01-26-2017, 10:43 PM | #1 |
Rep 22
Do I need to clear any codes when returning a leased car
Hey guys, I have a leased 320i that has JB4 Tuner on it. I will be returning it soon since the lease is done. When I remove the JB4 do I need to clear any codes like shadow codes of some sort (i never put anything other then a premium in it)? Or is it ok to just return it as is? I had also done some other codes like DVD in motion etc. Has any one had any experience returning a leased beamer after tuner install / it being coded.
01-26-2017, 11:50 PM | #2 | |
Rep 14,115
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
01-27-2017, 07:07 AM | #3 |
Rep 554
Don't worry about it, the "shadow codes" and data logs are automatically picked up and sent to BMW if they plugged your car in when you previously took it in for service. Check the threads on the F80 forums. So either they already know or it just wasn't noticed. As for the coding you had done, those all get wiped out when the software is updated before being put for sale.
Boston CCA 383036
'20 M340i '18 MB GLS550 '07 4Runner V8 Limited 4WD |
