01-17-2014, 02:42 PM | #23 | |
Rep 1,975
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
01-19-2014, 04:33 PM | #24 |
Rep 603
Just looked at the BMW online parts cataloge.
The 335i Standard front rotor (340mm) and the 18" M Performance Brake front rotor (370mm) seem to have the same original replacement brake pads Part #: 34 11 6 859 066 But.... The M Sport Brake front rotor (370mm) (S2NHA Option) has a different replacement brake pad. Part #: 34 11 6 865 460 That's quite strange, as one could upgrade the 370mm M Sport Brake front rotor with the M Performace Brake rotor. Am I missunderstanding something here? P.S. I made a thread a while ago about the different brake setups. Brakes buying decision helper: "Factory", "M Sport Brakes", "M Performance Brakes" |
01-19-2014, 05:29 PM | #25 |
Rep 1,975
Man this whole brake deal is like an elusive purple unicorn...
01-19-2014, 05:46 PM | #26 | |
Rep 349
2013 EBII 328i M-Sport 6MT, M-Performance Brakes, M-Performance Suspension, APEX Arc-8 18 x 8.5 square, Pilot SS
1999 EB1 M3 - Bilstein PSS9, Vorshlag Camber Plates, Kosei K1, ZII Star Spec, PFC, gallon of distilled water. |
01-20-2014, 01:28 PM | #27 |
Rep 4,323
the pad material is def different between the standard 340 and 370 M Perf option...I've tracked both, and cooked the 340 pads while the 370s did fine.
01-20-2014, 04:12 PM | #28 | |
Rep 1,201
edit: Or does this mean the calipers are different? |
01-20-2014, 09:39 PM | #29 |
Rep 349
FWIW, here are the mounted m-performance pads vs the ones I got from Porterfield. Porterfield is saying they are for 240's, but they seem to fill the 270's.
Note: When installed, only the banana part fills it out the contact surface. Otherwise there would be some area with no pad contact. 1/2"+...not sure.
02-12-2014, 06:15 PM | #30 | |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Looks like there's a little extra room in there, but maybe that is how they're intended to fit the caliper for the 370mm rotor? Are they the same size as your Porterfield street version? I'd like to order a set of track pads - you still think these are the best way to go at the moment?
02-13-2014, 12:22 AM | #31 | |
Rep 349
http://www.f30post.com/forums/showpo...3&postcount=21 might be of interest to you. It's kinda my experience with various setups. Honestly I'd strongly caution against using their track compound in the front without doing something in the rear. I know it's pretty common to run a race pad in front and leave OE in the rear for track days. However, because their track compound is so aggressive, it's almost too much in the front. For me the rear seemed to become unstable. My e46 setup was carbotech front (can't remember the compound) and OE rear. That worked great. These are a whole different ballgame. On the street with cold pads I could with little effort lock the brakes up. A buddy told me it's the same compound stock cars use, so I think it's less about progression. That said, all of my 'tests' have been on street tires. If I had some r-comp's on I would probably at the very least use their street compound in the rear. One last word of warning. For some reason I had a lot of vibration using their race pads. I actually thought my front rotors were warped. I never figured out what it was, but the backing plates were a little different (more bare bones with no handles). The holes for the pad pins were oval instead of circular. I theorize the pad may have been shifting, but thats pure speculation. Is it the best option? I think it may be the only option for M-performance. Most especially the rears. This is the only vendor I've see that makes the pads for the 2pot rears. I've seen a low dust solution (can't remember the brand), but I think that's mainly for low temp/OE applications. I saw a set of custom carbotech's a member had made (might be in the FS forum), but I'm not sure the details there. Man this post turned out much longer than intended lol.
02-13-2014, 09:14 AM | #32 |
558
Rep 1,477
Drives: 335i
Thanks @ronin951 - a lot of good info...
So it sounds like the OE pads are fairly solid, but will start to fade at the end of a punishing track day... not good The Porterfield pads are strong and robust, but maybe a bit too aggressive. And they tend to induce some vibration, potentially due to the way the pads attach. When you ran the Porterfield pads front and rear, did all the brake bias and front lock-up issues (that you experienced with OE rear pads previously) go away? How did you like the feel overall? Lastly, do you know if Porterfield has another compound that would be slightly more progressive? (Can you share your contact info for Porterfield?) Thanks again for your help!
02-13-2014, 07:45 PM | #33 | |
Rep 349
So, the only unknown is how the street compound will hold up with stickier tires, which I think you have. Send me a PM and i'll get you a direct contact. I don't want to put info here. Same for anyone else too.
02-13-2014, 07:53 PM | #34 | |
Rep 1,975
02-13-2014, 08:00 PM | #35 | |
558
Rep 1,477
Drives: 335i
The only other concern I had was your warning about vibration. Was this only with the race compound pads, or is this just inherent to their backing plate/pin hole design on all their pads?
02-13-2014, 09:06 PM | #36 | ||
Rep 349
You should be just fine on track with r4-s (street). Sebring is pretty hard on brakes..well pretty much everything. They did great. I think they use 'street' loosly from a heat perspective. Iirc they have a compound comparison chart on their site. Side note...if you want a compound from another manufacturer they can do that too.
02-13-2014, 09:11 PM | #37 | ||
Rep 349
02-14-2014, 06:48 AM | #38 |
Rep 1,975
So you sent in nib Mperf rear pads and just used what they had for the fronts?
02-14-2014, 04:20 PM | #39 |
558
Rep 1,477
Drives: 335i
@ronin951 - thanks for all your help with letting us know about Porterfield, and your feedback on what you have tested out so far. I contacted them today, and got some good info:
They have definitive measurements for the rear pads (no doubt thanks to you sending in your OE rear pad as a template!), so no worries there They don't have definitive measurements for the front pads on file, and she wasn't positive if the sizing was just right for the M Performance brakes (or M-Sport brake option, which are the same). I want to do a bit more research with this before ordering, and maybe send them an OE front pad to double check, and use as a template if necessary The compounds she mentioned were:
So I'm leaning toward getting the R4 race compound once I get definitive info on the front pad size.
02-14-2014, 05:26 PM | #40 | |
Rep 1,975
02-14-2014, 08:26 PM | #41 | |
Rep 349
As for my original order. I initially asked for standard F30 335 front pads. I was under the mis-understanding that they were identical. What I didn't account for was the rotor size difference. 240mm is stock correct? Somehow these mostly-fill the 270mm rotors. The ST43's was off a little and the R4-S sorta fits due to the banana shape. I just realized I need to post a pic similar to above with R4-S installed. Will do tomorrow. If you reverse lookup the P/N in my OP you should be able to tell what they sent. I actually feel a little bad for them because of all the different brake combo's. I mean I can hardly keep it straight lol. If you guys need me to take one for the team and ship them a pad I will. So long as I get it back
02-14-2014, 08:34 PM | #42 |
558
Rep 1,477
Drives: 335i
If you wouldn't mind sending them one of your front OE M Performance pads for a template... I would be MOST appreciative!!
02-14-2014, 09:03 PM | #43 | |
Rep 349
BTW, got curious and just googled this up Brake Discs/Pads Reviews... VWVortex - Brake pad performance: Friction coefficient & operating temperature LIST Ferodo DS2500 0.5cf MAX Ferodo DS3000 0.62cf MAX Mintex M1144 0.45cf GreenStuff 0.48cf cold, 0.52cf at 175C, 0.4cf at 500C RedStuff 0.4cf YellowStuff 0.46cf TarOx .112 0.35cf, 0.38cf MAX TarOx .113 0.35cf, 0.40cf MAX TarOx .114 0.43cf, 0.47cf MAX Red Dot XF 0.39cf Pagid Black......0.36 cold, 0.38 @ 100C, 0.43 @ 300C, 0.45 MAX Pagid Blue........0.4 cold, 0.42 @ 100C, 0.43 @ 300C, 0.46 MAX Pagid Orange....0.39 cold, 0.40 @ 100C, 0.43 @ 300C, 0.49 MAX Pagid Black......0.44 cold, 0.47 @ 100C, 0.49 @ 300C, 0.54 MAX Pagid Grey.......0.50 cold, 0.54 @ 100C, 0.57 @ 300C, 0.62 MAX Pagid Yellow.....0.40 cold, 0.43 @ 100C, 0.47 @ 300C, 0.49 MAX Hopefully it's accurate.
02-15-2014, 12:02 PM | #44 | ||
558
Rep 1,477
Drives: 335i
