07-25-2015, 06:33 PM | #8977 |
Rep 1,130
Drives: '16 340i AW MSport
Coding a friends car ran into an issue where coding folding mirrors wasn't working, did BMW re-map the location of the ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN code?
Basically as seen in the screen shots I observed the following:
Any Ideas? |
07-25-2015, 07:47 PM | #8978 | |
Rep 40,789
07-26-2015, 04:21 AM | #8979 |
Rep 44
I just picked up a brandnew F11 with stock software F010-15-07-502 which means ISTA/P 3.56.1.
I run E-Sys 3.24.3, E-Sys Launcher Premium 2.1.2.63 and PSdZData 56.1 Lite as I want to FDL-Code only. I'm quite used to FDL-Coding with my "old" 2012 F30, but with old, untrimmed versions of PSdZData Two questions: 1) I need to use 56.1 but I'm a little in fear as those PSdZdata are trimmed and comments "re-injected" in some way. If the injection by Tokenmaster is not right for whatever reason (e.g. BMW changed the position of an option), can I simply load the original CAFD that I read out initially and FDL-code it again and I'm fully reverted? 2) Is it correct that with this software combination I do not need to enter a Token PIN any more? |
07-26-2015, 07:31 AM | #8981 | |
Rep 40,789
2) With E-Sys Launcher, you generate your own .EST with PIN, but do nothave to enter PIN each time afterwards.
07-26-2015, 07:32 AM | #8982 |
Rep 40,789
PM sent.
07-26-2015, 07:34 AM | #8984 |
Rep 40,789
PM sent.
07-26-2015, 09:52 AM | #8985 |
Rep 1,130
07-26-2015, 12:04 PM | #8986 |
Rep 171
Drives: X3 M Comp
Hi Shawn,
I'm looking to start trying my hand at coding etc. Could you message me details on how I can get the E-Sys and things required to start? Thanks. |
07-26-2015, 12:06 PM | #8987 |
Rep 40,789
PM sent.
07-26-2015, 12:11 PM | #8988 | |
Rep 40,789
07-26-2015, 05:33 PM | #8989 | |
Rep 15
1. BC_DIGITAL_V : I have it set to "aktiv", however after coding, it reverts back to "nicht_aktiv". I see not digital speed under BC. 2. BC_V_KORREKTUR: I have it set to "nicht_aktiv", however after coding, it reverts back to "aktiv". Also, I am seeing a funny display under BC that looks like a time symbol (as under cruise control) followed by a "km/hr" reading that starts from zero but is slowly incrementing...does not match the actual speed or any correction. 3. BMW_LOGO: I have it set to "m_performance", however, it defaults to "ag" after coding. 4. DIM_NACHT_EIN: I set "werte=FF", but it defaults back to "werte=08" (the original setting my car). Any ideas on what I am doing wrong here? I am receiving no errors in the "coding" step? I am having the same issue regardless of whether I am programming "KOMBI", "FEM_BODY" or "HU_NBT". All setting changes seem to take effect but after shutting the car and restarting, all values go back to default, except for this new display under BC (mentioned in #2 above) Do i need to get a restore done from my original settings....if so, can anyone guide with the steps. HELPPPP !!! Last edited by manyoo99; 07-26-2015 at 07:11 PM.. |
07-26-2015, 07:43 PM | #8990 | |
Rep 40,789
07-26-2015, 07:56 PM | #8992 |
Rep 40,789
No. You cannot send or receive PM's yet. Send me one when you can.
07-26-2015, 08:24 PM | #8993 |
Rep 15
07-26-2015, 10:46 PM | #8994 |
Rep 2,233
Drives: '12 M3
Does anyone know how to read OBD2 error codes (ie. check engine lights) for these F series cars?
07-27-2015, 10:23 AM | #8996 |
Rep 40,789
PM sent.
07-27-2015, 11:01 AM | #8997 |
Rep 1,799
Shawn, I coded a Jan 14 F31 successfully using the guides on here.
I am due to pick up a June 15 F31 on Thursday and assume it has the shortened CAFD files - is there an idiots guide anywhere on how to code these shortened files ? You already sent me a link to download the new software - thanks.
U06 230e Active Tourer |
Previous : 2019 F31 340i : 2017 F31 335D M-Sport |
07-27-2015, 11:09 AM | #8998 | |
Rep 40,789
