05-20-2018, 03:03 AM | #1 |
Rep 7
Help Nbt Evo
Hi Guys
I have a BMW 335d with standard business navigation. I have just purchased a Professional Media NBT EVO removed from a 2018 335d shadow edition with the new interface iD6. I now have in my possession 8.8 screen, NBT EVO headunit, iDrive scroller and the ATM 4g GPS. How simple is it to retro this and code to my VIN or can someone please help?! |
05-20-2018, 04:16 PM | #2 |
Rep 765
There is plenty of info here for u. Try the search button. Sorry but no one wanna spoon feed someone wit so much info on the subject available here. That’s prolly why no one responded yet. I’ll get ya started tho. U need an emulator or expensive fsc codes so get that ASAP.
05-20-2018, 05:05 PM | #4 | |
Rep 10,473
http://f30.bimmerpost.com/forums/forumdisplay.php?f=412 |
05-21-2018, 02:51 AM | #6 |
Rep 7
05-21-2018, 08:20 AM | #8 |
Rep 342
If you want all the ConnectedDrive services to work, then you need to have the ATM and EVO coded to use the VIN of the ATM donor car.
I keep getting robbed because I leave the front door open..
I could close it but I feel doing so would be a victory for the thieves.... |
05-21-2018, 10:50 AM | #9 |
Coding ECU's remotely
445
Rep 1,172
To retrofit this it needs a fair bit of work...
If your car currently has an EVO iD4 system then you only need an canbus emulator and it can be fitted then coded to your vin - the ATM will replace your current unit. If you have an earlier system with TCB then you will need some extra wiring and the same canbus filter & wiring. I am based in the UK and can help you if you are stuck.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
