10-06-2014, 12:55 PM | #7393 |
Rep 40,789
Sorry, but I do not know. I hardly ever use INPA myself.
10-06-2014, 01:09 PM | #7394 | ||
Rep 50
ok, thanks.
I have next question. About inserting CAFD. How we choose the right version of CAFD files ? When You write about DME we match version of CAFD with I-level: Quote:
or the last I-level of the CAFD file we can find in PsdzData ? Last edited by __mkw; 10-06-2014 at 01:26 PM.. |
10-06-2014, 01:42 PM | #7395 |
Rep 40,789
You can't ever go wrong using the CAFD file matching the I-Step Shipment.
In my experience though, 99% of the time you can also just use a newer version, so I grab the one from the latest I-Level displayed, as it is easier to do. When it comes to DME, given the criticality of the ECU, as an added precaution I advise people to match the CAFD to current I-Level, although I have at times used newer CAFD on ECU as well.
10-06-2014, 10:19 PM | #7398 | |
Rep 40,789
You can clear them with E-Sys too though: Click "External Applications" in the left menu.
10-06-2014, 10:20 PM | #7399 |
Rep 40,789
PM sent.
10-08-2014, 04:44 PM | #7401 |
Rep 40,789
PM sent.
10-09-2014, 06:07 AM | #7404 |
Rep 40,789
PM sent.
10-09-2014, 06:17 AM | #7405 |
Rep 40,789
Your image is like a postage stamp, and I can't see the details, but it is normal for some ECU's to not have a CAFD like Gateway Module, Tyre Pressure Control Module, Electronic Damper Modules, etc. These Control Units can be flashed with new firmware, but they are not codeable.
10-09-2014, 03:43 PM | #7406 |
Rep 235
I've recently replaced my halogen drl's with led bulbs which look great and work perfect when the headlights are off. However when the headlights are on (therefore the drl's are off) i noticed that they flicker once every few minutes and on startup,im assuming this is the error checking which i have seen mentioned when people replace their turn signals etc. Does anyone know how to code the f30 to disable the drl bulb checks like you can with the turn signals?
10-10-2014, 10:34 AM | #7408 | |
Rep 40,789
10-10-2014, 09:44 PM | #7410 |
Rep 40,789
PM sent.
10-11-2014, 07:36 AM | #7411 |
Rep 201
Anybody have a code for turning off the 3 little amber lights in the headlights of an M4? Stuff I found so far didn't work.
2011 e92 M3 AW Stripper
10-11-2014, 02:09 PM | #7414 | |
Rep 40,789
