View Poll Results: Did you experience timing chain failure on your N20 engine? | |||
Yes, my timing chain failed or required replacement. | 33 | 14.47% | |
No, I have not experienced timing chain failure. | 187 | 82.02% | |
I replaced my timing chain as a preventative measure. | 8 | 3.51% | |
Voters: 228. You may not vote on this poll |
10-20-2021, 12:24 AM | #309 |
Rep 1,407
Drives: 13' F30 328i 6MT
2013 328i N20 w/ 109k miles
- Tuned since 50k miles - Start / Stop coded out since 40k miles - Oil Changes every 6k w/liquimoly since 40k Currently I have a little oil pump whine ( sounds like a bad alternator bearing ), Once the car warms up the noise goes away and sounds normal outside of the wastegate rattle... Car pulls hard with zero issue.. Gonna just pay attention to the oil pump whine and monitor to see if it gets worse.. For now as soon as it warms up the noise is gone and car drives like day one... Chain thru the oil cap seems tight and theres no metal on metal sounds or noticeable wear when looking in.
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] |
sspade2468.50 |
10-22-2021, 08:50 PM | #310 | |
Rep 234
10-22-2021, 09:18 PM | #311 |
Rep 16,140
The tensioner that was used in the N20/26, 11317567680, was used in many engines, including the N43, N45, N46. They were normally aspirated, so it could be that the added stress of the turbo N20/26 was too much for it to handle.
10-24-2021, 10:17 PM | #312 | |
Rep 105
The chain was updated in 2015: https://www.realoem.com/bmw/enUS/par...&q=11318648732 On other cars, when they list a time range for the part in the part page, it indicates the part you should use for cars that were built in that time range. For example, there were two different ABS systems used on E46M3, depending whether the car was pre or post 9/2002: https://www.realoem.com/bmw/enUS/sho...diagId=34_1117 https://www.realoem.com/bmw/enUS/sho...diagId=34_2238 This leads me to think that the fact that the tensioner is listed twice on the parts page means that either one is perfectly fine. The chain, on the other hand, only has one part # listed, and it's only once you click on the part # for the chain itself do you realize it has been superseded. |
10-25-2021, 07:22 AM | #313 | |
Rep 16,140
We're well aware that the chain was updated. But since it was also used in the N55 without issue that indicates it was not necessarily the problem in and of itself.
10-25-2021, 10:01 AM | #314 | |
Rep 234
10-29-2021, 06:07 PM | #315 |
Rep 81
How bad is the slack on this? 2014 228i w 109k miles
https://youtube.com/shorts/GG6gZFOr-WA?feature=share |
10-29-2021, 10:07 PM | #316 | |
Rep 891
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
10-30-2021, 03:59 AM | #317 |
Rep 6
Model: 2014 328i xDrive
Mileage: 101k miles Timing Chain Status: No problems Oil Changes: IAW the conditions-based maintenance, Mobil 1 0W040 "European Formula" Stop/Start Coded Status: Not coded, but always turn it off Additional Details: None |
04-06-2022, 03:34 PM | #318 |
Rep 7
(bump)
Model: 2014 320i xDrive Mileage: 101k miles Timing Chain Status: No problems Oil Changes: Every 5k since I've owned the car (75k), Castrol Edge Stop/Start Coded Status: Coded out since 75k Additional Details: BM3 Stage1 since around 90k, I don't push it hard though. I always said I'd keep the car forever and just take my chances, but I've been eying an E85 Z4, and since I'm moving to a warmer area soon I thought this might be the time to try something new. Plus, a friend who knows a former BMW mechanic asked him his take on the N20 for me (just for fun) and he cursed it out saying he "wouldn't recommend one to his worst enemy". |
04-09-2022, 09:22 PM | #319 |
Rep 9
Model: 2012 BMW 328i
Mileage: 100k Timing Chain Status: Failed/Required Engine Replacement Oil change intervals: Every 5k miles Auto Start/Stop: Coded out Additional details: Bought the car at 88k miles and turbo, engine mounts, and exhaust hangars were replaced under warranty. Timing chain whine appeared at 95k miles and was taken to BMW at 100k miles where they confirmed it not only failed, but the guides were in pieces. Car drove fine besides the timing chain whine and the obvious need for new spark plugs. BMW recommended engine replacement at a cost of $12,600. Service is covered by third party warranty. No further details as to why an engine replacement was needed besides the timing chain guides being in pieces. Was running BM3 Stage 1 since 92k miles. Also, the whine started out very subtle, only appeared on cold startups and went away when the car warmed up. This lasted from 95k miles to about 99k miles where the whine would remain even while the car was warm, was very consistent and loud and matched the RPMs. Sounded like a screeching cat and was very noticeable in and outside of the car. Last edited by Sirhc1995; 04-09-2022 at 09:46 PM.. |
04-12-2022, 10:02 AM | #321 |
Rep 5,458
Drives: F30
Cold will not give an accurate picture as the chain tensioner is driven by oil pressure... therefore engine must be warm with oil circulated to make sure tensioner is fully extended and doing its job.
04-14-2022, 06:08 PM | #322 |
Rep 10
Model: 2014 328i xDrive. South Africa model
Mileage: 102k miles Timing Chain Status: None so far Oil Changes: Every 3k miles Stop/Start Coded Status: Coded off except in eco mode Additional Details: EW Charge pipe & Injen intake w/ SAT coded in along with S+ |
sspade2468.50 |
07-30-2022, 07:19 AM | #323 |
Rep 17
Model: 2013 328i
Mileage: 71k miles Timing Chain Status: no issues Oil Changes: Every 5-6k miles Stop/Start Coded Status: manually turned off, rarely if ever use eco Additional Details: Injen intake, downpipe, Bootmod3 tune since ~50k. I give it a spirited drive here and there, but do not beat down on it. Last edited by TheKingStampede; 07-30-2022 at 02:32 PM.. |
sspade2468.50 |
08-11-2022, 03:32 PM | #324 |
Rep 5
Hello Everyone,
I took my car to my mechanic and the car wouldn’t start. He opened it up because he thought it was the starter. Come to find out it was a time chain that slipped. He suggested that I take it to the dealership to see if they can cover it. I have a 2016 328i sulev GT with 48,790 miles. Does anyone know if there is coverage on that model? Some advice would be really appreciated. |
08-12-2022, 08:49 AM | #325 | |
Rep 5,458
Drives: F30
That being said... your mileage is extremely low and I would definitely take it to BMW for a proper inspection... and "See what they say." Hopefully, the car is well maintained with proof of service history and I think you could get some goodwill towards a repair. Definitely keep us posted, very interested to hear how this pans out! |
OldDudesBimmer27.00 |
08-12-2022, 10:35 AM | #326 | |
Rep 49
https://f30.bimmerpost.com/forums/sh...2&postcount=18
2014 328i XDrive
2016 535i XDrive |
08-12-2022, 02:18 PM | #327 |
Rep 63
Model: 2013 BMW 328i XDrive
Mileage: 67k Timing Chain Status: Failed/Required Engine Replacement Oil change intervals: Every 7k miles Auto Start/Stop: Coded out Additional details Completely stock , never driven rough just a basic daily driver. Drove a mile to my gym, left an hr later, half way back at a stop light I hear some noise then it gets louder, I pull off into a side street and it dies on me. |
08-15-2022, 08:22 AM | #328 |
Rep 100
Drives: F30 328i BMW
Mileage: 77k (Bought as 3rd Owner at 54K) Timing Chain Status: No Oil change intervals: Every 3k miles since ownership Auto Start/Stop: Coded out at 56K Additional details BM3 Stg 1 @60k, had catless but removed (prepping for move to state with emissions), muffler delete. No major issues, just the loud N20 noises. Car was a CPO for the 2nd Owner prior to me taking over. Prepping to do all spark plugs and coil packs shortly just as preventive maintenance. |
08-15-2022, 02:23 PM | #329 |
Rep 22
2014 428i xdrive
Build date :6/2014 Bought the car at 33k Oil changes every 5-6k miles Auto start coded ff Drove in "sport" mode only since 33k Bootmode stage 2 FBO since 60k miles, currently 92k Spark plugs/ coils changed every 25k miles. Have not changed the timing chain. Weekly pulls of 120+ And highway miles 70%
IG: @Matty1k
08-15-2022, 03:58 PM | #330 |
Rep 12
I would like to share with you too.
Now I don't have timing chain issue but I still looking some professional garage to change N20 timing chain in Oregon too. BMW F30 328xi N20 ULEV Automatic Model: 2015 328i luxury Mileage: 45,300 miles Timing Chain Status: No problems (check by open oil cap) Oil Changes: use BMW service schedule by year and mileage (read from CarFax) Additional Details: Default engine / no tune up / |
