05-28-2020, 09:41 AM | #1 |
Rep 110
emergency call malfunction? 2016 328i
Hey all
Found a few threads about it but seems like there isn't a solution that addresses every case. Long story short, my stepdad got a CPO 2016 328i last summer. A few weeks ago it started throwing the error 'emergency call malfunction' and a warning light appears on the dash. It comes and goes for days at at time. He called the service center and basically was told it's not powertrain and won't be covered by CPO, approx $500 to fix. Kind of dumb, considering that CPOd cars are supposed to essentially be 'brand new' and IMO something like this shouldnt fail in such a short time, but whatever. Anyway from what I can find, this is related to the telemetry unit in some way. Either it's the 'backup battery' or the entire unit itself which is in the trunk, or under the headliner. I checked the trunk as per https://www.newtis.info/tisv2/a/en/f...one/1VnYUrc0jT but pretty sure the small box i saw isnt the TCU, so I'm assuming its under the headliner, which seems like a pain to fix yourself. Other threads indicate that even service centers do a terrible job as well, damaging trim and creasing the headliner. Sheesh. 1 - Is there a known 'fix' to this error without spending time swapping out several parts? Some people say it's the backup battery. Others say the entire unit needs to get replaced. And yet others say it's something to do with the SIM card, connected drive, or the shark fin / antenna. 2 - If it is instead related to connected drive subscription, then how's that fixed, or even ascertained? He never paid for this service, but I would assume that if BMW 'turned off' the service (months later) from the previous owner, then it shouldn't be throwing errors like this. (Indeed, I never re-upped that for my car, and I don't get any errors like, and my SOS/GPS/ etc work fine.) 3 - Is it possible to just code this out so the error message just doesn't show? Thanks for looking |
05-28-2020, 02:04 PM | #2 |
Rep 919
OP I wrote a thread about it here...did it a month ago...just replaced my telematics control unit battery in the headliner.
I only broke one small clip...put it in my notes. Then you clear the codes and you're done. No more annoying message or Yellow warning triangle. https://f30.bimmerpost.com/forums/sh...ght=telematics
CrumbyButter24.50 |
05-28-2020, 04:58 PM | #3 | |
Rep 110
03-11-2022, 06:00 PM | #4 |
Rep 9
Hello. Were you able to resolve this issue? If yes, can you kindly help with how you fixed it? I’m seeing the same issue on my 2016 x320i. Thanks.
03-11-2022, 06:44 PM | #5 | |
Rep 3
03-11-2022, 06:49 PM | #6 | ||
Rep 9
03-11-2022, 06:59 PM | #7 | |||
Rep 3
03-11-2022, 07:31 PM | #8 |
Rep 919
The coding might eliminate the light, but also, probably, the feature, which might be worth a $50 battery and some aggravation getting to it.
If you're in an accident, the battery for the car disconnects, so the tcu battery powers your call from the car for emergency services. Might help if you're alone and unconscious on a dark, deserted road somewhere. I just hated seeing the yellow triangle so fixed it. Coding it out seems okay if you can live without the feature.
03-11-2022, 07:36 PM | #9 | ||||
Rep 9
03-11-2022, 07:56 PM | #10 | |
Rep 180
Seeing that you have a 2016, have you had the 4G upgrade performed? If it's truly the battery, BMW will cover the cost when the TCB2 is upgraded. Note-you must have factory navigation for this to be applicable. |
Billfitz8246.00 |
03-11-2022, 07:57 PM | #11 | |||||
Rep 3
The message you would usually see on the dash on startup for the Emergency (see picture attached) is no longer there due to the coding .. To reiterate, I currently still have a CEL on my dashboard however I no longer have the message of the Emergency Call Malfunction neither on my dash or iDrive system. Picture attached isn't mine btw, car is currently stored so I'm using it as reference. |
03-12-2022, 01:46 PM | #12 | |||||
Rep 180
If applicable, the 4G campaign is offered at no cost, regardless of ownership or warranty. I'd reach out to BMW and see if your car is eligible, although it sounds like it may have only been offered to owners with an active Connected subscription. https://www.bmwusa.com/content/dam/b...pdf/3G_FAQ.pdf |
03-13-2022, 08:39 AM | #13 |
Rep 110
Just to update everyone on this... it was my stepdad's car. He was ignoring it for a while until the car went in for another repair (oil level sensor) and had the shop take a look at the telemetry thing while it was there.
I believe all they did was disconnect the unit, iirc it was under the headliner (328i), he didn't want or need it. I guess a replacement battery would be the alternative, or possibly the entire unit was bad. Also, it didn't trigger a CEL, just the SOS malfunction message. Last edited by CrumbyButter; 03-13-2022 at 12:17 PM.. |
03-26-2022, 09:33 AM | #14 | |
Rep 40,793
Requirement is: "In order to use the PM system and be a full fledged member of this community, you will have to make 4 post replies and wait 1 hour for your account to be upgraded."
03-26-2022, 10:27 AM | #15 | ||
Rep 9
03-26-2022, 10:28 AM | #16 | |
Rep 9
03-26-2022, 12:12 PM | #17 |
Rep 40,793
03-04-2023, 09:03 PM | #18 |
Rep 1
Drives: 2017 BMW 330i
Hey all, I have the same issue that started about 7 months ago, but it has gotten worse somehow. It used to only show the ‘emergency call malfunction’ warning about once per month. Now it shows the warning and my rear turn signals will not work causing hyper flash. They are LED lci tail lights and should not have this issue. Once the car is restarted everything functions perfectly.
