05-07-2022, 03:06 PM | #1 |
Rep 409
Spark Plug Replacement
Everything that I have found online has suggested that BMW recommends replacing spark plugs at 60k miles.
I currently hav 38,900 miles, and yesterday I received a message on the 'My BMW App' informing me that in 1,100 miles I will need an Oil change and . . spark plugs. Are spark plugs monitored dynamically? Why would I need to change mine at 40k vs 60k ? All I can think of is that I have MPPSK. Does that put additional wear and tear on the spark plugs? |
05-07-2022, 03:23 PM | #2 |
Rep 2,200
BMW replaced our plugs with the CPO free maintenance at between 30-40k miles.
05-07-2022, 03:35 PM | #3 | |
Rep 409
I don't mind doing it - if there is an actual reason to do so. 20k miles early is not chump change . . (or chump miles lol) |
05-07-2022, 04:53 PM | #4 | |
Sedan Driver
389
Rep 1,018
05-07-2022, 07:30 PM | #5 |
Rep 7,607
Generally recommendation is to cut interval in half when tuned. MPPK is mild, so probably not totally necessary, but still worth it... just order through FCP and you will never pay for plugs again. I would do it at 40k.
05-07-2022, 07:31 PM | #6 | |
Rep 409
I guess, if I don't notice a damn thing, after getting new plugs . .I have my answer haha. |
05-07-2022, 09:40 PM | #7 |
Rep 295
Drives: 2016 340i X Drive
Per the Owner’s Manual: “Replace spark plugs at every 6th Engine Oil Service (approximately 60,000; all models except diesels).”
The dealer recommended I have the plugs replaced at my 6th oil change, according to the book. I had just over 50k miles on it. I did it myself. I’m guessing you’re right in assuming your replacement interval is tied to the MPPSK. |
05-09-2022, 01:15 PM | #8 | |
Rep 7,607
05-09-2022, 05:36 PM | #9 |
Rep 4,877
Its because your car is due for its 6th oil change. I got pinged by my dealer last week as well. According to the BMW service, it's 6 oil changes or 96k km / 60k miles. As much as that is "preventative maintenance", you really need to swap your plugs every 6 years, regardless of mileage? Do they really rot in there? First time I've ever seen such a thing.
My car is at it's 6th oil change and 55k km / 35k miles. And no, not changing them.... |
05-10-2022, 07:41 AM | #10 |
Rep 409
I have done some reading and have decided to move forward and get the spark plugs replaced. With the (mild) MPPSK tune and my oddly aggressive driving habits, my plugs should probably get changed out every 40k miles. With a more intense tune, every 25k miles. Not saying this is FACT, but that's the feeling I get from digging around online.
Oddly enough, the Dealer wins this one. We have a great Indy that only works on BMWs out here. Has a great reputation. But, I was a bit disappointed that their quote was almost $200 more than the dealer for my needs. Oil Change at Dealer: $99 Oil Change at Indy: $124 Spark Plugs at Dealer: $323 Spark Plugs at Indy: $512 Dealer has some good pricing under "Value Services" tab. We have two BMW dealers here, and only one is offering the value pricing on spark plugs. So, might as well save myself $200 now, rather than wait for 60k miles and pay $200 more, if that pricing has ended. On to the next one . . . |
05-10-2022, 12:51 PM | #11 |
Melbourne Red F32 B58
59
Rep 99
NGK Spark plugs - $160
Mobil 1 0w20 - $50 Oil Filter - $17 Do it myself and maybe cause a headache or two - $0 Make sure its a 14mm magnetic thin wall spark plug socket. -B58 Engine Just because I want to be cool Dinan Red Coil Packs - $230
Real drivers use 3 pedals. Its about connection.
05-10-2022, 12:58 PM | #12 |
Rep 975
I just have a regular 14mm spark plug socket with the rubber inside which worked great for extraction but for insertion, I taped the socket to the extender.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
05-10-2022, 02:34 PM | #13 |
59
Rep 99
Edited to make sure that I state its for a b58.
05-10-2022, 03:18 PM | #14 |
Rep 975
The B58 spark plug uses a 16mm? Thought most if not all BMW spark plugs use 14mm.
05-11-2022, 07:55 AM | #15 |
59
Rep 99
14mm 12point is correct for NGK 94201
05-11-2022, 09:49 AM | #17 |
Rep 2,128
I'm sure here spark plugs are changed every second service. So every 4 years.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
05-11-2022, 11:58 PM | #18 |
Rep 295
14mm thin wall socket is the correct size. Here’s the one I bought that fit properly.
https://www.fcpeuro.com/products/14m...nsion-cta-7654 Also, a bracket at the rear of the engine compartment must be removed to access the rear spark plugs. It’s not hard if you follow the procedure. Here’s one from YouTube. Last edited by Livetodrive; 05-12-2022 at 12:05 AM.. Reason: Added bracket removal procedue. |
Fliplegend1471.00 |
05-12-2022, 06:34 AM | #19 |
Rep 424
I'm changing mine this weekend, got all the tools and torque wrench, along with the NGKs. People say not to change coils as those should be good for a while, So I'm going that route. Dealer wanted close to 1k for ignition service but that may have included coil packs… it has to for that much.
//'17 F36 440i Mineral Grey
//MPPSK w/carbon tips //Apex ARC8 255/40/18 //MST intake //AutoTechnik brace |
05-12-2022, 06:39 PM | #20 |
Rep 409
I scheduled my Spark Plug service at one of the local BMW dealers here. Shockingly (even to them lol), they had the best price.
BMW dealer sites have a 'value service' link on the menu. You put in your year and model and it tells you what value services are available to you. Dealer 1: Offered Value Spark Plugs $323, and Value Oil $99. Plus ten other values. Dealer 2: Only offered Value Oil $99. None of the others. Seeing as I have already been to Dealer 2, I called them to see if they would price match the Value Spark Plug Service. They would not. He said "We are not participating in that sale". No worries . . . I called Dealer1 and they told me I was incorrect. $323 was not the price for me . It was $575! I said "okay. Please help me understand the difference between the $323 option you are advertising online, and the $575 version? What is the exact difference in those?" He said he would call me back haha. Then when they called back, the will honor the price. Great. Then, I called the local Indy shop (great reputation and I really want to start going there . . ), but they quoted $124 for the oil change and $512 for the spark plugs. Shockingly, they where higher on both options. Seeing as I don't have tools, and live in an apartment where it's not allowed to do work on our car in the lot . . . $323 was a pretty good price. She is scheduled for next Wednesday. |
05-13-2022, 06:19 AM | #21 |
Rep 975
$323 is actually not bad for that work. Good luck!
05-13-2022, 06:48 AM | #22 |
Rep 424
$323 with the spark plugs included??
