BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > 2018 340i xDrive BM3 MM S2+ dyno
Studio RSR
      10-02-2023, 05:55 PM   #1
lens
lens's Avatar
2070
Drives: 2018 340i xDrive
Brought my car to my local dyno to see what it makes on 91!
433AWHP/521AWTQ
Mods are:
BM3 Multimap stage 2+ 91 OTS
BM3 flexfuel kit
CTS turbo catless DP
TU HPFP
Ivilla035114.00
_ObiJon200.00
toxik2454.50
      10-03-2023, 10:23 AM   #2
Ivilla035
Drives: 2016 340i RWD
433AWHP/521AWTQ
Mods are:
BM3
BM3 flexfuel kit
TU HPFP
Let's go!! Solid numbers.
lens2069.50
      10-05-2023, 12:25 AM   #3
iamsammtheman
Drives: 2017 340i Xdrive 6MT
holy smokes that's on an OTS tune?
      10-05-2023, 04:04 AM   #4
lens
lens's Avatar
2070
Yup, multimap stage 2+ 91 OTS
      10-05-2023, 05:34 AM   #5
M2C
Drives: BMW M140i xDrive
Great numbers for only 91. Can you maybe provide a log?
      10-05-2023, 07:38 AM   #6
lens
lens's Avatar
2070
https://bootmod3.net/log?id=64f8ae4dc090c6bb30a691de
      10-05-2023, 08:00 AM   #7
M2C
Thanks. The only "bad" thing I can see is a throttle closure and some timing corrections between around 3,800 until 4,800 rpm. Seems like a little bit too much boost in the beginning. But except for that pretty nice values considerung 91 oct only.
      10-05-2023, 12:34 PM   #8
lens
lens's Avatar
2070
Normal, you're not supposed to start that low rpm at high gear anyways.
What's important is the results after 5k rpm.
Here's a multiple gear pull example.
https://bootmod3.net/log?id=64ddf0feae729b43b3899caf
A few corrections but nothing too serious, mostly heat related and 91.
But you're still seeing positive timing so it's not a bad map to run.
bm3, bmw, ots
