10-28-2022, 04:53 PM | #1 |
Rep 56
Should I buy OE starter?
I know OEM is the way to go. But the starters are like $380 on FCP EURO. The OE one is $160. Would you guys not recommend buying the OE? Or do you think it would be fine?
10-28-2022, 05:13 PM | #2 |
Rep 4,551
Drives: 2015 328d xDrive
OE is fine
10-28-2022, 05:36 PM | #3 |
Rep 770
There is a starter count reset that you 'should' do with either ISTA or other compatible scan tool after you replace the starter. I'm unsure what it's used for, but it MAY disable starting of the vehicle after X amounts of starts. It is for sure used with the stop/start calculations.
10-28-2022, 05:53 PM | #5 |
Rep 56
10-28-2022, 06:37 PM | #6 |
Rep 131
OE is BMW and OEM will be whoever supplies the part to BMW to put in their cars. They will be identical other than the removal of BMW trademarks. If not, then it most likely isn't OEM.
Wires1645.50 AndrewC198910931.00 |
10-28-2022, 09:41 PM | #7 | |
Rep 1,199
For the uninitiated: OE = Original Equipment = essentially identical to what came on the car. These are "Genuine BMW" branded parts OEM = Original Equipment Manufacturer = also essentially identical to what came on the car, but branded as the actual supplier (ZF, Mann, TRW, Mahle, Bosch, etc). This manufacturer makes the "Genuine BMW" part on literally the same equipment/process. The BMW logo is often ground off. OE "Genuine BMW" is almost NEVER worth the premium. Always go OEM.
10-29-2022, 07:55 AM | #8 |
Rep 1,818
what exactly is the worry if you're buying from FCP, it's lifetime warranty anyways. They're not gonna sell you some crap that won't last, otherwise their business model wouldn't make sense. That's why you never see really cheap chinese alternatives on there, only OE quality stuff
10-29-2022, 04:54 PM | #10 | |
Rep 10,352
"Drive more, worry less. "
JoHnMuir70.00 |
10-29-2022, 05:18 PM | #11 | ||
Rep 1,818
F32Fleet3574.50 |
10-30-2022, 11:27 AM | #12 | |
¯\_(ツ)_/¯
945
Rep 1,762
I might have to order my entire front suspension (struts with all parts on it) today/tomorrow to still get the refund. I don't want hundreds of dollars sitting in store credit which I don't know when I would use.
