05-02-2016, 11:12 AM | #1 |
Rep 39
330d xdrive Wet Grip Issues
Hi everyone,
We recently got a 330d xdrive after previously owning an Impreza WRX Hawkeye. Overall we are happy with it but we experienced some wet grip issues yesterday. When exiting a couple of different roundabouts on the a34 Handforth bypass in Cheshire I put my foot down a bit and the back end wiggled. This did shock us a bit as I thought the xdrive would have dealt with this quite easily before the loss of traction but it felt the same as my old e92 335i which obviously wasn't an xdrive. It's my partners daily drive and it has made her a bit worried about it as she hates any tail movement (as do I.) We may have been spoilt by the Impreza as the back end never went out in that on the same roundabouts or any other time, but I'd expect a car that is worth 6 times as much with xdrive to be at least as capable as a 9 year old Impreza. We have Bridgestone Potenza s001 tyres which I understand are pretty bad in the wet. Has anyone else with an xdrive experienced this? Would changing to non run flats make a lot of difference or would having acs springs fitted make a bigger difference by lowering the centre of gravity? If changing the tyres would make the most difference, which tyres do you recommend? I know a lot of people buy a BMW to have a bit of fun with the tail sliding out but we bought the xdrive to avoid that happening. I look forward to your replies. Many Thanks, Adam |
05-02-2016, 11:22 AM | #2 | |
Rep 2,639
Subaru is made of plastic bits and rattles like crazy, it's build quality is quite cheap, for example during the winter, I was having some fun drifting in a parking lot and ended up in a snow bank, front end first. I had no problems backing out and my front end had no scatches or damage at all. My buddy in his STI did the same thing and his bumper was cracked and scratched. I'm running Continental DWS and they are much better in the rain, gas mileage, and comfort. |
05-02-2016, 11:46 AM | #4 |
Rep 123
Sounds normal to me, it always initially steps out at the rear and if you keep your foot planted you will then feel it distribute power to the front. The DSC will always kick in before you get into too much trouble but i still drive it like a rear wheel drive car in the wet and give it a bit of respect - very different to Audi and Subaru 4 wheel drive systems
G21 M340d Touring - Skyscraper Grey over Cognac interior
05-02-2016, 11:47 AM | #5 |
Rep 8,498
Rear-biased X-Drive will have something to do with this, but I suspect it's largely due to the woeful wet grip of the Bridgestones. The rear diff is also open on the BMW and once traction has been exceeded the inside/slipping wheel will over-rotate quickly.
Coming from an Impreza, assuming you drove it like it was intended, there will be a) some adjustment required to your assessment of the BMW's capabilities, or b) some investment required to address the traction/roll/damping, or c) both. As a first step I suggest you ditch the RFTs and replace them with some decent rubber. Michelin Pilot Super Sports have a strong following on the forum, as do Eagle F1s. A Quaife LSD is very effective and changes wiggle (which can feel like sudden break-away) into fun
05-02-2016, 12:32 PM | #7 | |
Rep 39
Yes I know I shouldn't really compare it to the Subaru but it's quite hard not to. You're right about the plastic finish to the Subaru, we looked at a new one and the rear diffuser felt like it was made of wobble board! I wouldn't have thought the f30 could stand up to much impact though as most of the panels bend in very easily but I presume that's a safety thing, crumple zones and pedestrian safety etc! I've not come across Continental DWS I'll look into those. Many Thanks, Adam |
05-02-2016, 01:57 PM | #9 | |
Rep 39
Yes I'm sure it must be mainly because of the tyres so hopefully changing them will sort the issue out to sone degree. I think it was just a bit surprising as I didn't plant my foot down, I was in comfort mode and maybe went down 2/3 of the way down on the accelerator. I will also look to get acs springs at some point too. That LSD looks very good! I had eagle f1's on the Impreza and they inspired a lot of confidence so may look to get those again. They have just released the asymmetric 3 but I'm not sure if they are available in the exact size for my 442's. I've heard a lot of mention about the MPSS but a few reviews I read said their expertise was in dry grip rather than wet. I'm reading good things about the Continental Sport 6, and I take it from the reviews that continentals are better in the wet than the Michellins? Has anyone tried the Sport 6 yet? Many Thanks, Adam |
05-02-2016, 01:59 PM | #11 | |
Rep 39
Maybe that was part of the problem as I didn't plant my foot, I went about 2/3's of the way down and I don't think the wiggle would have inspired me to floor it but maybe with the new tyres I will try that! Many Thanks, Adam |
05-02-2016, 02:04 PM | #12 | |
Rep 19,982
Change the springs and tyres and it will help considerably.
05-02-2016, 02:11 PM | #13 |
Rep 419
Afraid I can't comment on the SportContact 6's, but I have the SportContact 5 run flats and I've never had 'a wiggle in the rain'.
My standard 330d Xdrive feels totally planted in the rain even if I give it a decent amount of beans. Don't get me wrong, it's definitely rear biased, but the sure footedness is why I bought the Xdrive. I know others have said that they've felt the rear wiggle, but before you commit to new tyres, I'd have the suspension checked for anything working loose and them I'd have a 4 wheel alignment done. Good luck |
05-02-2016, 02:28 PM | #14 |
Rep 32,881
Definitely the abysmal Bridgestones! Ditch them and get Michelin Pilot Super Sports, they are great in the wet! I've never even seen the traction control light in the wet with mine.
05-02-2016, 02:38 PM | #15 |
Rep 39
Yes that is very true, and the tyres & suspension is definitely the way forward then!
05-02-2016, 02:40 PM | #16 | |
Rep 39
Do BMW do checks for free as its only 8 months old or do they charge if they check it over and find nothing? |
05-02-2016, 02:42 PM | #17 | |
Rep 32,881
05-02-2016, 02:44 PM | #18 | |
Rep 39
On another note, does anyone know what tyres sizes will comfortably fit on the 442's, I think they are 8j & 8.5j, I think they do Goodyear Ass. 3's in 245 35 19, would these fit ok? Many Thanks, Adam |
05-02-2016, 02:46 PM | #19 | ||
Rep 32,881
And MPSS, although PS4 and sport contact 6's are newer tyres, they are both a rung below MPSS. |
05-02-2016, 02:47 PM | #20 | ||
Rep 19,982
05-02-2016, 02:50 PM | #21 | |
Rep 419
You mentioned that you've only just got the 330d. If it was a BMW AUC I would definitely ask them to check it over for you free of charge. If it wasn't, I'd be tempted to go straight to an expert alignment shop, although it will cost you. |
05-02-2016, 02:52 PM | #22 | ||
Rep 19,982
grip, tyres, xdrive |
