12-17-2019, 05:34 PM | #1 |
Rep 2,653
Apex Flow Formed Wheels for BMW F30 and F3x 3 and 4 series series | Built to Perform
For over 10 years, Apex has been the go-to wheel for BMW enthusiasts looking for the perfect balance between strength, weight, and cost. Our ARC-8 and EC-7 designs address the concerns of more and more racers and track day enthusiasts: long term durability, fitment, and performance. Our newer FL-5 and SM-10 designs provide a step-up in strength and true race wheel features like I-beam spokes and reinforced lips. ➡︎ Perfect fit without spacers ➡︎ Made to work with big brake kits ➡︎ 100% OEM compatibility, no extra hardware required ➡︎ Unbeatable warranty & 50% replacement program The lightest flow formed wheel we make. Also the most affordable. A deep lug recess allows for easy access for beefy impact sockets without scratching the wheel face. Available in Profile 1 (less concavity) and Profile 3 (deep concavity). The less concave profile provides increased caliper clearance on narrow applications, while the deep concave profile reduces weight and creates a stunningly aggressive appearance on low offset and wide width applications. Both profiles are available in 17”, 18”, and 19” diameters. Face profile is determined by offset and width and cannot be selected independently. Massive brake clearance & a plethora of fitments. The curved spokes of the EC-7’s face beautifully contour around some of the largest brake calipers available. The split "Y" spokes were carefully evaluated from every aspect to ensure light weight and remarkable strength. Available in Profile 1 (less concavity), Profile 2 (medium concavity), and Profile 3 (deep concavity). Profile 1 provides increased caliper clearance on narrow applications, while the deepest concave face reduces weight and creates a stunningly aggressive appearance on low offset and wide-width applications. All three profiles are available in both 18”, and 19” diameters. Face profile is determined by offset and width and cannot be selected independently. Gorgeous flow formed lip with I-beam spokes for reduced weight. Both the inner and outer lips are flow formed to stand up to all the abuse the street and track have to offer. The spokes of the FL-5 were designed to be robust where they need to be, and extra lightweight where they should be. Weight is reduced by CNC machining material out from the sides of each spoke. It’s expensive and avoided by almost every manufacturer, but affordable with volume. Available in Shallow, Medium, and Deep lip profiles. This maximizes spoke concavity and reduces weight on the FL-5 design. Lip size is determined by offset and width, and cannot be selected independently. Modern design with reinforced lips and I-beam spokes. Like the FL-5, the SM-10 spokes were also designed to be robust where they need to be, and extra lightweight where they should be. Weight is reduced by CNC machining material out from the sides of each spoke. Available in Profile 2 (medium concavity) and Profile 3 (deep concavity). The medium concavity is offered on narrow-width applications, while the deep concavity is offered on our wide-width applications. Concavity is dependent on width and offset, and cannot selected independently. The right solution for every application. An optimized car setup begins with the perfect wheel and tire fitment. Without model-specific attention to each wheels specifications, maximum performance is compromised. Each size was selected to find the right balance between a clean fit and the most grip possible. Each design's wide range of widths, offsets, and face profiles result in unique fitments ranging from 8.5" to 11" wide. Each wheel combines these features to meet the different brake caliper, strut, and fender clearance needs of each BMW model. Most vehicle models have options for wheels that range from direct-fit to aggressive for specialty applications. Daily drivers and professional racers don't have the same needs, so why should they be forced to buy the same exact fitment? 100% OEM Compatibility No need to change your wheel bolts, center caps, or TPMS sensors. All Apex BMW wheels were designed from the start to work with OEM 60º tapered hardware, which means both OEM lug bolts and aftermarket stud kits with the proper lug nut seat type will fit perfectly. All of our 5x120 BMW wheels use a 72.56mm center bore, no hubcentric rings or adapters are necessary. All wheels come with gloss black Apex center caps, but you can also snap-in your OEM BMW caps for a more OEM+ look. All Apex wheels accept OEM and aftermarket equivalent TPMS sensors, and any standard-sized metal or rubber valve stem. If the spokes or barrel of a wheel can’t clear your brakes, the wheel can’t be used at all. We’ve made sure all of our flow formed wheels clear OEM steel brakes spacer-free when the correct vehicle-specific designs and fitments are used. With many applications, even big brake kits will clear spacer-free. The 17" ARC-8 clears many kits up to 355mm. Our 18" wheels clear up to 380mm, including some variants of the Brembo GT kit, which has long been the benchmark as one of the toughest brake setups to clear. Our 19" wheels clear even the 410mm BMW Carbon Ceramic brakes. View our fitment guides to confirm brake clearance, or contact us if you don't see your setup listed. Weight Optimized We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn’t improve strength. The end result is a flow formed wheel with an ideal balance of strength and weight.Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. Apex flow formed wheels are officially tested and registered by the VIA in Japan, and we have the proof to back it up. Japan’s JWL is a standard for wheel load ratings. Our wheels exceed those ratings. Most manufacturers only meet the minimum, while some even fall below—yet they still claim to be JWL. Always verify load ratings before you buy. Additional Features Hub Centric - All APEX BMW wheels with a 5x120mm bolt pattern are purpose built featuring a 72.56mm center bore. No centering rings required. Center Caps - We don't charge extra for caps and we design our BMW wheels to be interchangeable with the OE roundel cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps. Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly. TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes. Lifetime Warranty All our wheels come with a lifetime structural warranty and 1 year finish warranty, so you can be confident in your purchase. Let’s face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable. Our unique Apex Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices. We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides. Apex BMW Wheel Gallery Questions? Call: 925-245-0773 Email: expert@apexwheels.com Web: www.apexwheels.com Hours: M-F 9a-5p PST
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 11-03-2023 at 06:36 PM.. |
12-17-2019, 05:35 PM | #2 |
Rep 2,653
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 12-16-2020 at 04:47 PM.. |
03-23-2020, 07:24 PM | #3 |
Rep 6,798
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
06-24-2020, 03:52 PM | #5 |
Rep 6,798
Sorry for the slow reply! We don't have any forum specific discounts available at the moment but we are currently running our 17" forged group buy if you are interested in that. We will have some additional group buys here in the near future that I can't delve into the specifics of so definitely keep your eyes open for those!
07-14-2020, 08:16 AM | #6 | |
Rep 546
I'm looking for a square set of 18" Flow formed Arc-8's |
07-14-2020, 12:50 PM | #7 | |
Rep 6,798
-Tom
08-06-2020, 11:13 AM | #9 | |
Rep 6,798
-Tom
08-06-2020, 05:31 PM | #10 |
Rep 44
Are Overstock sales eligible for the APEX360° Wheel Replacement Program?
"B-stock, blemished, scratch-and-dent, and close-out sales are not eligible for this program." |
08-06-2020, 05:57 PM | #11 | |
Rep 6,798
Any wheels listed as a part of our overstock sale will be fully eligible for the APEX 360 50% replacement program. -Geirsen
08-06-2020, 08:44 PM | #12 |
Rep 44
The terms also say that you have to buy 4 together for the replacement program, but for a staggered setup, only 2 may be on sale. Can I buy 2 and wait to see if the others go on sale during the "ongoing sale" as "products [are] updated every 2 weeks depending on inventory.". I'm not in a hurry as I have plenty of tread left on my current set of tires and am looking to replace the wheels only when time for a new set of tires.
08-07-2020, 03:58 PM | #13 | |
Rep 6,798
For the APEX 360 50% replacement program, the original purchaser’s order must be for at least four or more wheels in a matching square or staggered set to qualify. Separate individual orders for a pair of wheels placed on different dates will not be eligible for the 50% replacement program. These terms are set in place to keep this amazing APEX 360 program a viable option for our customers, and ensure we efficiently handle any inquires that we receive. If you have any additional questions regarding our APEX 360 50% replacement program, please do not hesitate to reach out! -Geirsen
08-07-2020, 05:27 PM | #14 |
Rep 2,815
Drives: F33 430 and F39 M35i
My daughter keeps curbing my 19s so I think I would like some 17s before I give her the car. I saw these on your blem sheet.
ARC-8 17x8.5 ET20 5x120 72.56 BMW Hyper Black like new, only had tires mounted on them ARC-8 17x8.5 ET20 5x120 72.56 BMW Hyper Black like new, only had tires mounted on them ARC-8 17x8.5 ET20 5x120 72.56 BMW Hyper Black like new, only had tires mounted on them ARC-8 17x8.5 ET20 5x120 72.56 BMW Hyper Black like new, only had tires mounted on them I was thinking 235/50/17 runflats for her. How much would this stick out past the fender? Car came with factory 400m wheels. I currently run 19" summers and 17" (17x7.5) snow tires. Thanks Assuming you still have those four in stock. If not, I'll keep looking. Last edited by chowser51; 08-07-2020 at 06:31 PM.. |
08-07-2020, 06:58 PM | #15 | |
Rep 6,798
If you actually order these, be prepared to dial in plenty of negative camber in the front and roll the fenders in the rear. Otherwise, I'd recommend taking the easy way out and going with the 17x8.5 ET40s instead. One other thing to point out is that if your daughter is curbing the wheels now, buying a wheel that actually pokes out beyond the fender probably isn't the best idea even if there will be extra tire sidewall to protect them. Lastly, all blem sales are final so you'll want to be really sure that this is a setup you want before ordering. If you'd still like to order them, shoot us a message at GarageSale@apexraceparts.com! You will certainly be one of the only F30s running around on E30 M3 Spec wheels if you make it work. -Tom
chowser512034.00 |
08-20-2020, 11:12 AM | #17 | |
Rep 6,798
At this time, we do not have any BMW 17" wheels as a part of our overstock sale. I highly suggest joining our newsletter to stay up to date with any future promotions applicable to the wheels you are looking for! -Geisen
08-31-2020, 06:47 PM | #18 |
Rep 6,798
APEX Overstock Sale Too much of a good thing! Some of our wheels have been idling on our shelves for too long! In order to make more room for exciting fresh inventory, we've decided to put select wheels on sale! This will be an ongoing sale and the products will be updated every 2 weeks depending on inventory. Don't see the offset or width that you are after? Check back in a few weeks! You never know what might go on sale! Head over to our website to check out the sale now!
11-06-2020, 02:59 PM | #19 |
Rep 6,798
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 11-12-2021 at 06:47 PM.. |
11-10-2020, 06:58 PM | #21 |
Rep 6,798
I don't have any details at this time, but historically we typically do have a Black Friday sale.
