BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F30 3 Series M Performance Brakes Installed
      09-29-2016, 09:11 AM   #177
dreamwonder
Drives: Silver 2006 330i
Originally Posted by Lancelot View Post
These 2 pics makes me wanted to repaint my car to silver.
jtskariah130.00
      04-30-2017, 08:27 PM   #178
Sanelko
Sanelko's Avatar
70
Drives: 2012 Jet Black 328i
Anyone have a PDF of the BMW procedure that runs through the retrofit? I swear I saw it before but no luck finding it now. Would appreciate it if you could send it my way.
      04-30-2017, 08:46 PM   #179
Jim E.
Jim E.'s Avatar
92
Drives: Individ: 99 M3, 11 X5d, 16 F31
see attached
Sanelko69.50
      05-06-2017, 09:57 PM   #180
Sanelko
Sanelko's Avatar
70
Hey guys. So finally got around to doing the retrofit, just did the rear brakes today and have a question. For any of you guys that did this on their 328i, did you need new hardware for the e-brakes? I initially put the adjuster screw on the smallest setting to make reinstall easy, and once I got the rotors on there I started adjusting/stretching the adjuster spring. I adjusted the driver's side to what seems to be the max it will extend to, and the ebrake is still not grabbing onto the rotor at all. I do see the new rear rotor hats are about 1cm wider than the old ones, maybe the e-brake hardware I have won't stretch out that much? Appreciate any input.
      05-06-2017, 11:12 PM   #181
Sanelko
Sanelko's Avatar
70
Think I figured it out, I probably got the rear rotors for the larger wheel bearing in my set.
      05-24-2017, 03:17 PM   #182
roll_the_dice
roll_the_dice's Avatar
507
Drives: 2013 BMW F30 EBII
Did my install of M performance brakes this past weekend...Love the look of these...makes the entire car look better than the stock small calipers that came with my car.
Drives: 2011 Porsche 958, 1965 Chevy C10, 1988 Porsche 944 Sold:2010 e90 Montego Blue, 2013 F30 EBII, 2013 Tangerine Scream Ford Focus ST, 2006 Mini R50,2004 VW Touareg, 2012 Camaro Convertible, 2008 Porsche 911 Convertible, 2007 Corvette, 2004 BMW e64 convertible, 2000 Dodge Dakota, 1999 Ford F150, 1999 Porsche Boxster, 1999 Ferrari Modena, 1992 BMW e36, 1990 Nissan 240sx, 1979 Celica, 1974 Mustang II
My Build Thread
      08-16-2017, 06:46 AM   #183
LarryDavid
Drives: white e60
So much nicer. Great addition!
Oy vey!
Will fix your keys for you at locksmiths leicester
      08-16-2017, 09:16 AM   #184
roll_the_dice
507
Thanks! I love the look. Someone rolled down their window the other day at a traffic light and said...love your car and the brakes!
My Build Thread
CJ4211548.50
      10-02-2017, 08:46 PM   #185
BwatM5
Drives: 2019 F90; 2020 G01; 2014 F31
Installed M Performance Brakes on my F31 today! My biggest challenge was getting the lug studs off. Effing Sears had them well over 200 ft/lbs (I was lazy and didn't feel like putting on my new 398 Orbit Grey wheels last week).
All in all, it took me about 5 hours (1 hour just to remove lugs). It was a bit of a challenge getting the caliper bolts off all 4 corners. It seems like they come with quite a bit of Loctite from the factory. I let the bolts soak in PB Blaster for a bit, which helped.
I bleed the system in the proper order twice, then used Reingold to activate the DSC bleed procedure to shake loose any additional air bubbles (there were some).
I then VO coded SPBR to the HO-WORT folder, Using Serpent720 instructions.
Originally Posted by Serpent720 View Post
Just installed the M Performance Brake kit and did this the DSC coding, and braking feel is great. This is what I did
Using Esys 3.23.4 with psdzdata 51.1
1. Connect=>Expert Mode=>Coding=>Read FA=>Save FA
2. Editiors & Viewers=>FA-Editor=>Go to HO-Wort and right click to "Edit", then type (means add) "SPBR" under HO-Wort folder
3. Highlight the FA, "Activate FA" and "Calculate FA" to verify no error is found after adding the SPBR.
4. Check the Vehicle Profile to locate the "aftermarket retrofit" and verify the "SPBR_18_ZOLL_SPORTBRAKE" is added to the folder
5. Write FA to the car. No confirmation window will pop up after saving the FA to the car. So you need to go to next step for verification.
6. Expert Mode=>Coding=>Read FA. You are able to see the SPBR being added to the HO-Wort folder on your car.
7. Read SVT, and locate the "DSC" (File Folder SVT/ECU/DSC), then right click the "DSC" folder and select "Code". Coding would begin immediately.
8. Wait until the coding is finished, and repeat Step 1 to save a copy of the new FA.
9. Unplug the PC from the car. The M-Performance Brake is now enable and enjoy the genuine M-Performance Braking experience.
So far the biggest difference is the looks! The car looks AMAZING! The yellow really goes well with Mineral Grey. I'll get some better pics up tomorrow. Thank you everyone for your help! This is definitely an easy DIY. My two closest dealer's quoted me $620 and $1140 for the install. Definitely glad I did it myself. It only cost me $5 in brake fluid from my local dealer and $60 for a pressure bleeder from Amazon.
      05-19-2018, 08:30 PM   #186
_.loso._
Drives: 2014 BMW F30 320i
Does anyone know if the F80 M3 Carbon Ceramic Brake kit would fit on and F30????
      06-03-2018, 10:43 PM   #187
Musashi
Drives: BMW 335i XDrive Laguna Seca
Do not recommend you try. Go instead for custom strand woven carbon ceramic new technology, a better CCB, x3- x5 longer than prev CCB tech. Works at all temps.
      10-06-2018, 11:28 PM   #188
mholder
Drives: 2017 F30 340i Black, mppsk
Where have you seen the M Performance Brake Kit sold for under $2000.00 in the USA and what is the labor cost and hours to install at a BMW dealership.
      10-06-2018, 11:43 PM   #189
mholder
Where in the USA have you seen the M Performance Brake kit selling for under $2000.00 and what is the labor hours and charge for a BMW dealership to install.
      10-07-2018, 06:30 PM   #190
Vulpe
Vulpe's Avatar
280
Drives: F87 M2C
Go in the sponsor section of this forum and a couple vendors price them under $2000. A few in the $1700 range before shipping. Of course you also have to add in the rear rotors which is another ~$400. Cheapest if you are lucky enough to get free shipping is just under $2300.
My local dealership quoted me ~$700 after tax, depending on your location I would expect it to be cheaper.
      10-07-2018, 09:35 PM   #191
BwatM5
I purchased a complete set (rotors, calipers, pads, dust shields etc) for $1473 shipped from a BMW dealer on eBay.
      10-12-2018, 08:31 PM   #192
EDWYER
Yoda of mods
EDWYER's Avatar
1673
Drives: X5 RWD
2015 X5 RWD  [0.00]
2016 BMW M2  [10.00]
That's a damn good deal.
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired)
Follow me on Twitter: https://twitter.com/EdwyerCLT
YT: https://www.youtube.com/@DWYERGARAGE/videos
      10-12-2018, 08:37 PM   #193
BwatM5
Yep!! I sent him a message asking to get me his best price. I couldn't say no when I saw it. This was for Yellow Calipers. Red and Orange were a few hundred dollars more.
      10-21-2018, 01:08 PM   #194
TinkyWinks
TinkyWinks's Avatar
42
Drives: 2014 BMW 335i
soooo what is this dealer's eBay username
      11-15-2018, 02:38 PM   #195
vtune
Drives: E92 335i 6MT
hi everyone,
i have this kit and my brake pads are almost done. Can somebody tell me if they are just the regular pads or does this come with special pads? I've been through the entire booklets and cannot find any info on replacement parts.
greatly appreciate any input.
thanks!
      11-15-2018, 06:54 PM   #196
BwatM5
Originally Posted by vtune View Post
hi everyone,
thanks!
The M Performance Brakes use the same pads as the F8x. How many miles do you have? I only have about 10k on mine, but there is plenty of pad left. The stock pads create WAY too much dust. I've heard good things about EBC Reds. I'm probably going to give them a try when it's time.
Here are the part #'s for EBC Reds
REDSTUFF
EBC DP32130C- FRONT
EBC DP32133C- REAR
Here are the part #'s for OEM BMW Pads.
34-11-2-284-969 FRONT
34-21-2-284-989 REAR
      11-23-2018, 03:12 PM   #197
Pdxway
Pdxway's Avatar
19
Drives: 2013 328i
hi everyone,
thanks!
I just got PowerStop from Amazon and it only cost me ~$80 using Prime shipping.
Front:*https://www.amazon.com/gp/aw/d/B01LY...op_mb_pd_title
Back:*https://www.amazon.com/gp/aw/d/B01CF...op_mb_pd_title
The back was on sales for ~$30.
After properly cleaning and lube all contact parts, for ~2 weeks of driving not a single noise.
Stopping power is the same for me for day to day driving.
But, I have read that ceramic pads are not good for track.
I decided not to change rotors (they are above minimum) and I reused sensors. Not doing the pads break-in process either. So far so good.
      12-03-2018, 03:49 PM   #198
White340XDriveInCt
Drives: 2023 Tanz M3 Comp
I'm looking to buy the M Brake upgrade from a BMW dealer on Ebay as well, but I have the Maintenance plan and I am wondering how this may affect that, and/or the warranty? Not sure my dealer will install customer supplied parts, even if from another BMW dealer, and if I get done somewhere else I see them trying to deny any warranty/maintenance claims if they arise, no?
3 series bmw m performance parts, 3 series f30, 3 series f30 forum, 3 series forum, 3 series m performance, 3 series m performance parts, bmw 3 series forum, bmw 3-series f30, bmw f30, bmw f30 3-series, bmw f30 forum, bmw m performance brakes, f30 3-series, f30 3-series forum, f30 bmw m performance, f30 bmw m performance parts, f30 forum, f30 forums, f30 m performance, f30 m performance brakes, f30 m performance parts, m performance 3 series, m performance brakes, m performance brakes f30, m performance f30, m performance parts 3 series
