BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Factory OEM F30 Wheels Offsets (18, 19, 20 inch) and Brake Sizes
Studio RSR
      03-13-2017, 10:35 AM   #177
BulsaraF36
BulsaraF36's Avatar
142
Drives: F36 435i M-Sport
Originally Posted by .BMW. View Post
Yes, those tires will work with RWD!
The rear tires are 3.5% taller than OEM sizes though.
so would that be an issue?
      03-13-2017, 10:56 AM   #178
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
No.
Actually helps to correct the speedo error that all BMW has from factory.
      03-13-2017, 10:59 AM   #179
BulsaraF36
BulsaraF36's Avatar
142
No.
I will buy these tires. Thank you for your help.
      03-27-2017, 10:40 AM   #180
Influence
Drives: 2020 X3M, 2016 X5 35i
Just to confirm:
I've got a 2017 340i (RWD) on order with the track package (so M Performance brakes). Going with the 19" 442Ms for the summer tires but being in NJ, will need to run a set of winters too.
Will the 400M 8" wide wheels clear the M Performance brakes of the track package? What about the 8.5" 400Ms? I'd most likely go with a square setup for the winters for easier tire rotation.
If I go with a square setup of the 8" wide 400Ms, will I need spacers to get them flush with the wheel wells? Easiest tire choice is 225/45/18, but I'd rather go a bit wider, like a 235 or 245 width setup.
Thanks!
      03-27-2017, 03:17 PM   #181
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
No spacers needed!
Go with square 8x18" ET34 style 400 wheels, no issues with brake caliper clearance even with M Sport brakes.
      03-31-2017, 09:38 AM   #182
Influence
No spacers needed!
If I put 245/45/18 Sottozero 3 RFs on do you think I'll have any rubbing issues on the fronts?
Thanks!
      03-31-2017, 09:45 AM   #183
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
No issues with rubbing!
      03-31-2017, 09:58 AM   #184
Influence
diameter on the 245/45/18 looks to be about 26.7" vs. the 26.1" on the 19" OEM summers that will be coming on the car - 2.3% difference in diameter, so I guess that should be fine and correct the speedo error a bit too.
      03-31-2017, 11:07 AM   #185
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Yes, that's correct!
      03-31-2017, 07:41 PM   #186
JackAdams
JackAdams's Avatar
80
Drives: '13 335xi
If your car came with 225 tires both front and rear your wheels are also square 8x18" ET34.
You can fit a square setup of either 245/40-18 or 245/45-18 MPSS on your square style 400 wheels.
Hi .BMW.,
I just picked up a 2013 335xi Sportline that came with a set of 18" 225 Pirelli RFT tires on style 397 rims. I have a set of Bridgestone Potenza RE050A summers from the 2004 545i I traded in. I had them staggered with 245/40R 18 on the front and 275/35R 18 on the back.
From reading through this thread -and all your very useful information - it would appear the 245s are the widest I can fit on my existing rims. Am I correct?
I'm thinking since I only used them for one season, I may just buy another 2 and run 245s all around. The 225s just look undersized for the car, imo.
Thanks in advance.
      04-01-2017, 12:54 AM   #187
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Correct!
      04-04-2017, 12:04 PM   #188
JackAdams
JackAdams's Avatar
80
Drives: '13 335xi
Correct!
Thank you!
Ohh, they have the Internet on computers now.
- Homer J.
      04-06-2017, 02:07 PM   #189
H2O
Drives: X5 3.5D, e46 330xi, 340xi
2017 340xi  [0.00]
I'm about to buy a 340i xdrive with M performance packages. I have a set of Apex ec-7 wheels which are:
18x8.5 et 35
18x9 et 31
Is there a way to fit this on the 340ix whitout rubbing the fenders? I was thinking going 245/40 square and maybe trying 18x9 front if it doesn't fit rear.
      04-06-2017, 02:44 PM   #190
Kid Red
Kid Red's Avatar
107
Drives: 2021 X5 40i
What is the ideal offset on 19s for the F30 to be just about flush? I don't want poke and I don't want it to be flush. I'd prefer just a hair inside being flush.
I've read that the F30 can't have a 12mm spacer on the rear due to hub length, has anyone made one that fits or is that still the case requiring a 15mm as the smallest?
I'm stuck between spacers on w/ 403m or 437 reps. However, 437m OEM & reps all sadly seem to be at or passing that poking threshold.
Current: 2021 Carbon Black w/Cognac X5 M Sport
Sold: 2018 Dark Graphite 540i M Sport
Sold: 2013 Mineral Grey 335i M-Sport
Sold: 2010 Sapphire Black E90 335i
      04-10-2017, 10:13 AM   #191
raybmw
Drives: 2020 g20 330i
Wheels recommendation
Correct!
New to the forum and my first 335. I see a lot of you guys doing 20's on the f30. I have a deal on velgen vmb7 20×9 +35 & 20×10.5 +45
what tire size is recommended for that setup?
Sorry for my bad english and thanks!
      04-10-2017, 02:20 PM   #192
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Those are very wide wheels for F30!
You need to run stretched tires to avoid rubbing, maybe a 235/275 setup.
      04-18-2017, 10:27 AM   #193
raybmw
Thanks for your help! I read in another thread by Velgen wheels and they said:
"This car is lowered on HNR Springs. You can run 20x9 & 20x10.5 with 245-35-20 and 285-30-20 and if you rung 19s it will be 19x9 245-35-19 & 19x10.5 285-30-19. NO RUBBING The wheels are HUB centric and you can use your oem Lug Bolts".
What do you think?
      04-18-2017, 10:38 AM   #194
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
9x19" ET35 with 245/35-19 will fit up front. 10.5x19" ET45 with 285/30-19 is an aggressive rear fitment for sure.
But if Velgen claim that it fits without rubbing I guess they knows better than me.
      04-18-2017, 11:21 AM   #195
raybmw
in my case i got the 20's. it would be 20x9 & 20x10.5 with 245-35-20 and 285-30-20. I think im going 275-30-20 rear to be safe.
Thanks!
      04-18-2017, 01:50 PM   #196
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Remember that those 20" tire sizes are 1" taller in overall diameter compared to the 19" sizes we discussed above.
To keep the diameter constant when moving from 19" to 20" the tire profile must be lower:
245/35-19 -> 245/30-20
and
285/30-19 -> 285/25-20
      04-18-2017, 04:59 PM   #197
zole2112
Modder of everything I own
zole2112's Avatar
147
Drives: 2013 335i Xdrive
I'm looking for wheels and tires for my 2013 335i F30 Xdrive Luxury pkg. Currently I have the square set up 225/45/18 et34. Most people in this thread are doing staggered but I want to do a square set up so that i can rotate all 4 tires.
What I would like to do is:
19x9.5 and 265/35-19
I will use spacers if needed, will this fit? I may put it on a rack this weekend to check for clearances with the current set up.
Thank you!
      04-18-2017, 11:36 PM   #198
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
255 square on 8.5" wheels would be the widest setup I can recommend.
I dont think there is room for 265/35-19 up front.
f30 3 series wheel offset, f30 3 series wheel offsets, f30 328i wheel offset, f30 328i wheels offset, f30 328i wheels offsets, f30 335i wheel offset, f30 335i wheels offset, f30 335i wheels offsets, f30 offets, f30 offset, f30 wheel offset, f30 wheel offsets, f30 wheels offset, f30 wheels offsets, wheel offset f30, wheels offset f30, wheels offsets f30
