01-14-2018, 08:41 PM | #243 |
Rep 2,214
Aren't you replacing four original 8x18" ET34 with four eBay 8x17" ET34 wheels?
01-14-2018, 08:57 PM | #244 | |
Rep 6
But he also said he pulled these rims from a 2011 323. So I was questioning the ebay person since the rims should come in different widths for the front and the rear if they were pulled from a 2011 323. If they are all the same part number 36116775599. The offsets should be good with the F36. Thanks! |
01-16-2018, 03:59 PM | #246 |
Rep 57
I have read through most of this thread, but I am still a bit confused. I am trying to purchase a 19x8.5 ET 35 square set with 245-35-19 tires. Will that fit nicely or "flush" on both axles (front and rear)? Excuse my ignorance with this subject, just wanted help.
Edit: Forgot to add, this is for an F30 328i Base. Last edited by Alpine3s; 01-17-2018 at 07:23 AM.. |
01-18-2018, 07:48 PM | #247 |
Rep 161
So I have a 2017 320i with H&r sport springs on 397 oem wheels, I'm on the hunt for some 437 or 403 wheels, and my question is, would these work on my 320i? And what's the widest I can go on tires? 265? I'm sooo confused!
02-01-2018, 09:51 AM | #248 |
Rep 14
hi i ried to read through here but couldnt find the same question
can someone help and let me know if 18x8 et40 would fit? it would be 225 45 18 all around? thanks |
02-01-2018, 12:54 PM | #249 |
Rep 5,140
02-02-2018, 10:33 AM | #250 |
Rep 14
02-14-2018, 01:11 PM | #252 |
Rep 11
Hi All - newbie here
Have just picked up a 435D Xdrive M Sport (2014) and have the wheels below to be put on the car but before i go any further i want to make sure i have the correct fit for the xdrive system the wheels are as follows - F 20 x 8.5 offset 40 & R 20 x 9.5 offset 45 What size tyres do i need? i want to run it on non runflats and may in the future drop it to 430D level. Any help or advice would be great, thanks Last edited by tommerf13; 02-14-2018 at 01:20 PM.. |
02-19-2018, 12:30 PM | #253 |
Rep 30
Hello everyone. I think I have the answer to this fitment but I just want to be sure. Has anyone used the following setup on a 2014 BMW F30 328i
Wheels: 19x9 ET-35 19x10 ET-38 Tires: 245/35/19 Front 275/30/19 Rear I believe after reading the entire post that the 275/30 on the Rear will RUB and I have to go with 255/35/19 as the widest tire. I would like to be sure, incase someone has this setup and it is working well. Thanks -WS |
03-15-2018, 10:27 AM | #254 | |
Rep 231
I am looking at a 9 inch front with ET35 and a 10 inch rear with 45ET running 235/35 and 275/35 tyres which are within the 1% difference allowable fro X Drive. Got any photos? |
04-05-2018, 03:53 AM | #255 |
Rep 3
Fitment 328i F31 Non m-sport
Hi.
I just ordered new rims, can you plese give input on if it will fit or not? Rims IMAZ IM8 8.5x19 ET 38 Also i got 4 pair of 255/35-19 Pirelli P Zero. I got non m-sport 328i Euro model. Thanks. |
04-06-2018, 10:33 AM | #256 |
Rep 8
Hello guys.
I want to install non OEM wheels on my bmw F31 touring. Wheels in question are 19" 8.5J ET35 with center hole 72.6mm on ALL four wheels. Tyres im going to put on are 225/40R19. It should be fine on front, however I am worrying that on rear wheels such a little offset would pose problems with tyre being too deep so that it might rub inner fender. Can I put that dimension rear without any problems or should I consider purchasing 12mm spacers, so I would reach stock offset of 47mm. Thanks! |
04-06-2018, 03:41 PM | #257 |
Rep 5,140
The wheels will fit just fine!
8.5x19" ET35, 225/40-19 is only 1 mm from OEM square spec (ET36). Spacers works in the opposite direction, ET35 wheels with 12 mm spacers yields a new offset of 23! |
Machinebuilder278.50 |
04-07-2018, 04:23 AM | #258 |
Rep 8
Thanks for reply. Yeah I see now, stock rims have ET 47 since they are wider and they must compensate that.
04-07-2018, 06:58 AM | #259 |
Rep 5,140
04-11-2018, 09:20 PM | #261 |
Rep 20
Hi just got a F30 320 Touring
Does it have the same track front and back as the larger models like 335? Loving the look of the M437 Also what rep are made in M437 design and in good quality? Have no problem going OE M437 with 235/40/19 and 265/35/19 or 255/35/19 but I’m affraid they will poke out just so slightly. Not a fan of that. They have to be just as concave as OE NOT 1 mm less if that’s possible with a rep...? thanks |
05-10-2018, 03:06 PM | #263 |
Rep 9
Not sure if this has been shared before, but here is a list of all F30 wheels with factory tyre sizes and the usual wheel specs - https://www.carsaddiction.com/en/whe...?m=3series-F30
05-17-2018, 03:08 PM | #264 |
Rep 473
Can someone help? wondering if I can get away with
19's 8.5 FRONT et30 AND 9.5 REAR et36 I'm RWD on stock M sport (sport Line) suspension. Non adaptive If so what tires can I run? widest? Thanks
I has no mods
