09-30-2015, 06:23 AM | #1 |
Rep 15
Difference in volume between sources
Hello! I've been trying to find any threads regarding this but i have found none. I just want to know if someone else have experienced that music over bluetooth/iPhone is significantly lower than for example FM? I need to have half the volume to listen on normal volume and obviously when switching to FM i almost get deaf.
I use iPhone 6 with iOS 9, Apple Music and i have max volume on the phone. Is it or is there actually something wrong? EDIT: Car, 2016 navi prof. H/K sound. Last edited by mr30_328; 09-30-2015 at 06:24 AM.. Reason: Forgot car |
09-30-2015, 08:02 AM | #2 |
Rep 37
+1 - Volume output on external sources are much better via the cable than BT. Sound quality is also better. I think its just a feature of the BT rather than a fault.
09-30-2015, 08:06 AM | #3 |
Rep 267
09-30-2015, 08:11 AM | #4 |
Rep 4,724
It's normal. Just use a USB y cable or snap in adapter. I refuse to stream BT audio in my car because the quality sucks.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
09-30-2015, 08:30 AM | #5 |
Rep 15
Ok, great, it's not only me then. But on my '13 328 i did not have the same issue even though streaming over BT. I agree, the quality is worse than when using cable but i still think it's ok. At least more OK than getting deaf because of improper volume settings (and the inability to change them)
Thank you guys! |
09-30-2015, 08:41 AM | #6 |
Rep 1,668
The issue you describe is very valid but may not be a limitation within the BMW radio. The output volume can depend on the input level from the source that it is being played. This means via bluetooth versus USB versus radio/sirius. The input level may be controllable via the volume on the input device albeit phone, tablet, ipod etc. If you try that, as well as the aux input, and cannot get a boost in the volume levels then certainly you can say that there is a limitation in the BMW radio itself. If you have gone through this troubleshooting already then please disregard.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
10-01-2015, 01:54 AM | #7 |
Rep 15
I tried using the USB cable yesterday with the same result. I also tried both Apple Music and Youtube to rule out the possibility that the actual app was the cause. I will try to dig out a 5s with iOS 8.3 to see if it has to with the phone or the OS version.
10-01-2015, 06:53 AM | #10 |
Rep 2,744
Is there any evidence that Bluetooth still sucks? I know earlier versions had limited bandwidth, but v4 (which both the car and modern phones support, I believe) supports up to 24 Mbit/s, which is plenty.
01-12-2016, 01:26 AM | #11 |
Rep 15
UPDATE:
I tried USB-connected iPod Nano yesterday with the same results. Switching from Nano to FM makes me deaf. So now i tried IOS8, iPhone 6 and iPhone 5, and iPod. Not sure if i need to do anything else to rule out device-issues... |
01-12-2016, 03:20 AM | #12 | |
2JZ-GTE
3038
Rep 3,992
01-12-2016, 04:16 AM | #13 |
Rep 114
Hello
Same problem here, connected trough snapin IOS 9.2 tried everything but no solution FYI when connected trough usb or snap in the volume on the Iphone or android device doesn't matter Gran coupe 2014 Last edited by F36420I; 01-12-2016 at 04:21 AM.. |
01-12-2016, 10:48 PM | #14 | |
Rep 1,623
Don't ask why I switch from Sirius to FM....
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
01-15-2016, 11:01 AM | #16 |
Rep 15
My 2015 328i has the same issue also. I actually use the AUX IN and the volume is lower compared to the FM/Sat radio. I turn on the volume all the way up on the phone. This is on a Samsung Note 4.
