04-08-2024, 01:24 AM | #4115 |
Rep 3,878
Again - you have major corrections going on! Your fuel is terrible! Crap fuel - crap performance. You need (much) better fuel if you are experiencing corrections on a stage 1 RON 95!
Your stage 0 looks ok-ish but even there it is visible that your fuel is low octane!
04-08-2024, 03:15 AM | #4116 | |
Rep 27
04-08-2024, 03:23 AM | #4117 |
Rep 3,878
I don't think so. Your Stage 0 map is running ok, although still suggesting suboptimal fuel. This to me proves it is the fuel, not spark plugs or anything else.
Try different fuel or start adding Ethanol. Don't kill you engine with this one.
04-08-2024, 06:38 AM | #4118 |
Rep 4
Can anyone confirm what is reducing my load limit after 6,300 rpm on the second WOT pull (see link to log below)
https://www.bootmod3.net/log?id=6613...7984464cd92501 My first guess is component protection due to EGT or similar but would be great if someone could advise. Apologies that the log doesn't just contain the WOT pull data (I have have been checking log data during steady state conditions too) |
04-11-2024, 05:27 AM | #4119 | |
Rep 5
And today I changed all ignition coils (OEM Bosch) but I wasn't able to do good pulls but ones I did and compared to previous similar pulls there is huge difference in timing corrections. So far only cylinder 1 is doing few (but less than before). I'll add new logs when I have time to do so. Anways, are old ignition coils (as attachment) looking normal? I guess those are pretty old if not original. Spark plugs were changed ~5000km ago and there was no visible dust, oil or anything else exceptional. |
04-11-2024, 05:59 AM | #4120 |
Rep 3,878
Unlike spark plugs - you cannot tell much about the condition of coils just by their look... it is all internal.
04-15-2024, 03:21 AM | #4121 |
Rep 4
Can someone take a look at this log file and tell me if there is something i should worry about?
https://datazap.me/u/w00t/stage-2?log=0&data=23 Car is 540 stage 2+(98 ron map ) on 100 ron fuel with the current mods: HJS 300 cel high flow cat, everything else stock K&N drop in filter TU Pump Masata chargepipe NGK sparkplugs, stock gap My concern is with the timing corrections on cyl2 and cyl4 and the off target on the exhaust vanos. Thanks in advance. Last edited by w00t; 04-15-2024 at 07:37 AM.. |
04-15-2024, 05:48 AM | #4122 |
Rep 3,878
Are you mixing up RON and AKI?
Where are you? 100 is most likely RON. And the 93 you are referring to cannot be RON, it is AKI (equivalent to 98 RON). You should be more worried about the timing delta for knock being pulled at the beginning. Not much, but indicating you could use a bit better (higher octane) fuel. You can drive as is if you choose to, but keep an eye on the logs as temperatures increase…
04-15-2024, 07:21 AM | #4123 | |
Rep 4
Will try with a bit of octane booster to see if there is a difference. |
04-15-2024, 07:23 AM | #4124 |
Rep 3,878
That means you are using the AKI 93 map (= RON 98 map) with RON 100 fuel. Don’t confuse them
Use ethanol instead of octane boosters.
04-15-2024, 07:34 AM | #4125 | |
Rep 4
Are u suggesting using a little bit of ethanol to smoothen out the corrections and the timing delta for knock? If so should i be switching the map to a more aggresive one, or the current should be fine? I don't want to install flexfuel kit or calculating the E content every time i fill up, that's why im asking for the optimal solution. |
04-15-2024, 08:44 AM | #4126 |
Novice
303
Rep 695
Not posting my log but posting a photo of my log because some people here had doubts about my hybrid turbo logs..
Look at this boost curve (not on a daw but on a full frame turbo) |
04-15-2024, 08:45 AM | #4127 |
Rep 3,878
Just add about 5-10% E! No need to change anything. The E increases the fuel octane. Start with about 5% and see how the logs are. Might be enough.
04-16-2024, 06:39 AM | #4128 |
Rep 5
Stupid questions continues..
I feel myself total idiot because I don't understand what torque limit 131072 actually means. Cylinder fill limit is confusing me. I have tried to find answers with AI/Google/Youtube but I'm still confused. Can someone try to explain a bit easier way about it, give me a hint am I doing something horribly wrong or what I should check next? Transmission is flashed with default xHP stage 2 map. Engine is B58 gen 1. Recently changed parts - vrsf high flow downpipe - bosch oem ignition coils - k&n high flow intake filter (~5000km ago) - engine oil + filter (~5000km ago) - transmission oil (~5000km ago) - ngk spark plugs (~5000km ago) With MHD stage 1 map, https://datazap.me/u/muumio/mhd-stag...-22-37&solo=22 First I accidentally flashed MHD stage 2 map while setting aftermarket DP option for quick test run after installing high flow DP, https://datazap.me/u/muumio/mhd-stag...-26-47&solo=26 EDIT: I was able to go for another run with correct map. Last edited by muumio; 04-16-2024 at 12:33 PM.. |
04-16-2024, 08:13 PM | #4129 |
Rep 2
B58 Stage 2 93 log review
18’ m240i with BM3 Stage 2 93 tune. How’s the log look? From what I understand timing corrections less than 3 and no knock are good?
https://bootmod3.net/log?id=661f16d913417d1edeb7ebe3 |
04-16-2024, 10:24 PM | #4130 | |
Rep 954
Dustin Braun @ Braun Performance Tuning
04-16-2024, 10:26 PM | #4131 | |
Rep 954
04-17-2024, 01:39 PM | #4132 |
Rep 2
Thanks for the advice. It was about 85 degrees ambient when running the logs. I live in the south so it gets pretty hot. May end up switch to the 91 map once it gets hotter. Shell 93 here seems to be pretty good.
04-17-2024, 10:53 PM | #4133 |
Rep 5
04-18-2024, 12:06 PM | #4134 |
Rep 19
Can someone looks to my log and says is everythink is good?
Gen1, Masata catted DP, RON98, St2 MHD https://datazap.me/u/black340i/log-1...25-26-27-28-29 Thanks |
04-19-2024, 12:57 PM | #4136 |
Rep 20
Hi Guys I have a b58 , and my logs are okay im on stg2 Mgflasher 98 ron- but my Boost The map asks for 16-17psi and mine starts dropping after 5700 rpm 15.5 and then comes back slowly can you guys check my log
This was 3-4th gear i believe https://logs.mgflasher.com/log/14cbb...0=&wide=1&vt=2 Second one in 3rd gear https://logs.mgflasher.com/log/14cbb...0=&wide=1&vt=1 Third one 3-4th i believe https://logs.mgflasher.com/log/14cbb...19&wide=1&vt=0 |
