06-27-2017, 08:27 AM | #1 |
Rep 3,815
Need more bass
So looked at this before but could not make head or tail of it.
My car is a 2014 F30 with HK and NBT. I'm sure things have moved on any recommendations on quick plug and play upgrade to the OEM subs under the seats to improve the base a little bit. Modding bug is back as I'm bored post surgery recovery and trying to avoid modding the outside so sound system it is.
F30 335i M Sport - now departed
06-27-2017, 10:00 AM | #2 |
Rep 16,082
There probably isn't a quick and easy one. Replacing the woofers with units that in theory can go louder, because the cones are able to move further, does you no good if the amplifier lacks the power required to make use of that additional excursion capability. You'll see claims for magic woofers that in and of themselves will give huge improvements, but those claims are never backed up by real world measured data, because there isn't any.
As for going lower, even a change of amp and woofers is no guarantee, as the main factor limiting the low frequency response of the woofers is the size of the enclosures they're in. IMPO if you want to significantly improve on the bass a separate sub in the trunk is the best bet. |
06-27-2017, 10:19 AM | #3 |
Rep 775
Agree with Billfitz, odds are changing drivers and/or just adding an amp might not be enough. Added a powered sub by Bazooka and that solved it. You'll want the Audio Control unit plus custom harness from https://technicpnp.com .
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
06-27-2017, 10:46 AM | #4 | |
Rep 240
Look at Integral audio if you want a real upgrade of amp and speakers! Great kit but not cheap! I was looking at the Integral Audio gear for my UK base stereo system upgrade but they only currently do it for hifi cars not HK and base cars (they said it was in development months and months ago) If you want to stick with U.K. installers / suppliers look at audiofile-incar.co.uk they are based in Bishops Stortford. Top quality installers and upgrades. HTH Andrew |
06-27-2017, 11:16 AM | #5 |
Rep 3,815
Thanks all while a full upgrade to HK would be great aka what I had in my e46 I find the HK pretty good compromise and just woudl be nice to have slightly improved bass.
If sws8 / bavsound is still the way to go I think will run down that route. any pros /cons as to sws or bavsound. Though getting hold of bavsound might be hard in uk. cant find any resellers
