01-27-2017, 05:25 AM | #1 |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Good Trickle Charger?
Anyone have any suggestions for a good trickle charger for our cars? Something that is quality and will last.
Thanks
FBO-PS1 and stuff
01-27-2017, 06:25 AM | #3 | |
Dejan
1753
Rep 4,197
That NOCO you use is it pretty slow or? How long have you had it? I'm having an issue with the battery dropping to 11.4-11.5v. In turn what I've discovered that the bm3 and flashing has a minimal flash protocol. It won't flash your car if the car doesn't meet certain criteria.
FBO-PS1 and stuff
01-27-2017, 06:41 AM | #5 | |
Dejan
1753
Rep 4,197
Thanks again Ron. It'll be a slow charge but it's ok my battery isn't dead just low. I'll look into amazon prime asap.
FBO-PS1 and stuff
01-27-2017, 06:53 AM | #6 |
Dejan
1753
Rep 4,197
I see it has AGM so that's good. Do you set it on a particular setting like 12v? Or does it do everything itself?
FBO-PS1 and stuff
01-27-2017, 07:04 AM | #7 | |
Gettin It Figured Out
1820
Rep 2,669
Yes, I have it set to 12v "Cold/AGM" setting, since car and charger sit in a cold garage. Once set, charger does the rest... .
Jadar1752.50 |
01-27-2017, 09:02 AM | #8 | |
Rep 1,502
For charging times you can do the math. The battery in my 335i is 100AH IIRC, so charging from 0 to 100AH at 4A would take 25 hours. IME BMW seems to have programmed the N55 to maintain the battery at about 75%. That is, every time I hook up my charger even after long drives when you'd expect the battery to be 100% the highest I've ever seen is 75%. So topping up to a full 100% might be a waste of time if you're on the clock for whatever reason. |
Jadar1752.50 |
01-27-2017, 02:35 PM | #11 |
Dejan
1753
Rep 4,197
I picked it up. It's actually $10 cheaper and it appears BMW uses it but it's just a BMW logo and the exact same ctek 4.3 rebranded. So good enough for BMW good enough for me.
BMW 4.3 Battery Charger https://www.amazon.com/dp/B00L1JUUVS..._t66IybT7ZHJNB
FBO-PS1 and stuff
01-27-2017, 03:02 PM | #12 | |
Rep 1,502
I think BMW used to rebrand Battery Tender, not sure when they changed. |
Jadar1752.50 |
01-27-2017, 03:04 PM | #13 | ||
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
01-27-2017, 05:45 PM | #15 |
Rep 29
Hard to beat BatteryTender. I use it on my Porsche Boxster in the winter.
https://www.amazon.com/Battery-Tende.../dp/B000NCOKQK Walmart also stocks it. |
Jadar1752.50 |
01-27-2017, 05:46 PM | #16 | |
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
01-27-2017, 07:04 PM | #17 |
Rep 1,502
01-27-2017, 08:28 PM | #19 | |
Rep 1,502
In my case my wife tends to drive local, short trips in our X5. So every once in a while I'll hook up the battery charger when I start getting concerned. I've seen it go from 10% to 75% overnight. The faster charge speed is nice for peace of mind and convenience in those particular use cases. |
Jadar1752.50 |
