08-22-2015, 08:46 AM | #9153 |
Rep 40,779
PM sent.
08-22-2015, 09:53 AM | #9155 | |
Rep 59
Is there going to be an issue with the dealership if I go in with a modified FA? Thanks for all of your help on these boards. Mark |
08-22-2015, 10:06 AM | #9156 | |
Rep 40,779
That said, if an when Dealer programs a car, ISTA/P reads FA and flashes and encodes the ECU's accordingly. Thus, FA (Options and Build Date) must be proper for any and all hardware installed to car. If you have retrofitted AHL, and AHL was a valid factory option for your car, and FA is proper for AHL, programming should be no issue. But say for example you retrofit Xenon only, without Adaptive function, and Xenon only was not offered for your build (only AHL was offered), then ISTA/P is not going to like it. In case like that, original hardware must be put back in car for successful dealer programming.
08-22-2015, 01:30 PM | #9158 |
Rep 40,779
So in your case, I would just add both codes back to FA, and write FA to car.
08-24-2015, 02:45 AM | #9159 |
Rep 490
Replaced Battery need coding?
I've been hearing/reading that everytime a BMW ride replaced it's battery, it need to be "coded" - the coding in this case seems to vary from a setting change to adaptation.
I just have my factory battery replaced with a 95ah (factory were rated at 90ah, most after-market batt are all 80 or 95ah) - is this something we can code ourself? The shop that replace my battery says nothing need to be coded as "F-series" are smart E-word seems to allow coding the battery with 70, 80 or 90ah AGM battery @Shawnsheridan - mind sharing Tools32 installer? read that it could be used to reset the battery, but the "Ediabas" folder I have doesn't seems to be working - it kinda get left behind from prior installation, never actually installed the program on it's own Last edited by kon; 08-24-2015 at 03:51 AM.. |
08-24-2015, 06:02 AM | #9160 | |
Rep 40,779
PM sent.
08-24-2015, 09:26 AM | #9161 | |
Rep 490
08-24-2015, 06:28 PM | #9162 | |
Rep 5
2012 F30 318d - the second 318 I've owned
Bayside, Brisbane, Australia |
08-24-2015, 06:35 PM | #9163 | |
Rep 15
When I press start icon in second step trying to write a fake VIN (WBAFV31030DZ17872) there is an error: SWT diagnosis for ECU "basevariant=HU_nbt diagaddress=63 failled [CO57] OpenECUconnection for link HU_nbt_63_Ethernet Failed with error MCD error severity: 20651, error code:49184, descrition: object with na me not found, Vendr code:3, Vendor description: provied name HU_nbt_63_ETHERNET doesnt map on an item. I came from a HU_entry to a retrofit NBT with emulator, on a f20. Any help will be welcome Thanks! |
08-25-2015, 08:52 AM | #9164 |
Rep 2
So this is literally the greatest thread I've read, almost 3 years of coding information in one place!
I'm new to it all, and recently purchased a 2013 MY14 328i M-Sport. shawnsheridan you are a deadset legend and I'd really appreciate if you could send the E-Sys files and all the stuff I need to audionick@gmail.com I have a cable on its way. Cheers |
08-25-2015, 10:28 AM | #9165 | |
Rep 40,779
08-26-2015, 12:05 PM | #9166 | |
Rep 18
Anyone managed to activate this function on F30? Singapore is a hot climate country & the air condition is set to Europe standard which totally not cold enough in our country. Appreciate if any kind soul could give me a direction. Did tried to use google translate on INKA and seriously got no clue about it. Lastly, I would like to thank Shawn for keeping this post alive |
08-26-2015, 06:12 PM | #9167 |
Rep 3
@shawnsheridan, I am currently on E-sys Version 3.26.1 and PSdZData_Lite Ver. 54.1. Is this the most current?, if not, can you send me the link? Thanks again.
08-27-2015, 04:52 AM | #9168 |
Rep 40,779
No, 56.3 is the latest. PM sent.
08-27-2015, 09:04 AM | #9169 |
Rep 98
Shawn can you send me this new Psdzdata?
Does anyone know the codes for a 428 convertible F33? Configure something different at the opening of the ceiling?
08-27-2015, 09:06 AM | #9170 |
Rep 40,779
PM sent.
08-27-2015, 09:36 PM | #9172 |
Rep 1,374
Drives: Audi R8 v10 Spyder
Hi Shawn,
Could you send me the link to the latest version of PsdZData? Thanks in advance
08-28-2015, 11:35 AM | #9174 |
Rep 33
I'm in the process of rebuilding my laptop and am upgrading all the E-sys bits for a MY2015 F30. Shawn, would you mind sending me the latest links?
One more question: I found this guidance from you in another thread. For an F30 is this still correct for current pszdata and e-sys? "What is E-Sys Launcher Car Series set to? It should be as follows: E-Sys Launcher Car Series = F30 E-Sys -- Connection Target = F20" Thanks! Last edited by Drew46; 08-28-2015 at 01:33 PM.. |
