BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 LCI - poorer suspension or the mistake?
      12-06-2015, 04:11 PM   #1
felixo
Poland
Drives: Waiting for F30 320d LCI :-D
Hello,
This is my first post on Bimmerpost.
I am planning the f30 LCI purchase. I tested pre-LCI (316 i). I like that suspension very much. On wheel rims of 17 inches. Very \ "dignified\" amortizing. Two days ago I tested LCI 318d on wheel rims of 18 inches. It didn't appeal to me. Much tougher suspension. Similar to the VW Golf? ;-)
OK. I know: there were 18inches. And LCI has a tougher suspension according to press information.
However I discovered something... Possible that F30/F31 LCI have a "cheaper" and "full version" of standard hanging depending on the engine.
Here is detailed tech spec new F30/F31 LCI:
https://www.press.bmwgroup.com/globa...tem=node__4142
In that specification models 318d, 320i, 330i, 340i only have:
"Aluminium double-joint spring strut axle with displaced camber".
Rest of engines (318i, 316d, 320d, 330d) have "full" suspension:
"Aluminium double-joint spring strut axle with displaced camber, small positive steering roll radius, transverse force compensation, anti-dive".
Pre-LCI models - all have the same "full" suspension.
Questions:
1. Is it a mistake?
2. If not, what's that supposed to mean? How it is important for comfort?
3. Why do some models have a "poorer" suspension?
4. Why 318d only has "cheaper" suspension? Other diesels have "full".
5. Whether somebody tested and can express the opinion about the practical difference in the work of the pre-LCI and LCI suspension?
Regards
      12-07-2015, 08:13 AM   #2
Daftasabrush
Fool
Daftasabrush's Avatar
England
1857
Drives: F31 340i
I'd put it down to a mistake, especially considering the 340i is listed as having single pison front brakes: "Single-piston floating-calliper disc brakes / vented"
They're actually fixed four piston callipers.
      12-07-2015, 12:06 PM   #3
cryptocar
cryptocar's Avatar
Drives: 13' F30 385xi VNV Speed Custom
Originally Posted by felixo
Hello,
Questions:
1. Is it a mistake?
Regards
Most of the ones with a "full suspension" are diesels too. Could have something to do with it.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
      12-08-2015, 03:36 PM   #4
felixo
Poland
I have replay from BMW in Munich:
"It is a translation error. All BMW 3 Series have “Aluminium double-joint spring strut axle with displaced camber, small positive steering roll radius, transverse force compensation, anti-dive.” We will correct that."
3 series, bmw, f30, lci, suspension
