04-20-2023, 04:32 AM | #1 |
Rep 16
F36 NBT EVO (ID6) with MMI and G30 10.25 screen restart issue
I have been using a Droid UK MMI box with my F36 for a while with no problems.
Recently I decided to upgrade my 8.8 screen to 10.25 and purchased a 5 series G30 NBT EVO ID6 10.25CID (PN: 8715339). After installing and coding it the new screen works 100% when Im using the ID6 interface. However, I get random reboots of the BMW head unit when using the MMI interface for Android Auto. The MMI goes blank for a few seconds but if I go back to the BMW ID6 interface it shows that it is rebooting. I have the following trouble codes set. So far I have replaced the LVD cable but it hasn't helped. I wonder if the CID coms check is triggering the reboots. Maybe this can be disabled...? Has anyone else experienced this or know where I go next? |
07-16-2023, 12:19 PM | #3 | |
Rep 5
I think problem is in your MMI box. Or it cant work with G30 display. Or , you can check what version of DIsplay is you use. I can got MGU display which is different from NBT EVO So far I have replaced the LVD cable but it hasn't helped. |
07-16-2023, 01:37 PM | #4 |
Rep 1,590
"I wonder if the CID coms check is triggering the reboots. Maybe this can be disabled...?"
I think this is likely. I only have an NBT HU with an MMI, and seems like the MMI boots up before the car's HU does power up. And the MMI as part of its normal routine disconnects the HU's signal to the HU and substitutes its own signal to the screen. So, the car's HU or the network thinks that there is a break. I do not have MOST (do no know if EVO has), but I had similar CID errors and I added a fiber optic loop ($5 on Aliexpress) between the two HU MOST ports and the CID errors went away. Of course, there are still the CAN signals that can result in errors if interfered by the MMI's somehow. The Chinese who write the firmware for the MMI should start paying attention and wise up and add a delay in booting up the MMI and allow the car's HU to boot up first. This could eliminate a lot of the random issues.
07-30-2023, 01:26 AM | #5 |
Rep 16
07-30-2023, 01:33 AM | #6 | |
Rep 16
Thanks for this. On the EVO I do have fiber going to both of the MOST inputs already. Will check them and both CVS cables when I next get the car dash. |
10-26-2023, 03:20 PM | #7 |
Rep 4
