BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > KW V2 Compatible Camber Plates
      09-09-2017, 05:01 PM   #1
Grewal99
Drives: 2013 335xi M sport
Are there any camber plates out there that are compatible with the KW V2 coilovers?
      09-11-2017, 04:36 PM   #2
SpecialK
Drives: 2012 335i
I think the KW front springs utilize the stock upper mount, so any camber plate that's compatible with stock springs should work. Call the vendor first to confirm.
You options are:
Ground Control
Vorshlag
K-mac
Dinan
There may be more, but that's all I can think of off hand.
      09-11-2017, 10:58 PM   #3
Grewal99
You options are:
Ground Control
Vorshlag
K-mac
Dinan
Okay cool thanks for the info will call first and ask thanks for listing a few options
      04-20-2018, 09:13 PM   #4
DaFish
DaFish's Avatar
Drives: 2014 435iX, FBO
You options are:
Ground Control
Vorshlag
K-mac
Dinan
Please post here - I'd love to know too. Thanks
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S
      04-20-2018, 09:21 PM   #5
Grewal99
You options are:
Ground Control
Vorshlag
K-mac
Dinan
Hey man from wat I have figured out ground control is one of the best but you need to call kw and check the size so you can get the matching ground control size so it fits properly
      04-20-2018, 09:32 PM   #6
DaFish
DaFish's Avatar
You options are:
Ground Control
Vorshlag
K-mac
Dinan
Thanks...
https://groundcontrolstore.com/colle...es-4seriespair
Ill have to validate with Kw and GC
      04-22-2018, 07:22 AM   #7
B58 parts
B58 parts's Avatar
Drives: '17 340ix 6MT
Please let us know .. I am going to get some camber plates to compliment the kw v3s.
The caster is 1 deg different from l/r ... and I need to add a lot of camber. I was hoping to run -2.5 front, -2 rear. The rears are set. The front was only at 0.7/0.8 and it is still understeering pretty badly. I've been tweaking the tire pressures and the damper settings but I haven't been able to get enough grip up front to offset the great amount of grip in the rear. I believe more camber is the next move.
Then unfortunately sway bars, as the body roll with these is still a bit much. It's worse than the b16s I ran briefly, which were too stiff around town (even for me), plus I couldn't get the front low enough, and an unfixable clunking noise with them developed in week 3. I'm going to ship them for repair and sell them off .. sucks, sucked having to do the install 2x, and now camber plates...
The kw v3s are great, the ride is amazing. They just don't handle quite the way I'd like yet, but that should be solveable through further adjustment / additional parts.
      04-27-2018, 06:02 PM   #8
DaFish
DaFish's Avatar
I got my KW Street Comforts installed this week, and I had the car aligned this week. He said I need LESS camber on the rear, and MORE camber on the front. I think I was -.7 too on the front.
We could go Ground Control camber plates, or apparently M2 suspension arms. My mechanic said he installed these on a customer for about -1.5 degrees on the front - which would be fine for street, but probably not for you if you track.
I am exploring this and will let you know.
