09-15-2016, 02:50 PM | #177 |
Rep 226
09-15-2016, 03:04 PM | #178 |
Rep 716
09-15-2016, 05:44 PM | #179 |
Rep 315
Drives: 2013 335i M Sport
Any eta on the iOS app Dinan?
2013 335i l Estoril Blue | M Sport l MPPK | M Perf Exhaust | M Perf Brakes l Adaptive M Suspension l DAP | DHP | Premium | Tech
My Build -> Mod Journal |
09-17-2016, 07:52 AM | #181 | |
Rep 158
09-17-2016, 10:27 AM | #182 | |
Rep 191
Drives: 2013 BMW 335i M-Sport
2013 335i M-Sport 8spA
2011 M-B GLK350 2000 Dodge Ram 2500 QC 4x4 CTD |
09-23-2016, 11:35 PM | #183 | |
Rep 122
10-19-2016, 01:33 PM | #184 |
Moon Parasite
655
Rep 1,336
Ok, finally got back to a dyno with cooler temps than back in Aug. Today at dyno time temp was 84 deg and 73% humidity. This is the same dynojet dyno the car was run on with the MPPK. Then it measured 312 HP / 315 TQ
Today the last two runs were done with the Dinan Sport in Race mode with 93 oct fuel. End numbers were 323.7 HP / 342.2 TQ So at the wheels that's a delta (change) of 11.7 HP / 26.6 TQ for the inquiring minds out there. Not going to get into crank conversion numbers because that's always a question of the loss factor one chooses to use. The delta is what's important IMO.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
Vegetable792.50 |
10-19-2016, 02:09 PM | #185 | |
Rep 3,130
10-19-2016, 02:13 PM | #186 |
3441
Rep 79,211
I don't even think this car loses 15%. When you guys measure HP, are you using Engine Dyno's?
Would probably better suit Dinan to measure at the wheels on a traditional dyno jet for the sake of transparency. Drivetrain loss percentages are almost never accurate. |
10-19-2016, 04:06 PM | #187 | |
Rep 3,130
Drivetrain loss comes down to a lot of factors including drivetrain, transmission, RPM, etc but 15% seems to be the accepted "throw a percentage at a wall" number everyone likes to use. xDrive cars can be over 20% whereas a RWD car in the current F chassis seemingly is about 12-13% in most cases from our testing and correlating back and forth from the engine to the chassis dyno. Not knowing the OP's drivetrain or anything else I simply used the defacto 15%. |
10-19-2016, 04:18 PM | #188 | |
3441
Rep 79,211
10-19-2016, 07:00 PM | #189 |
Moon Parasite
655
Rep 1,336
For those two above I'd have to go back to the shop and get them to overlay them. Next time I'm on that side of the city I'll see what I can do.
10-19-2016, 09:30 PM | #190 | |
Rep 1,628
M4 in MG | 6 MT
10-20-2016, 08:04 AM | #191 | |
Moon Parasite
655
Rep 1,336
But if you own a GM I highly recommend their shop for tuning or work. They get great results. There was a beautiful blue Cadillac ATS-V that came off the dyno as I got there.
Vegetable792.50 |
10-21-2016, 12:00 AM | #192 | |
Rep 1,628
M4 in MG | 6 MT
10-21-2016, 05:14 AM | #193 | |
Moon Parasite
655
Rep 1,336
The point I was trying to make to you was the only run done in Sport+ was that very first run and I don't think the Op still quite had the feel of dyno'ing a car with kickdown before I switched it to Race. I honestly wouldn't put any great weight in it one way or another. The reason I hesitated to even mention it. The Dinan Sport seems to provide most of its gain at the lower end of RPM range, in my case it seems to really kick in around 2000-2500 rpms up to about 4500-5000, but after that the feel of the car is about the same as before in Sport+ or Race.
Vegetable792.50 |
10-21-2016, 08:50 PM | #195 | |
Rep 1,628
M4 in MG | 6 MT
11-05-2016, 06:29 AM | #196 |
Moon Parasite
655
Rep 1,336
Finally got around to pulling the logged data out of Torque app and graphing it from the last run. (which is the one I have the chart for). Just click on the smaller image and it will pull up the full size.(hyperlinked)
Also I'll post the overlay chart from the last MPPK only run and the Sport+. I think it re-enforces that most of the Pwr/TQ gains are showing in the lower side of the RPM range below 5000rpms.
GPM174.50 |
11-05-2016, 05:26 PM | #197 |
Rep 211
Thanks for posting this. Looks like we're similarly equipped and although without supporting data my butt-o-meter would agree with your results.
Mineral Gray - Active Autowerke Stage 2 - MPerformance Suspension - VRSF CP - CTS Turbo IC - Catted Fabspeed - Akrapovic - HRE FF15
CIWS655.00 |
