional strut brace might tighten things up even more. I just don't see it making any discernible difference, though.
09-09-2018, 02:43 AM | #95 |
Rep 1,291
First feeling is significantly different and the proof of efficiency is in what you feel.
Handling is more precise and more enjoyable as far as i'm concerned. I retrofitted the F80 strut brace which goes one step beyond by bolting to the outer frame as well, not just between struts towers. The stock bar is a V, which means it can bend and is designed to bend, a strut brace limits the movement of the struts top points and as a result keeps the general geometry tidy, that otherwise allow some movement.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
09-10-2018, 12:44 AM | #96 |
Rep 35
I just bought this strut bar for ~$50: https://www.jom.de/en/passend-fuer-b...ahr-ab-10-2011
Fitment is good and it looks cool but I am not sure how much good it does since the mounting plates are very weak. |
09-10-2018, 01:35 AM | #97 |
Rep 121
Installed mine today from Megan Racing. $85 - Quality seems good, but my '13 xdrive has a totally different 3 bolt pattern that I see in other f30 example. The third bolt is in back of the shock tower instead of the front.
Two holes still line up, so it should be fine. https://www.ebay.com/itm/MEGAN-RACE-...53.m2749.l2649 Last edited by brikabrak; 09-10-2018 at 01:43 AM.. |
09-11-2018, 09:32 AM | #98 |
Yoda of mods
1674
Rep 3,006
Drives: X5 RWD
Price is good. What are your driving impressions after having it on?
09-11-2018, 02:05 PM | #99 |
Rep 35
10-27-2018, 03:33 PM | #100 | |
Rep 67
The only down side of the aftermarket one is that the dealership here in Egypt wouldn't take it off , u have to take it off at your shop before going to the dealership,, its a pain in the ass really |
Bt130915.00 |
10-28-2018, 11:18 AM | #101 |
Rep 79
10-28-2018, 12:04 PM | #102 | ||
Rep 5,457
Drives: F30
12-17-2018, 12:21 PM | #103 | |
Rep 67
greetings to you "upsidedownfunnel"
I believe the is a way to measure all of this The only pain u ll get is that whenever you change the oil u ll have to remove it,, cause u can't reach the oil filter with this thing on |
09-17-2019, 06:32 PM | #104 |
Rep 42
Does this fit on a 2018 340ix do you know?
2018 340ix MPPSK, adaptive m chassis, variable sport steering, light package, NAV pro, M aerodynamics package, Eventuri intake, stage 1 ecu tune, stage 3 tcu tune! Toronto
10-20-2019, 01:51 PM | #105 | |
Rep 785
According to the manufacturer these requiring trimming or removal of the ecu cover for installation. This is confusing because on my 2015,the ecu is on the right side of the engine. It doesn't appear to be anywhere near the strut brace. And in their photos the main engine cover is installed, so it looks like it would be fine. What gives? |
10-20-2019, 02:44 PM | #106 |
Yoda of mods
1674
Rep 3,006
Drives: X5 RWD
10-20-2019, 03:51 PM | #107 |
Rep 128
Why bother with ones that don't fit the 5 bolt top mounts. The 3 bolt is an old design - it means they haven't bothered to update their products.
Get the Ultra Racing version. It clears the B58. |
10-20-2019, 04:36 PM | #108 | |
Rep 785
Anyway my car is the n55 and I have a 5 bolt strut tower, 6 if you count the bolt which the OEM strut-firewall brace is attached to. If you have a link, pass it on. And to the guy above, 800$ is ridiculous. Megan racing is selling directly for 109 |
10-20-2019, 05:27 PM | #109 | ||
Rep 3,540
10-20-2019, 05:29 PM | #110 |
Law Enforcer
25114
Rep 22,288
Drives: '22 Chalk Gray Porsche C2S
