02-16-2023, 12:34 PM | #23 | |
Rep 27
I ended up getting (2) 6 packs of the Castrol OW-30 Euro blend since its LL approved. Was rushing a little to since I wanna do the oil change this weekend. Didn't have much luck finding a single quart online or last night at AdvancedAutoParts. Their system was also weird with finding that blend. Pretty happy with my decision - especially since off of Amazon. |
Skyhigh1889.50 |
02-16-2023, 02:41 PM | #24 | |
Rep 106
Wires1645.50 |
02-16-2023, 03:08 PM | #25 |
Rep 27
02-16-2023, 03:08 PM | #26 |
Rep 3,877
0W30 is relatively exotic in Europe too, as viscosity. 0W40 and 5W30 are way more common.
02-16-2023, 04:25 PM | #29 |
Rep 106
It calls for 0W-20 all the way up to 15W-40. As long as it meets the spec and right for your climate and application. Lots of guys running high boost use 15W-40.
02-16-2023, 04:29 PM | #30 |
Rep 3,877
And that’s the point - there is no one-fits-all solution when it comes to oil.
Hence why there is a range available.
02-17-2023, 05:12 PM | #31 | |
Rep 4,877
https://f30.bimmerpost.com/forums/sh....php?t=1966435 |
02-17-2023, 05:15 PM | #32 | |
Rep 4,877
If you are heavily tuned, it's just something to consider. |
02-18-2023, 08:18 PM | #33 |
Rep 27
So an updated.
Got my Castrol Ow-30 Euro Car blend from Amazon but it doesn't list the BB LongLife-01 spec on it. Amazon pic showed it. Same blend and everything but doesn't list same specs. Does it matter or oil is oil? Just a double check since I have 2 days before I do my change (waiting on filter). |
02-18-2023, 09:51 PM | #34 |
Rep 304
Castrol was BMW approved supplier for years. Then they had a fall out for 4-5 years when Shell won the contract. Subsequently, Castrol got it back. You probably got the oil made during the time it was not BMW certified, although the formular had not changed.
Billfitz8244.50 |
02-19-2023, 02:33 AM | #35 |
Rep 3,877
Get the data sheet of the oil online, from Castrol’s webpage! If it lists BMW’s approval - you are fine. Make sure it is exactly the same oil though.
If not - I’d be cautious about using it. Oil is not oil, although your car will not explode if you use it.
02-19-2023, 07:56 AM | #36 | |
Rep 10,355
BMW doesn't charge royalty fees. I don't know where people get this information. The blender pays for the tests and it's not expensive.
"Drive more, worry less. "
02-19-2023, 08:15 AM | #37 |
Rep 4,877
When I bought oil the change before, BMW branded bottles of LL rated oil wasn't any more expensive that other brands of non-LL rated oil (Mobil, Castrol, Quakerstake, etc). They all were about the same price.
It's just harder to find that euro spec oil in North America -- unless it's 0W40 if I recall. |
02-19-2023, 08:32 AM | #38 | |
Rep 10,355
BMW like all automakers became extremely sensitive to fuel efficiency. BMW responded in a couple of ways when it came to choice of lubricant. First they started using and recommending "FE" oils for existing engines such as the N20, N55, etc. These were slightly thinner 30w and some 20w (N20). Second, they wanted the new B-series engines to be able to use 20w as factory fill. Because of this focus on fuel efficiency and the fact that these cars were certified on the thinner oils, BMWNA will never recommend the heavier LL04/LL01 oils for the current lineup. 0w16 is around the corner.
02-19-2023, 08:33 AM | #39 | |
Rep 10,355
02-19-2023, 10:31 AM | #40 | |
Rep 3,877
02-19-2023, 10:34 AM | #41 | |
Rep 3,877
All of this has nothing to do with royalty.
02-19-2023, 11:05 AM | #42 | |
Rep 27
Thanks for help all. Don't know if future oil changes will stay focused on this oil, might switch to Liqui Moly or Motul. who knows. |
02-19-2023, 11:57 AM | #43 | |
Rep 16,088
If you don't think there's some serious quid pro quo going on between BMW and Castrol you're in an alternate reality.
alohasurftoad3081.50 |
02-19-2023, 01:13 PM | #44 | |
Rep 10,355
This is 5w40 all the way down to 0w20. These engines are used worldwide with variation in fue quality and emissions compliance. BMW like all automakers have market dependent specifications.
