01-13-2016, 10:49 PM | #1 |
Rep 1,627
340 X-Drive 0-60 in 4.2?
Sorry if this is a re-post, Autobytel posted this today. Thoughts? (other than that I have too much time on my hands to watch Autobytel vids on youtube)
M4 in MG | 6 MT
01-14-2016, 12:50 AM | #3 | |
2JZ-GTE
3038
Rep 3,992
01-14-2016, 07:00 AM | #4 |
Rep 4,724
I'll cause an uproar:
This is why AWD should be offered in M vehicles. Cars are getting so powerful they need more traction to get the power down.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
01-14-2016, 09:59 AM | #6 |
Rep 939
There are so many variables when it comes to 0-60 times. A huge variable is traction and obviously all wheel drive helps tremendously. Temp is another important variable. Looks like it's about 28 degrees and the turbo loves that. An M with that temp and rear wheel drive only on summer performance tires would have a major traction issue and a relatively bad 0-60.
01-14-2016, 10:09 AM | #7 |
Rep 499
Drives: 2016 F80
On top of everything everyone else has said the BMW published 0-60 for all their cars is usually fairly conservative so expect actual performance of the M's to exceed published specs as well.
01-14-2016, 11:28 AM | #8 |
Rep 687
01-14-2016, 01:02 PM | #9 |
Rep 421
Not sure I understand. Can you explain what you mean?
2016 340i xDrive, msport, estoril/saddle/anthracite, blk kidney grills, 400m mixed summer, adaptive m, technology, lighting, cold weather, drivers assistance, enhanced usb
01-14-2016, 01:10 PM | #10 |
Rep 687
They are counting how many seconds it gets to move the car from 0 to 100km/h using the dashboard speedometer as reference. So it took roughly 4.2~4.5 seconds to reach the "100km/h" mark on the speedometer.
We all know the speedometer is inaccurate. So I wager that the delta in time (from specs to the video results) is due to the fact that the car never reached 100km/h, and it would take it longer to reach 100. |
WolfpackSV0.00 |
01-14-2016, 02:01 PM | #11 | |
Rep 893
I know it's not a B58 but I can't resist posting my 0-60 record:
2019 SG M5C
2015 SO M3 6MT 2015 BSM M235xi |
01-14-2016, 10:22 PM | #12 | |
Rep 33
Using Road and Track times for the 335i (in their article where they pit it against the Lexus, Infiniti, and Cadillac): from 60 MPH, adding 1 second gets you to about 67 MPH. The speedometer is not off by that much. And that is with the 335i with 20 less HP than the 340i. |
01-14-2016, 10:46 PM | #13 | |
Rep 1,627
M4 in MG | 6 MT
01-14-2016, 11:16 PM | #14 |
Rep 271
Motortrend clocked a 4.4 0-60 on a 335i xDrive with PPK, so 4.2 from a B58 isn't completely outlandish. I'd say it's definitely mid to low fours.
I tried LC with traction control fully off recently. The grip off the line kicks you in the face, holy moly. |
01-16-2016, 08:38 AM | #16 |
Captain Crunch
168
Rep 548
Almost makes me want to change my 340i order to a 340xi order. But I dont want the xi suspension, squared tires or another diff to service.
On Order (in transit): BMW iX 50, Oxide Grey
Retired: BMW Welt Delivery 4/14/16: European Delivery - 2016 340i EBII/Saddle - ZMP | ZCW | ZDA | ZLP | ZTP | M Adaptive | Rear Shades | MPPSK Before and After Dyno Retired: 2011 335D Space Grey/Black - ZSP | ZPP | ZCW | 6FL | Sat Radio | Nav | $600 Base Audio Upgrade |
01-16-2016, 09:52 AM | #17 |
Moon Parasite
654
Rep 1,336
The new 7 series can pull a 4.3 0-60 and it weighs 4800lbs
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
01-16-2016, 10:44 AM | #18 |
Rep 162
Drives: 2018 G30 540i xDrive
If you're only worried about handling, the adaptive dampers feel about the same on both (I really tried to feel the difference and couldn't). Also, you can get non-squared tires with either M-Sport or Track handling. That's what I ended up going with... 2 weeks to go
01-16-2016, 01:17 PM | #20 | |
Captain Crunch
168
Rep 548
It does appear you can select 400m with all season or mixed run flats. I assume that "mixed run flats" mean a staggered setup?
01-16-2016, 01:51 PM | #22 |
Captain Crunch
168
Rep 548
Great, thats what I thought. UGH, yeah I think with the video above that the x-drive is what I'll switch my order to. I just wish we had a car locally that was x-drive with m adaptive so I could drive it in Sport mode.
