03-30-2016, 05:31 PM | #1 |
Rep 161
Front Negative Camber
I just installed wheels onto my car, I have a 2013 F30 328i xDrive and when I got my alignment done. It says that the front left side has about -1 degrees of camber and that if I want to fix it, I'd have to replace the bearing but I also plan to get the Bilstein B14 so could the coilovers be the solution or do I have to do anything else?
Benny Chen
04-01-2016, 11:56 PM | #2 | |
Rep 389
Drives: '13 F30 335i MSport
2013 GSM 335i MSport
04-02-2016, 12:11 AM | #3 | |
Rep 161
Benny Chen
04-05-2016, 03:32 AM | #4 |
Rep 4,515
Benn
Is your car in warranty ? 0.5 degree difference between L&R front camber is too much. BMW have swivel housings with different plus and minus 0.5 camber so it's an easy fix to fit the a swivel bearing housing to either reduce RHS camber or increase LHS camber. |
04-05-2016, 10:20 AM | #5 | |
Rep 161
Benny Chen
06-28-2016, 03:10 PM | #6 |
Rep 114
Drives: 2013 BMW 335i xdrive
@Bee Pee I have the same problem, can you explain more on the swivel housings?
06-29-2016, 02:48 AM | #7 | |
Rep 4,515
http://www.realoem.com/bmw/enUS/show...diagId=31_0956 item # 2 below
Current '22 X3M LCI.. |
07-01-2016, 12:43 PM | #8 | |
Supreme Allied Commander
3839
Rep 54,348
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
06-07-2018, 08:36 PM | #9 |
Rep 357
Question, I have the exact same issue, 3 years alignments where the front went from L -0.6 R -0.6 to -0.9/-0.6 and -1.1/0.6. How do you check for the subframe, and can it be adjusted, or will this be a hub/swivel bearing type repair?
06-07-2018, 08:55 PM | #10 | |
Rep 357
Initially the car had -0.6 / -0.6 front camber. Somehow, that became -0.9/-0.6 and -1.1/-0.6 over these years. Perhaps that road cutout at 50 mph, thanks Pirelli RFT! Yet... it increased since? Attached my last alignment, today. Swivel bearing then? |
06-07-2018, 10:39 PM | #11 |
3839
Rep 54,348
Drives: F80 M3
What does your alignment tech recommend you do?
11-21-2018, 10:21 AM | #13 |
Rep 2
Allowable camber difference between left and right?
A similar question here.
I bought a 2013 435i M Sports and had its wheels aligned yesterday, but the tech couldn't put the front left camber back within the spec. The front left camber is -1.12 while the right side is -0.12. The spec is (-0.04, -0.54). Is this difference allowable? I also wonder what could have caused the camber change. The seller said it never had an accident or hit curbs but I never know... The steering wheel was off-center to the right (\) and the car was pulling slightly to the left before alignment but these problems seem to have been resolved after alignment. The front wheels have new standard tyres 225/40R19 93Y, but don't think this can be related to the issue... Any advice? |
06-12-2022, 03:39 PM | #14 | |
Rep 7
Did you found out what was the problem or how did you solve it? Can the subframe be moved? Thank you |
08-07-2022, 05:07 PM | #15 |
Rep 421
Drives: 2017 F31 328dx
I'm having issues where my LF is not in alignment with RF. Even installed camber plates for my alignment guy to help fix it when I lowered it on Eibach springs and put in Bilstein B8's. He still couldn't get it right. Has me wondering if it's a bent thrust arm or something as I've already changed the shocks.
08-08-2022, 05:03 PM | #16 | |
Rep 8,492
Camber ? Caster ? Toe ? There are many possible causes of poor alignment between including worn bushes, bent arms or track rod ends, different ride heights, bent chassis, etc. If you can elaborate on the problem it may help to isolate some of the possible factors.
08-08-2022, 07:44 PM | #17 | |
Rep 421
08-09-2022, 04:16 AM | #18 | ||
Rep 8,492
Are you running OEM arms and bushes ? Most quality camber plates will go to at least -2.5. There shouldn't be any need for adjustable length arms for a road spec geo if you are already using plates. Something definitely does seem right.
08-09-2022, 06:55 AM | #19 | |
Rep 72
If it’s out of spec by so much then something is bent and needs replacing first. If the alignment guy isn’t aware of that then I would advise finding a new one. |
08-09-2022, 09:54 AM | #20 |
Rep 1,127
I am surprised to hear there is a camber issue up front. I don't have a X drive, but on my RWD F30 there is no camber adjustment capability from the factory on the front axle. It should just be neutral from the factory, maybe there is something worn out or out of spec causing the issue? If the shop that says it's out of spec doesn't have a solution maybe a visit to another shop might be in order. I wouldn't just start suggesting fixes to the tech/shop. -1 degree isn't the end of the world, but yeah it will cause a little uneven wear over time.
08-14-2022, 01:24 PM | #21 |
Rep 126
These steering knuckles are for the M3 & M4. In addition to different camber, the holes for the calipers are 5mm farther out.
2017 430i w/ Strut Brace / M-Perf brakes / M-Sport anti-sway / 255/40/18 square / iDrive-6
