01-20-2015, 03:06 PM | #7965 | |
Rep 7
Not sure what's that for... CMB_MEDIA [36] [F590257] readCPS o.k. CAFD_000005B6_004_002_017.ncd generated CAFD_00000B0A_000_037_000 Fehler: CPS read from ECU "ECUIdME_0x12" failed! [C070] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_CPS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; ECU: DME_12_ETHERNET severity: ERROR [2130765072] The car was running. I drove it for about 4 miles and then put it in the parking lot and the engine was idling on Parking gear. The LCD showed all the information on the screen and auto start was off just in case the car engine may die down.. Last edited by ankit486; 01-20-2015 at 03:13 PM.. |
01-20-2015, 05:13 PM | #7966 | |
Rep 40,779
01-21-2015, 10:29 AM | #7967 | |
Rep 7
Finally got the EBT working. It was really easy. Thanks a lot shawnsheridan . On a different note, I tried applying all 6NK, 6NL, 6NR and 6NS one at a time. Initially it showed some symbol which meant mobile phone interphase. But after I changed the code I am unable to get it back. Any idea? I am unable to figure out which option actually gave me that option. I tried all of them repplying one at a time and still cannot get the screen to show that feature. Also, I am not seeing the option for CD/DVD. does it mean I will not be able to play a disk? not that I care because usually I stream music form phone or iPod. But it's spooky!! |
01-23-2015, 06:22 AM | #7968 | |
Rep 143
01-23-2015, 08:50 AM | #7969 |
Rep 1,063
What is the latest version of the F30 cheat sheet? Does anyone have a copy?
Delivered --> '21 G01 X3 M40i, 8SA, Sunstone Metallic with Cognac Vernasca, 22Z, ZDA, ZDB, ZPK, ZPP w/ 4HA, ZPX, 2VF, 3AC, 4K1, 688, 6NW, 5DF
Past --> ?19 G01 X3 m40i, 15 F33 328xi, 8SA, '13 F30 328i, '08 E92 335xi, '95 E34 530i, '88 E30 M3 |
01-23-2015, 09:02 AM | #7971 | |
Don't care
117
Rep 224
01-23-2015, 09:14 AM | #7972 |
Rep 1,063
Perfect, thanks. Without knowing the doc name, it's hard to find in a 300+ page thread.
01-24-2015, 03:13 AM | #7973 |
Rep 50
I want to replace fem module in my F30.
I have used module fem to replace this in my car. What steps in E-sys needs to be done to reprogram this used module with my car VIN and to code module with my car FA ? |
01-24-2015, 04:41 PM | #7974 |
Rep 3,089
Variable Light Distribution (removing 8S4)
Can someone please verify that these are the items I need to change in order to enable variable light distribution:
FEM_Body 3073 C_AFS_ENA nicht_aktiv -> aktiv FEM_Body 3073 LUT_FLC_FORWARDLIGHTING_Y 9C 9C B0 -> 9C 9C 9C I know I can VO code as well but I am too lazy to re-code all my FEM_BODY coding changes I've already done. |
01-25-2015, 08:26 AM | #7976 |
Rep 40,779
As far as I know, it is available in all I-Step.
01-25-2015, 09:50 AM | #7977 |
Rep 1,749
setting up a new laptop. can someone give me link to latest esys and datafiles please. thanks!
"It gave you amazing satisfaction, but anyone who says he loved it is either a liar or he wasn't going fast enough." - Jackie Stewart on racing at the Nurburgring
01-25-2015, 01:03 PM | #7978 |
Rep 6,990
Just did my first coding, everything worked great! Question: I coded EFF_DYN_SPORT_CID to "aktiv" and the display shows up on my non-navi screen, but I don't get any values. Is there something else that needs to be coded to actually get the screen to display HP and TQ values?
Thanks in advance!
01-25-2015, 01:21 PM | #7979 |
Rep 40,779
PM sent.
01-25-2015, 01:22 PM | #7980 | |
Rep 40,779
01-25-2015, 01:27 PM | #7981 |
Rep 6,990
Bummer!
01-25-2015, 08:30 PM | #7982 |
Rep 124
I upgraded my map to 2015 and my RTTI didn't work any more
I adjusted my setting to NAVI_TRAFFIC_INFO_MAP = aktiv TI_TMC = aktiv TI_CA_TMC = aktiv TI_TMC_REGIONAL = aktiv TI_TRAFFIC_INFOMAP = aktiv TI_VINFO = aktiv Previously on 2013 map it worked but now it doesn't. Did i miss out some steps? |
01-25-2015, 09:09 PM | #7983 | |
Rep 40,779
01-26-2015, 07:30 AM | #7984 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
This only will work if you have HU_CIC or HU_NBT. Enabling it on HU_ENTRY or HU_ENTRYNAV will give you the guages but nothing will work. |
01-27-2015, 07:45 AM | #7985 |
Rep 6,990
Thanks. All I can find is the HU_ENTRY, so I apparently have neither of those other categories.
01-27-2015, 10:21 AM | #7986 |
Rep 1,573
if you dont have navigation, you wont find HU_CIC or HU_NBT
2015i Cadillac Escalade ESV
