02-16-2023, 08:06 AM | #1 |
Rep 55
Oil leak on top of N20 engine
My N20 engine, 2012 328i, seems to have an oil leak on top of the engine. There is oil collecting just in front of the oil filter. See picture. It looks like it might be coming from the oil filter cap but I torqued it and there doesn't seem to be any oil leaking there. Any ideas? Also, what is that thing in front of the oil filter?
02-16-2023, 08:38 AM | #4 |
Rep 975
Could also be coming from the oil filter cap if the o-ring that goes around it was improperly installed during the filter change. That oil covered alternator is worrying.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
sspade2466.00 |
02-16-2023, 12:48 PM | #5 |
Rep 55
02-16-2023, 12:50 PM | #6 |
Rep 975
Ideally, you would want to clean all that oil up to see where it's actually coming from. A new oil filter o-ring is just a tad easier than the OFHG. I'm truly hoping it's the former.
However, as I look closer, I am seeing oil on the upper coolant hose and pretty much when I see that, it's almost always OFHG.
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line Last edited by Fliplegend; 02-16-2023 at 01:10 PM.. |
sspade2466.00 |
02-16-2023, 03:38 PM | #7 | |
Rep 55
02-16-2023, 03:42 PM | #8 |
Rep 975
Fortunately there is an excellent FCP write-up/video that walks you through it. Good luck!
bryanbrian25.50 |
02-27-2023, 07:33 PM | #9 |
Rep 55
Yes, I watched the FCP video. Very very good one. After watching I realized that the leak could be from the oil cooler and not the filter housing gasket. So I just changed that part, which does not require you to remove anything else. During removal I noticed one of the bolts was not torqued correctly but I replaced the gasket anyway. So far so good, no leak right now.
oil leak |
