10-15-2019, 09:01 AM | #46 | |
Rep 32,881
https://forums.lr4x4.com/topic/39788...pth-for-a-td5/ |
10-15-2019, 09:01 AM | #47 |
Rep 1,268
10-15-2019, 09:03 AM | #48 |
Rep 32,881
You have to wait for the cabin to completely fill with water, for the pressure difference to neutralise.
The0pportunist470.50 RustyBitz1573.50 |
10-15-2019, 09:09 AM | #49 |
Rep 3,967
10-15-2019, 09:35 AM | #50 |
Rep 1,049
Drives: F31 320D Xdrive Msport+
This is what pointed ends of the metal legs of the head restraints are for, hit the windows hard and in the corner and they will put through.
[url=https://www.deutschespeed.com/threads/the-bimmerpost-refugee-thread.561/]Click here for the Bimmerpost UK Refugees - Censorship Sucks![/url]
10-15-2019, 09:44 AM | #51 | |
Barge driver
8656
Rep 12,425
730d/Z4C
10-15-2019, 09:46 AM | #52 | ||
Rep 32,881
10-16-2019, 02:50 AM | #53 |
Rep 4,935
Drives: 340i MPPSK
Never knew that
Life is a state of mind |
10-16-2019, 03:06 AM | #54 | |
Rep 1,049
For the sake of £5 or less it's better to have one of these in the glove box or drivers side storage compartment (if you have the extended storage option) https://www.screwfix.com/p/fire-safe...lt-knife/48101
TodmordenLad2875.50 |
10-16-2019, 03:35 AM | #55 |
Rep 5,681
But if, as he says, the OP had seen other saloon cars drive through without a problem I think he was reasonable to expect his car would be able to do the same. Therefore, if it gets to an insurance claim and his insurers try to say he was negligent I think he's got a reasonable counter argument....
10-16-2019, 06:38 AM | #56 | |
Rep 3,967
10-16-2019, 12:04 PM | #57 |
Rep 228
Got the 1st estimate from the dealer which has now been sent on it insurers, total £4.3k which includes oilflush through, replace all oils and filters, steering rack and starter motor replacement. After this work the engine will be run to assess any further damage.
R |
10-16-2019, 12:21 PM | #58 | |
Rep 32,881
10-16-2019, 12:39 PM | #59 | |
Rep 470
And sounds like you were on an open public road - just can't see how they could refuse to pay out. |
10-16-2019, 01:14 PM | #60 | |
Rep 1,058
Drives: G01 BMW X3 30d M Sport Plus
10-16-2019, 01:37 PM | #61 | |
Rep 5,681
However, are they saying the damage is a result of water entering the engine via the air intake? I do find that surprising if the flood water didn't even get to the bottom of the doors; as per an earlier post, I though the air intake on the F31 was mounted behind the grille and hence the flood water you described shouldn't have got anywhere near it? |
10-16-2019, 03:11 PM | #62 |
Rep 811
So they haven't even taken the spark plugs out and air filter to check the engine?! Over 4 grand for that lot is simply fraud in my opinion. Most of that stuff will be just fine, it's subject to water all the time being the lowest components. Crazy, no wonder our premiums are ridiculous
MashinBenzin8459.00 |
10-16-2019, 05:12 PM | #63 | |
Rep 8,500
New steering rack and starter motor because the car went through a puddle ? Oil flush-through and new seals yet the engine hasn't been checked to see whether it's been structurally compromised ? What good is new oil going to do if the valves are bent, con rods are bent, block is cracked, etc ? What a joke. OP, you should call them out on this.
10-16-2019, 05:45 PM | #64 | |
Rep 32,881
11-03-2019, 10:33 AM | #65 |
Rep 228
they did take the spark plugs out and checked cylinders at the beginning.
After a week of "discussion" dealer and insurance agreed to just do the oil work and then see how the engine behaved. Dealer conformed on Friday that oil work done and compression checked with the result that insurance have agreed to a full repair, expect more news next Friday. Thanks for the advise R |
11-03-2019, 11:09 AM | #66 | ||
Rep 25,115
The new Defender is at the Traf this week coming up. I'll be taking a peek.
My car made front page of Bimmerpost
