BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F30 - Rear Spacers on 19's
      06-04-2014, 11:27 PM   #67
black_beauty
black_beauty's Avatar
Drives: a really nice BMW
H&R for F30, no coilovers for xDrive
320i, 328i, 335i xDr
http://www.ecstuning.com/BMW-F30-335...d/G-L/H-and-R/
320i, 328i, 335i RWD
http://www.ecstuning.com/BMW-F30-335...d/F-I/H-and-R/
328d and xdrive
http://www.ecstuning.com/BMW-F30-328...d/F-K/H-and-R/
      06-06-2014, 08:13 AM   #68
tlak77
Drives: F30 335i
Originally Posted by TPA335 View Post
I have H&R 10mm spacers up front and 13mm rear. I used 40mm wheel bolts up front and 43mm bolts in the rear. This is what was recommended to me by H&R and I've had no issues. I got 8 full turns on the fronts and 9 turns on the rears. BTW, ECS has (at least had) the best pricing on the H&R spacers and wheel bolts.
I ended up getting 10mm ECS spacers with included bolts for the front; and 13mm HR for the back with 40mm bolts.
I would probably go with the same brand all around but ECS does not have 13mm and HRs 10mm were back order. Ill have little color mismatch...
T
2013 335i F30
B45, LCSW, ZMM, ZDH, ZPP, ZTP, 337, 2TV, 428, 494, 688, 6AA, 6AB, 6VA
Flickr
      02-19-2015, 07:13 AM   #69
Bedista
Bedista's Avatar
52
Drives: 328i
Originally Posted by 335i-SG View Post
Yes, my pics below are with spacers and springs installed.
My opinion:
10mm in front is perfect, 15mm in rear is a bit to aggressive but flush with my stock bubble tires. With different tires it could be perfect.
12mm would have been perfect but H&R only makes 5mm, 15mm & 20mm for rear. 5mm, 10mm, 13mm, 15mm, 20mm front. 12mm rear is supposedly not safe but some have done it anyway with different brands. You can read why by searching this form.
H&R Sport springs:
I feel less body role, slightly stiffer but comfortable and the sport drop looks sporty and classy. My car has not bottomed out on big pumps but my biggest issue is with small road fluctuations. The front end seams to bounce a bit. Bounce is a little to strong a word but its bad enough that I will eventually change to coil overs.
Overall I'm happy considering the look for the low cost.
Nice! Is 10mm pretty flush? I'm debating wether I would get 5mm in front or is the stock bubble tire just deceiving me on the last pic
      02-21-2015, 01:47 PM   #70
andrew 330i
it can never be too clean...
andrew 330i's Avatar
163
Drives: 2014 F31 M Sport Wagon
Originally Posted by RJCrew View Post
BMS 15mm rear and 12mm front with h&r sport... the look is too aggressive for me so thinking about putting 12mm for the rear and 10mm front.
~ I agree I think the 10 front & 12 rears are the right look ... without being overly aggressive.
'14 328xi wagon / m sport / white / red leather
kw v1 coilover kit / 19" staggered 351 M double spoke wheels / upper strut bar /
sport line grille & exhaust tips / 50% tint / painted reflectors / debadged / complete clear bra
      02-24-2015, 08:47 AM   #71
j13reyes
Drives: 2014 BMW 320i
I ran a 10/12 setup on my stock 18s. If you're lowered, a 15mm in the rear will rub
      02-24-2015, 11:53 AM   #72
tboooe
tboooe's Avatar
925
Drives: F36 428i GC, E36 M3 - gone :(
I run 10/12 BMS spacers on my F36 with stock suspension. With the Pirelli runflat sidewall profile which extends past the wheel edge this setup is perfectly flush up front and just a bit recessed in the rear. I imagine tires with a sidewall that does not protrude out as far as the Pirellis you can do 12/15 without any poke. Once I lower my car about 1" with coilovers, I will see if 12/15 works. Note that I am very conservative and do not like any poke at all.
Here is a shot of car:
My build thread
2015 428i GC - Alpine White - Coral Red - M Sport
      02-27-2015, 10:07 PM   #73
Bedista
Bedista's Avatar
52
Drives: 328i
Any vibration issues on the 10mm F and 12Mm R combo?
      02-27-2015, 10:56 PM   #74
tboooe
tboooe's Avatar
925
No vibrations using the Burger spacers.
      11-16-2015, 06:56 PM   #75
kzflags
kzflags's Avatar
95
Drives: 2017 C63 coupe
sorry for bumping a super old thread, but is it established that its unsafe to run a 5mm or 8mm spacer in the rear? seems to be some back and forth on that on this thread, but no one has attempted to run such a small spacer.
i will be lowered, running 18x8.5 et35 sq setup with 255/40 tires. i believe the rears will need just a tiny bit of pushing out.
i have a set of h&r 5mm spacers id like to put on...
      11-16-2015, 11:16 PM   #76
dcg71
72
Drives: F15 X5
I would say take a wheel off, install a 5mm spacer and see for yourself how much hub (or lack of) your wheel has to purchase on. Then decide if you feel comfortable driving like that.
Personally there's no way I would ever install a 5mm or 8mm spacer.
      05-11-2017, 12:06 AM   #77
ilkhanso
Drives: 2006 BMW 330I Sports Premium
I recently installed burger motor sports spacers. 12MM front and 15mm rear. It's the perfect stance IMO. Next step is to lower it with Dinan springs. Got the shockware installed a couple weeks ago and man, what a game changer it was.
CQVD33051.50
      05-11-2017, 12:22 AM   #78
rixride
rixride's Avatar
Drives: 2009 M3 e92 & 2007 328XI e92
I had the Dinan springs but eventually went with KW-V1's.
Best move I ever made.
I'm also running 15 front and 18 rear spacers with 442 19" rims.
No rubs what so ever.
Excellent stance.
Just say'n
      06-06-2017, 10:43 AM   #79
Sparky2
Drives: 2014 BMW 335i M Sport
I'm using 18mm rear, 12mm front burger spacers 6 months now, no problem. Not lowered though. Same rims as OP.
      08-08-2017, 01:49 PM   #80
overkill1125
overkill1125's Avatar
Drives: 2019 440xi Gran Coupe
Anyone use the VRSF spacers on their F30-32?
