BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > input on Wheel setup
      03-18-2013, 07:12 AM   #1
Trowa
Jack Bauer
Drives: 2019 330i xDrive, 2016 S1000RR
Post Will this setup work? input on Wheel setup needed.
Hello everyone,
I currently have a white 328i xDrive Classic line and am looking at upgrading my wheels to,
19" Alufelgen SF-71s in Titanium Gunmetal
19x8.5 fronts - 35mm offset
19x9.5 rears - 35mm offset
I'd like to put Hankook Ventus V12 Evo K110s
Tire Size Front: 235/35-19
Tire Size Rear: 265/30-19
Would this keep me to stock diameter?
Would this setup work on an xDrive?
Would I have any problems with this setup?
Your thoughts and opinions would be greatly appreciated. ^.^
      03-19-2013, 11:46 AM   #2
Trowa
Jack Bauer
119 views and no one can help?
      03-19-2013, 12:23 PM   #3
overkill1125
overkill1125's Avatar
Drives: 2019 440xi Gran Coupe
I have asked plenty of questions concerning many topics on this forum.
You won't find much answer cause the car is still new and not many people have it or have enough experience with the car to have any concrete inputs.
Over on e90post, you'll probably get your answer within minutes of posting.
You'll notice that there aren't many post in general in this forum.
Join the frustration until more people joins the club.
      03-19-2013, 12:52 PM   #4
diesel86
Drives: 2012 BMW 328i Sportline
I am not an expert on the xDrive suspension and how it differs from the measurements of a RWD car, but your sizes and offsets are pretty conservative so I wouldn't guess you'd run into any issues with rubbing unless you decide to lower the car eventually. I don't know what the offset is on your stock wheels, but am willing to bet they are pretty close to my sportline wheels, i.e. ET34. So that being said, an 8.5" rim with an ET35 should have no problem fitting especially with a 235/35 tire. The rear is pretty much the same story. With that offset, I wouldn't expect to have any problems with an 9.5" rim
I'm planning on running an 18x8.5 with an ET 30-35 on all 4 corners shod with 245/40-18's.
2012 328i Sportline - Black Sapphire Metallic - 8AT Sport
I pronounce it "Beemer" and turn my fog lights on even when it's not foggy.
      03-19-2013, 01:01 PM   #5
Trowa
Jack Bauer
Thanks diesel86.
      03-19-2013, 02:09 PM   #6
tissot
hmmmmmmmm
Hong Kong
17
Drives: F30 - 328i
2006 330i  [0.00]
2006 330i  [0.00]
2006 330i  [0.00]
I also have a x-drive classic. Your specs seems to be fine but I would probably do 235/40/19 and 265/35/19 because that will fill the wheel well better since the x-drive sits so high up
I placed a order for my set last week and and my specs are
Front 19x8.5 35mm offset 225/40/19
Rear 19x9.5 38mm offset 255/35/19
Should be getting them within 2 weeks. I'll post some pics when I get them installed.
      03-19-2013, 10:43 PM   #7
Blake P
Kinda Like A Big Deal
Drives: F31 on order
265's might be a bit too aggressive on 9.5" ET35 if you plan to lower. Check out this one on similar specs, but slightly less wide tires: http://www.f30post.com/forums/showthread.php?t=814525
      03-19-2013, 11:59 PM   #8
Jackson743
Drives: 335i M-Sport/EBII/ED 12/5
I got an email recently from Mod Bargains.com. I believe they have those Alufelgens, and other wheels, are on sale. It's a March Madness sale.
EB 335i M-Sport / Euro Delivery / M-Performance Brakes / M-Performance Exhaust / Adaptive M Suspension / 19" M5 Reps / Michelin Pilot Super Sports
My European Delivery Thread http://www.f30post.com/forums/showthread.php?t=807429
      03-22-2013, 01:53 PM   #9
Trowa
Jack Bauer
more help would be appreciated.
      03-22-2013, 02:47 PM   #10
dcg71
72
Drives: F15 X5
235/40/19 and 265/35/19 will be closer to spec as far as diameter goes (~3mm diff for 265/35/19 vs ~10mm for 265/30/19)
      03-22-2013, 04:49 PM   #11
overkill1125
I was told that for a square setup it would be best to go with 225/40/19 all around.
Would it be better to go with 235/40/19 all around to have a more flush fitment?
      03-22-2013, 05:15 PM   #12
Blake P
If I was to go square, it would be 19x9" ET35 with 245/35/19 tires, then add rear spacers if necessary.
      03-24-2013, 02:00 AM   #13
SwnSng
Drives: 335i MSport - 6MT - GS
Originally Posted by Trowa View Post
Hello everyone,
Hope this helps.
      03-24-2013, 07:22 AM   #14
Trowa
Jack Bauer
Originally Posted by SwnSng View Post
Hope this helps.
Any issues? Rubbing? Did you do any suspension mods? What's your setup?
      03-24-2013, 07:52 AM   #15
ZigmundUK
ZigmundUK's Avatar
Drives: I20 IX M60 Oxide Grey
Hello everyone,
Here's the details of the 401 wheel size. Looks like the offsets don't match with your wheels.
http://www.alloywheelsdirect.net/bmw...401_wheel_3154
Running: G30 530d M Sport (B57) Mediterranean Blue
Running: I20 IX M60 Oxide Grey
Gone: F15 X5 40d M Sport (N57) Glacier Silver, E61 520d SE Auto (N47D20) Titanium Silver, F31 330d M Sport (N57D30A) Estoril Blue, E87 120d SE Auto (M47TU2D20) Sparkling Graphite
      03-24-2013, 10:18 AM   #16
SwnSng
Hope this helps.
Stock msport suspension. Wheels are 19x9.5 rear 255/35/19 tires.
No issue whatsoever, just like stock IMO except the car feels much more agile and quicker with lighter wheels and non run flats.
      03-24-2013, 07:07 PM   #17
Trowa
Jack Bauer
What are your front wheel and tires size? What are your offsets? Are they alufelgen rims?
      03-24-2013, 09:10 PM   #18
SwnSng
Fronts are 19x8.5. Tires are hankooks 225/40/19 in front.
Bbs ch-r wheels.
      03-24-2013, 10:41 PM   #19
onehungevo
Drives:
The 19x9.5 35 offset in rear will probably rub if you plan on lowering and properly aligning your car. My 19x9.5 38 offset is pretty flush.
      03-25-2013, 07:06 AM   #20
Trowa
Jack Bauer
Think I would have a problem with xdrive with this wheel and tire sizes?
19x8.5 - 225/40/19
19x9.5 - 255/35/19
Bbs ch-r wheels.
      03-25-2013, 11:00 AM   #21
SwnSng
19x8.5 - 225/40/19
19x9.5 - 255/35/19
Sorry, but I have no idea about x-drive cars.
      03-26-2013, 04:49 AM   #22
lmaleke
Hong Kong
Drives: shifting priorities for now...
Lightbulb
Quick question, and not trying to hijack OP's thread, so, Blake, will it be safe to say that for set up: 20x8.5 et34 with either 245/35 or 245/40 all around, would be a safe bet?
